2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-example #749
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 27 Nov 2021 15:01:57 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-example/749/display/redirect>
Changes:
Started by upstream project "epics-pva2pva-vx69" build number 330
originally caused by:
 Started by upstream project "epics-pva2pva" build number 331
  Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on the built-in node in workspace <https://jenkins.aps.anl.gov/job/epics-example/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-example/ws/.git> # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
 > git --version # timeout=10
 > git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision bf816da88471171afc6c6b5ed6f912289336c30e (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f bf816da88471171afc6c6b5ed6f912289336c30e # timeout=10
Commit message: "add putAlarm and putTimeStamp"
 > git rev-list --no-walk bf816da88471171afc6c6b5ed6f912289336c30e # timeout=10
[workspace] $ /bin/sh -xe /tmp/jenkins2879316252190518107.sh
+ echo 'PVDATABASE = /Jenkins/jenkins/jobs/epics-pvDatabase/workspace'
+ echo 'PVACLIENT = /Jenkins/jenkins/jobs/epics-pvaClient/workspace'
+ echo 'PVA2PVA = /Jenkins/jenkins/jobs/epics-pva2pva/workspace'
+ echo 'PVACCESS = /Jenkins/jenkins/jobs/epics-pvAccess/workspace'
+ echo 'NORMATIVE = /Jenkins/jenkins/jobs/epics-normativeTypes/workspace'
+ echo 'PVDATA = /Jenkins/jenkins/jobs/epics-pvData/workspace'
+ echo 'PVCOMMON = /Jenkins/jenkins/jobs/epics-pvCommon/workspace'
+ echo 'EPICS_BASE = /Jenkins/jenkins/jobs/epics-base-3.16/workspace'
+ make host
make -C ./configure install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure'
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure/O.linux-x86_64'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/configure'
make -C ./scalarLimit install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit'
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/configure'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/configure/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/configure'
make -C ./src install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/src'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include      -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include   -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF scalarLimitRecord.d  ../scalarLimitRecord.cpp
Installing dbd file ../../dbd/scalarLimitRecord.dbd
mkdir ../../dbd
Installing generic include file ../../include/scalarLimit/scalarLimitRecord.h
mkdir ../../include
mkdir ../../include/scalarLimit
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include      -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include   -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -c ../scalarLimitRecord.cpp
/usr/bin/ar -rc    libscalarLimitRecord.a         scalarLimitRecord.o
/usr/bin/ranlib libscalarLimitRecord.a
/usr/bin/g++ -o libscalarLimitRecord.so -shared -fPIC -Wl,-hlibscalarLimitRecord.so -L/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-base-3.16/workspace/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-pvAccess/workspace/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-pvData/workspace/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-base-3.16/workspace/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-pvAccess/workspace/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-pvData/workspace/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/lib/linux-x86_64           -rdynamic -m64             scalarLimitRecord.o   -lpvDatabase -lpvAccess -lpvAccessCA -lnt -lpvData -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../lib/linux-x86_64/libscalarLimitRecord.so
mkdir ../../lib
mkdir ../../lib/linux-x86_64
Installing library ../../lib/linux-x86_64/libscalarLimitRecord.a
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/src/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit/src'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/scalarLimit'
make -C ./powerSupplyRecord install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord'
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/configure'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/configure/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/configure'
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/src'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include      -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include   -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF powerSupplyMonitor.d  ../powerSupplyMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include      -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include   -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF powerSupplyClient.d  ../powerSupplyClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/Jenkins/jenkins/jobs/epics-pvDatabase/workspace/include      -I/Jenkins/jenkins/jobs/epics-pva2pva/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvAccess/workspace/include   -I/Jenkins/jenkins/jobs/epics-normativeTypes/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvData/workspace/include   -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include        -MM -MF powerSupplyRecord.d  ../powerSupplyRecord.cpp
Installing dbd file ../../dbd/powerSupplyRecord.dbd
mkdir ../../dbd
Installing generic include file ../../include/powerSupply/powerSupplyRecord.h
mkdir ../../include
mkdir ../../include/powerSupply
make[3]: *** No rule to make target '../../lib/linux-x86_64/libpvaClient.a', needed by 'libpowerSupplyRecord.a'.  Stop.
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/src/O.linux-x86_64'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord/src'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_DIRS:84: recipe for target 'src.install.linux-x86_64' failed
make[1]: *** [src.install.linux-x86_64] Error 2
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-example/workspace/powerSupplyRecord'
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_DIRS:84: recipe for target 'powerSupplyRecord.install.linux-x86_64' failed
make: *** [powerSupplyRecord.install.linux-x86_64] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: test/O.*/*.tap
Did not find any matching files.
Build failed in Jenkins: epics-example #750 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-pvaClient #527 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-pvCommon-linux32 #30 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-pvaClient #528 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-example #750 APS Jenkins via Core-talk
ANJ, 06 Dec 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
