2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: breaktable name incompatibilities
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Zimoch Dirk (PSI)" <dirk.zimoch at psi.ch>
Cc: "'core-talk at aps.anl.gov'" <core-talk at aps.anl.gov>
Date: Tue, 4 Jan 2022 08:20:35 -0800
On 1/4/22 1:09 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> The following breaktable name worked perfectly fine in EPICS 3.14:
> breaktable(ZX47-55LN+_142.8MHz) {
> But in EPICS 7, registerRecordDeviceDriver.pl complains:
> Syntax error in 'breaktable(ZX47-55LN+_142.8MHz) {'
> Not very informative, but let's try with quotes. Not the error is:
> Illegal breakpoint table name 'ZX47-55LN+_142.8MHz'
>         Identifiers are used in C code so must start with a letter, followed
>         by letters, digits and/or underscore characters only.
> Why that? The name of a breaktable is never used as a C identifier. It is simply a string.
> Such breaking changes are very inconvenient, as they require to change all the templates where the name is used and
Hi Dirk, I hope you can understand that this was almost certainly not
an intentionally breaking change!
It looks like a side effect of code re-use in the perl DBD parser code
because so many names in .dbd files do become C identifiers.
> make transition to EPICS 7 unnecessarily cumbersome.
I can't help but wonder if incremental testing with > 3.14 at some point
in the past decade, even only of compilation, would have helped PSI to
avoid this kind of frustration.
> Can we change it back?
I'll left this for Andrew.
breaktable name incompatibilities Zimoch Dirk (PSI) via Core-talk
Prev: Re: breaktable name incompatibilities Johnson, Andrew N. via Core-talk
Next: [Bug 1956459] [NEW] epicsThreadTest crashes on vxWorks 6.9.0 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
