2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1952074] Re: Using %z in printf is not portable
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 24 Nov 2021 12:24:43 -0000
The problem is that size_t has a different size (!) on different
implementations.
The usual (only?) way to get this portable is to cast the argument to
something like 'unsigned long long' and use the matching format
specifier.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1952074
Title:
Status in EPICS Base:
  New
Bug description:
  Some code in EPICS uses printf with the z format modifier for size_t arguments, as in "%zu". This is not portable. VxWorks (at least up to version 6.9.0) does not understand this and prints "zu" and then shifts all the remaining arguments to the wrong format specifier!
  Older Windows versions use "%Iu" for the same purpose.
  Affected code:
  modules/libcom/src/error/errlog.c (2x)
  modules/libcom/test/epicsErrlogTest.c
  modules/libcom/test/yajl_test.c (2x)
  modules/pvAccess/pvtoolsSrc/pvlist.cpp (2x)
  modules/pvAccess/src/ioc/reftrackioc.cpp (2x)
  modules/pvAccess/src/remote/blockingUDPTransport.cpp (4x)
  modules/pvAccess/src/remote/codec.cpp (2x)
  modules/pvAccess/src/remote/transportRegistry.cpp
  modules/pvAccess/src/server/responseHandlers.cpp
  modules/pvAccess/testApp/remote/testChannelConnect.cpp
  modules/pvAccess/testApp/remote/testmonitorfifo.cpp (4x)
  modules/pvData/src/factory/FieldCreateFactory.cpp (2x)
  modules/pvData/testApp/pv/performstruct.cpp (2x)
  modules/pvData/testApp/pv/testPVData.cpp
  modules/pva2pva/pdbApp/pdbgroup.cpp
  modules/pva2pva/pdbApp/pvalink.cpp (3x)
  modules/pva2pva/pdbApp/pvalink_jlif.cpp
  modules/pva2pva/testApp/testpdb.cpp (2x)
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1952074/+subscriptions
[Bug 1952074] [NEW] Using %z in printf is not portable Dirk Zimoch via Core-talk
Prev: [Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 and 6.9 Dirk Zimoch via Core-talk
Next: [Bug 1952074] Re: Using %z in printf is not portable rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1952074] Re: Using %z in printf is not portable Dirk Zimoch via Core-talk
ANJ, 24 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
