2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: pvMonitor questions
From: Mark L Rivers via Core-talk <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Wed, 3 Nov 2021 17:52:34 +0000
Folks,
I’m trying to understand the –q option to pvMonitor.  This is the help output:
TahoeU18:/corvette/home/epics/scratch> /corvette/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64-ub18/pvmonitor -h
Usage: pvmonitor [options] <PV name>...
options:
  -h: Help: Print this message
  -V: Print version and exit
  -r <pv request>:   Request, specifies what fields to return and options, default is ''
  -w <sec>:          Wait time, specifies timeout, default is 5.000000 second(s)
  -p <provider>:     Set default provider name, default is 'pva'
  -M <raw|nt|json>:  Output mode.  default is 'nt'
  -v:                Show entire structure (implies Raw mode)
  -q:                Quiet mode, print only error messages
  -d:                Enable debug output
deprecated options:
  -q, -t, -i, -n, -F: ignored
  -f <input file>:   errors
Output details:
  -m -v:             Monitor in Raw mode.  Print only fields marked as changed.
  -m -vv:            Monitor in Raw mode.  Highlight fields marked as changed, show all valid fields.
  -m -vvv:           Monitor in Raw mode.  Highlight fields marked as changed, show all fields.
  -vv:               Get in Raw mode.  Highlight valid fields, show all fields.
example: pvmonitor double01
It appears to have contradictory information.  It says that –q is quite mode and prints only error messages, and then it says that –q is deprecated.
When I run with –q it is not quiet, it outputs the same information as it does without –q.
TahoeU18:/corvette/home/epics/scratch> /corvette/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64-ub18/pvmonitor -r "value" -q 13SIM1:Pva1:Image
13SIM1:Pva1:Image structure
    union value
        float[]  [912250,912251,912252,912253,912254,912255,912256,912257,912258,912259,912260,912261,912262,912263,912326,…
It would be really nice to be able to limit the output of pvmonitor, similar to the -# option in camonitor.  I don’t care if it subscribes to the entire array, I just want to limit the processing time in pvmonitor to convert to ASCII, and to limit the amount of output it produces.
Can someone also explain what the –Mraw flag to pvget and pvmonitor does?  I don’t see any difference in the output with and without that option:
TahoeU18:/corvette/home/epics/scratch> /corvette/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64-ub18/pvget -r "value" 13SIM1:Pva1:Image | more
    union value
        float[]  [912445,912446,912447,912448,912449,912450,912451,912452,912453,912454,912455
TahoeU18:/corvette/home/epics/scratch> /corvette/usr/local/epics-devel/base-7.0.5/bin/linux-x86_64-ub18/pvget -r "value" -Mraw 13SIM1:Pva1:Image | more
    union value
        float[]  [912445,912446,912447,912448,912449,912450,912451,912452,912453,912454,912455,
Re: pvMonitor questions Michael Davidsaver via Core-talk
Prev: Build failed: epics-base base-fix-regressTest-regression-770 AppVeyor via Core-talk
Next: epics-base-7.0-win64-test - Build # 361 - Fixed! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Next: Re: pvMonitor questions Michael Davidsaver via Core-talk
ANJ, 03 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
