2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: CA gateway chaining
From: Timo Korhonen via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 25 Oct 2021 08:35:11 +0000
We at ESS are using CA gateways in a “chain” configuration, i.e., roughly in the following way:
Machine (aka Technical) network -> gateway A-> internal DMZ -> gateway B-> office network.
Does any of you have any experience with such a configuration?
What we have been seeing are somewhat oddly constant access delays, for instance caget taking more or less exactly one second to read an otherwise idle PV via gateway B.
Not surprisingly, this appears to be related to the traffic on the networks (i.e., machine operation.)
We have not yet done any systematic studies on this, I just thought to ask if anybody has experience or thoughts about this kind of issue.
Is this usage pattern something that should rather be avoided?
Cheers,
Timo
Re: CA gateway chaining Zimoch Dirk (PSI) via Core-talk
Re: [EXTERNAL] CA gateway chaining Hartman, Steven via Core-talk
Prev: Build failed: pva2pva 1.0.37 AppVeyor via Core-talk
Next: Re: CA gateway chaining Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Build failed: pva2pva 1.0.48 AppVeyor via Core-talk
ANJ, 25 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
