Public bug reported:
There are multiple bugs in dbRecordNameValidate()
(modules/database/src/ioc/dbStatic/dbLexRoutines.c).
/* any character restrictions */
char c = *pos;
if(c < ' ') {
errlogPrintf("Warning: Record/Alias name '%s' should not contain non-printable 0x%02u\n",
name, (unsigned)c);
1. The check for non-printable characters: if(c < ' ') does not consider implementations where char is signed. Characters with the high bit set are considered negative and thus <' '.
2. Printing the character with "0x%02u" prints a decimal number prefixed with 0x which is confusing (not to say wrong).
3. Casting a signed char to unsigned effectively first sign extends the char to int, then re-interprets it as unsigned int, turning a char >0x80 into a number >4294967168.
On an implementation where char is unsigned, the whole casting is pointless anyway.
This results in confusing warnings like:
Warning: Record/Alias name 'Ä' should not contain non-printable 0x4294967235
The function should explicitly use unsigned char c to fix (c < ' '), use
"0x%02x" to format c and not cast c.
** Affects: epics-base
Importance: Undecided
Status: New
** Patch added: "dbLexRoutines.patch"
https://bugs.launchpad.net/bugs/1941875/+attachment/5521157/+files/dbLexRoutines.patch
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
Title:
Buggy warning message "Record/Alias name '...' should not contain non-
printable ...
Status in EPICS Base:
New
Bug description:
char c = *pos;
if(c < ' ') {
name, (unsigned)c);
use "0x%02x" to format c and not cast c.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1941875/+subscriptions
- [Bug 1941875] Re: Buggy warning message "Record/Alias name '...' should not contain non-printable ... mdavidsaver via Core-talk
- [Bug 1941875] Re: Buggy warning message "Record/Alias name '...' should not contain non-printable ... Andrew Johnson via Core-talk
[Bug 1935037] Re: Invalid charactor in field name Ralph Lange via Core-talk
[Bug 1935037] Re: Invalid charactor in field name Dirk Zimoch via Core-talk
<2021>
2025
2026
[Bug 1941770] Re: Base-3.15.9 tarfile is missing the startup directory Andrew Johnson via Core-talk
<2021>
2025
2026
