2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Build failed: EPICS Base 7 base-7.0-419 (and others)
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: <core-talk at aps.anl.gov>
Date: Thu, 28 Oct 2021 10:56:23 +0200
Folks,
Digging into the last "Build failed" messages
(thanks to Karl for reminding me)
It seems as if there is a problem with this test case:
not ok 54 - dbGetField("li2", 5) -> 3 == 0
Failed 1/54 subtests
simmTest.tap .............. ok
mbbioDirectTest.tap ....... ok
asyncproctest.tap ......... ok
linkFilterTest.tap ........ ok
Test Summary Report
regressTest.tap         (Wstat: 0 Tests: 54 Failed: 1)
  Failed test:  54
This very run had 33 passed and 3 failed (all with this error)
Other runs have the same test case failure.
And sometimes problems with packages.chocolatey.org, see further down.
Are there any good ideas, what could be done about the
failure ?
Disable it under Windows ?
Retry, if it failed ?
Add a sleep?
sleep & retry if it failed ?
Any other good ideas ?
/Torsten
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/7ec7ep7n3xgy8r9n
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/8ie32k5b1t8jprqc
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/rehp29dioh4oit21
- make (exited 1) - make not installed. An error occurred during installation:
 The remote name could not be resolved: 'packages.chocolatey.org'
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/fwl9hskcml6gpcro
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/fne84vwr6h5653tv
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/bv72o8wc2p53cgv8
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/l1j2bhpq7756vrgl
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/ia3httwhe4e6djgr
[snip]
https://ci.appveyor.com/project/epics-base-7/epics-base/builds/41272487/job/qqi3lx0w4132jaly
Re: Build failed: EPICS Base 7 base-7.0-419 (and others) Johnson, Andrew N. via Core-talk
Build failed: EPICS Base 7 base-7.0-419 AppVeyor via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-419 AppVeyor via Core-talk
Next: Re: Build failed: EPICS Base 7 base-7.0-419 (and others) Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 28 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
