2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1952074] Re: Using %z in printf is not portable
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 24 Nov 2021 10:42:12 -0000
** Description changed:
  Some code in EPICS uses printf with the z format modifier for size_t arguments, as in "%zu". This is not portable. VxWorks (at least up to version 6.9.0) does not understand this and prints "zu" and then shifts all the remaining arguments to the wrong format specifier!
- Older Windows versions uses "%Iu" for the same purpose.
+ Older Windows versions use "%Iu" for the same purpose.
  Affected code:
  modules/libcom/src/error/errlog.c (2x)
  modules/libcom/test/epicsErrlogTest.c
  modules/libcom/test/yajl_test.c (2x)
  modules/pvAccess/pvtoolsSrc/pvlist.cpp (2x)
  modules/pvAccess/src/ioc/reftrackioc.cpp (2x)
- modules/pvAccess/blockingUDPTransport.cpp (4x)
+ modules/pvAccess/src/remote/blockingUDPTransport.cpp (4x)
  modules/pvAccess/src/remote/codec.cpp (2x)
  modules/pvAccess/src/remote/transportRegistry.cpp
  modules/pvAccess/src/server/responseHandlers.cpp
  modules/pvAccess/testApp/remote/testChannelConnect.cpp
  modules/pvAccess/testApp/remote/testmonitorfifo.cpp (4x)
  modules/pvData/src/factory/FieldCreateFactory.cpp (2x)
  modules/pvData/testApp/pv/performstruct.cpp (2x)
  modules/pvData/testApp/pv/testPVData.cpp
  modules/pva2pva/pdbApp/pdbgroup.cpp
  modules/pva2pva/pdbApp/pvalink.cpp (3x)
  modules/pva2pva/pdbApp/pvalink_jlif.cpp
  modules/pva2pva/testApp/testpdb.cpp (2x)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1952074
Title:
Status in EPICS Base:
  New
Bug description:
  Affected code:
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1952074/+subscriptions
[Bug 1952074] [NEW] Using %z in printf is not portable Dirk Zimoch via Core-talk
Prev: [Bug 1952074] Re: Using %z in printf is not portable Dirk Zimoch via Core-talk
Next: [Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 and 6.9 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Next: [Bug 1952074] Re: Using %z in printf is not portable Ralph Lange via Core-talk
ANJ, 24 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
