2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1951848] [NEW] Failing EPICS 7 libCom tests on VxWorks 6.7
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 22 Nov 2021 15:35:36 -0000
Public bug reported:
epicsThreadTest
# System has 1 CPUs
ok  1 - ncpus > 0
# main() thread 0x581810
not ok  2 - Join delayed parent (0 seconds) # TODO Thread join doesn't work
ok  3 - Join tests #1 completed
not ok  4 - Join delayed parent (0 seconds) # TODO Thread join doesn't work
ok  5 - Join tests #2 completed
not ok 12 - infoB.didSomething
not ok 13 - infoA.didSomething
not ok 14 - threadA epicsThreadIsOkToBlock() = 88
not ok 15 - threadB epicsThreadIsOkToBlock() = 7001716
    Results
       Tests: 15
      Passed:  11 = 73.33%
      Failed:   4 = 26.67%
epicsEventTest (TODO)
not ok 16 - epicsEventWaitWithTimeout(0.125000)  delay error -0.008332 sec # TODO Known issue with delay calculation
not ok 17 - epicsEventWaitWithTimeout(0.062500)  delay error -0.012501 sec # TODO Known issue with delay calculation
not ok 18 - epicsEventWaitWithTimeout(0.031250)  delay error -0.014585 sec # TODO Known issue with delay calculation
    Results
       Tests: 37
      Passed:  37 = 100.00%
 Todo Passes:  19 = 51.35%
epicsSockResolveTest
not ok 26 - aToIPAddr("127.0.0.test", 4000) -> 0
#   IP=0x7f000000, port=4000
not ok 27 - aToIPAddr("127.0.0.test:42", 4000) -> 0
#   IP=0x7f000000, port=42
not ok 30 - aToIPAddr("1.2.3.4.5", 4000) -> 0
#   IP=0x1020304, port=4000
not ok 31 - aToIPAddr("1.2.3.4.5:6", 4000) -> 0
#   IP=0x1020304, port=6
    Results
       Tests: 37
      Passed:  33 = 89.19%
      Failed:   4 = 10.81%
This fails because the VxWorks 6.7 implementation of hostGetByName
happily reads rubbish as the 4th numeric component as 0 and ignores any
further componends. Fixed in vxWorks 6.9.
epicsStdioTest (not really a bug: r/o NFS mount)
not ok 152 - (stream = fopen(report, "w")) != NULL
# 'report' could not be opened for writing: S_nfsLib_NFSERR_ROFS
ok 153 # SKIP Can't create stream file
ok 154 # SKIP Can't create stream file
ok 155 # SKIP Can't create stream file
ok 156 # SKIP Can't create stream file
ok 157 # SKIP Can't create stream file
ok 158 # SKIP Can't create stream file
ok 159 # SKIP Can't create stream file
ok 160 # SKIP Can't create stream file
ok 161 # SKIP Can't create stream file
ok 162 # SKIP Can't create stream file
ok 163 # SKIP Can't create stream file
    Results
       Tests: 163
      Passed: 162 = 99.39%
      Failed:   1 =  0.61%
     Skipped:  11 =  6.75%
macDefExpandTest
# Got "", expected "BAR".
not ok 27 - ${=BAR}
# Got "xy", expected "xBARy".
not ok 28 - x${=BAR}y
    Results
       Tests: 97
      Passed:  95 = 97.94%
      Failed:   2 =  2.06%
This test succeeds on VxWorks 6.9.
Running this test a second time fails more often because some environment variables are now defined, e.g.
not ok 77 - Macro F is 6, expected undefined
    Results
       Tests: 97
      Passed:  79 = 81.44%
      Failed:  18 = 18.56%
The test should unset all environment variables which it expects to be
unset!
