2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] CA gateway chaining
From: "Hartman, Steven via Core-talk" <core-talk at aps.anl.gov>
To: Timo Korhonen <Timo.Korhonen at ess.eu>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Mon, 25 Oct 2021 15:16:38 +0000
On Oct 25, 2021, at 4:35 AM, Timo Korhonen via Core-talk <core-talk at aps.anl.gov> wrote:
We at ESS are using CA gateways in a “chain” configuration, i.e., roughly in the following way:
Machine (aka Technical) network -> gateway A-> internal DMZ -> gateway B-> office network.
Does any of you have any experience with such a configuration?
Hi Timo—
For the SNS beam lines, each beam line has a gateway, and then we have a gateway-of-gateways for office machine clients to connect with . . .
bl1-gateway  }
bl2-gateway  }
bl3-gateway  }   -> aggregating-gateway -> office network clients
bln-gateway  }
There are nearly 30 gateways at the first level on separate private networks. Large arrays can impact performance, but generally it has worked quite well. We do not see a 1 second delay.
Steven Hartman
hartmansm at ornl.gov
Re: [EXTERNAL] CA gateway chaining Zimoch Dirk (PSI) via Core-talk
CA gateway chaining Timo Korhonen via Core-talk
Prev: Re: CA gateway chaining Timo Korhonen via Core-talk
Next: Re: CA gateway chaining Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: CA gateway chaining Kasemir, Kay via Core-talk
Next: Re: [EXTERNAL] CA gateway chaining Zimoch Dirk (PSI) via Core-talk
ANJ, 26 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
