See <https://jenkins.aps.anl.gov/job/epics-pvaClient/527/display/redirect>
Changes:
Started by upstream project "epics-normativeTypes-vx68" build number 303
originally caused by:
Started by upstream project "epics-normativeTypes" build number 304
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on the built-in node in workspace <https://jenkins.aps.anl.gov/job/epics-pvaClient/ws/>
The recommended git tool is: NONE
No credentials specified
> git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-pvaClient/ws/.git> # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://github.com/epics-base/pvaClientCPP.git # timeout=10
Cleaning workspace
> git rev-parse --verify HEAD # timeout=10
Resetting working tree
> git reset --hard # timeout=10
> git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvaClientCPP.git
> git --version # timeout=10
> git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://github.com/epics-base/pvaClientCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://github.com/epics-base/pvaClientCPP.git
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1001)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1242)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1302)
at hudson.scm.SCM.checkout(SCM.java:505)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1213)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:643)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:515)
at hudson.model.Run.execute(Run.java:1888)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:99)
at hudson.model.Executor.run(Executor.java:432)
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --progress https://github.com/epics-base/pvaClientCPP.git +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: remote: Internal Server Error.
remote:
fatal: unable to access 'https://github.com/epics-base/pvaClientCPP.git/': The requested URL returned error: 500
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2681)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2102)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:86)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:624)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:999)
... 11 more
Project epics-pvaClient still waiting for [epics-pvaClient-vx68, epics-pvaClient-vx69, epics-pvaClient-rtems] builds to complete
- Jenkins build is back to normal : epics-pvaClient #528 APS Jenkins via Core-talk
Build failed in Jenkins: epics-pvData-mac #198 APS Jenkins via Core-talk
Build failed in Jenkins: epics-example #749 APS Jenkins via Core-talk
<2021>
2025
2026
Jenkins build is back to normal : epics-pvData-mac #199 APS Jenkins via Core-talk
<2021>
2025
2026