** Affects: epics-base
     Importance: Undecided
         Status: New
** Summary changed:
- Failing libCom tests on VxWorks
+ Failing EPICS 7 libCom tests on VxWorks 6
** Summary changed:
- Failing EPICS 7 libCom tests on VxWorks 6
+ Failing EPICS 7 libCom tests on VxWorks 6.7
** Description changed:
  epicsThreadTest
  # System has 1 CPUs
  ok  1 - ncpus > 0
-     Results
-        Tests: 15
-       Passed:  11 = 73.33%
-       Failed:   4 = 26.67%
+     Results
+        Tests: 15
+       Passed:  11 = 73.33%
+       Failed:   4 = 26.67%
-     Results
-        Tests: 37
-       Passed:  37 = 100.00%
-  Todo Passes:  19 = 51.35%
+     Results
+        Tests: 37
+       Passed:  37 = 100.00%
+  Todo Passes:  19 = 51.35%
-     Results
-        Tests: 37
-       Passed:  33 = 89.19%
-       Failed:   4 = 10.81%
+     Results
+        Tests: 37
+       Passed:  33 = 89.19%
+       Failed:   4 = 10.81%
- This fails because the VxWorks implementation of hostGetByName happily reads rubbish as the 4th numeric component as 0 and ignores any further componends.
+ This fails because the VxWorks 6.7 implementation of hostGetByName
+ happily reads rubbish as the 4th numeric component as 0 and ignores any
+ further componends. Fixed in vxWorks 6.9.
-     Results
-        Tests: 163
-       Passed: 162 = 99.39%
-       Failed:   1 =  0.61%
-      Skipped:  11 =  6.75%
+     Results
+        Tests: 163
+       Passed: 162 = 99.39%
+       Failed:   1 =  0.61%
+      Skipped:  11 =  6.75%
  macDefExpandTest
  not ok 27 - ${=BAR}
-     Results
-        Tests: 97
-       Passed:  95 = 97.94%
-       Failed:   2 =  2.06%
+     Results
+        Tests: 97
+       Passed:  95 = 97.94%
+       Failed:   2 =  2.06%
-     Results
-        Tests: 97
-       Passed:  79 = 81.44%
-       Failed:  18 = 18.56%
+     Results
+        Tests: 97
+       Passed:  79 = 81.44%
+       Failed:  18 = 18.56%
  unset!
  epicsThreadTest
  # System has 1 CPUs
  ok  1 - ncpus > 0
      Results
         Tests: 15
        Passed:  11 = 73.33%
        Failed:   4 = 26.67%
      Results
         Tests: 37
      Results
         Tests: 37
        Passed:  33 = 89.19%
        Failed:   4 = 10.81%
      Results
         Tests: 163
        Failed:   1 =  0.61%
       Skipped:  11 =  6.75%
  macDefExpandTest
  not ok 27 - ${=BAR}
      Results
         Tests: 97
        Passed:  95 = 97.94%
        Failed:   2 =  2.06%
+ This test succeeds on VxWorks 6.9.
      Results
         Tests: 97
        Passed:  79 = 81.44%
        Failed:  18 = 18.56%
  unset!
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1951848
Title:
Status in EPICS Base:
  New
Bug description:
  epicsThreadTest
  # System has 1 CPUs
  ok  1 - ncpus > 0
      Results
         Tests: 15
        Passed:  11 = 73.33%
        Failed:   4 = 26.67%
      Results
         Tests: 37
      Results
         Tests: 37
        Passed:  33 = 89.19%
        Failed:   4 = 10.81%
  any further componends. Fixed in vxWorks 6.9.
      Results
         Tests: 163
        Failed:   1 =  0.61%
       Skipped:  11 =  6.75%
  macDefExpandTest
  not ok 27 - ${=BAR}
      Results
         Tests: 97
        Passed:  95 = 97.94%
        Failed:   2 =  2.06%
      Results
         Tests: 97
        Passed:  79 = 81.44%
        Failed:  18 = 18.56%
  unset!
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1951848/+subscriptions
[Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 Dirk Zimoch via Core-talk
[Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 and 6.9 Dirk Zimoch via Core-talk
[Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 and 6.9 Andrew Johnson via Core-talk
Prev: AW: Strange UDP message on VxWorks 6.9 Zimoch Dirk (PSI) via Core-talk
Next: [Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: epics-pva2pva-linux32 - Build # 230 - Fixed! APS Jenkins via Core-talk
ANJ, 27 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
