2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1941875] Re: Buggy warning message "Record/Alias name '...' should not contain non-printable ...
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 11 Oct 2021 18:13:25 -0000
** Changed in: epics-base
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1941875
Title:
  printable ...
Status in EPICS Base:
  Fix Released
Bug description:
  There are multiple bugs in dbRecordNameValidate()
  (modules/database/src/ioc/dbStatic/dbLexRoutines.c).
  /* any character restrictions */
  char c = *pos;
  if(c < ' ') {
    errlogPrintf("Warning: Record/Alias name '%s' should not contain non-printable 0x%02u\n",
                           name, (unsigned)c);
  1. The check for non-printable characters: if(c < ' ') does not consider implementations where char is signed. Characters with the high bit set are considered negative and thus <' '.
  2. Printing the character with "0x%02u" prints a decimal number prefixed with 0x which is confusing (not to say wrong).
  3. Casting a signed char to unsigned effectively first sign extends the char to int, then re-interprets it as unsigned int, turning a char >0x80 into a number >4294967168.
  On an implementation where char is unsigned, the whole casting is pointless anyway.
  This results in confusing warnings like:
  Warning: Record/Alias name 'Ä' should not contain non-printable 0x4294967235
  The function should explicitly use unsigned char c to fix (c < ' '),
  use "0x%02x" to format c and not cast c.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1941875/+subscriptions
[Bug 1941875] [NEW] Buggy warning message "Record/Alias name '...' should not contain non-printable ... Dirk Zimoch via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-402 AppVeyor via Core-talk
Next: [Bug 1938459] Re: int64in only checks lower 32 bits for change Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1941875] Re: Buggy warning message "Record/Alias name '...' should not contain non-printable ... mdavidsaver via Core-talk
Next: Build completed: epics-base base-7.0-751 AppVeyor via Core-talk
ANJ, 11 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
