2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: Git push problem
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 11 Jan 2022 20:36:01 +0000
I fixed the problem.  I added a .ssh/config file for the account I use for github:
Host *
    MACs hmac-sha1,umac-64 at openssh.com,hmac-ripemd160,hmac-sha2-512-etm at openssh.com,hmac-sha2-256-etm at openssh.com,hmac-sha2-512,hmac-sha2-256
I added all of the MACs that it said github was offering.
I am quite sure that nothing changed on my computer, so it seems like Github must have stopped supporting any of the MACs in my /etc/ssh/ssh_config file.  By adding all of the MACs Github says they do support to my .ssh/config file it now works.  Others running older versions of openssh may run into the same issue.
Sent: Tuesday, January 11, 2022 2:03 PM
Cc: core-talk at aps.anl.gov
Hi Michael,
Thanks for the reply.
Ø  Maybe an OS upgrade is in order?
I really want to avoid having to upgrade this OS now.  It was working fine last week and nothing has changed on our system that I know of.
Ø  Which openssh version is currently installed?
corvette:~>ssh -V
OpenSSH_7.4p1, OpenSSL 1.0.2k-fips  26 Jan 2017
Ø  GIT_SSH_COMMAND="ssh -vvv" git push
Ø  will print the gory details of the SSH connection process.
I tried that but I don't see any gory details:
export (base) [epics@corvette asyn]$ GIT_SSH_COMMAND="ssh -vvv" git push
Unable to negotiate with 140.82.112.3 port 22: no matching MAC found. Their offer: hmac-sha2-512-etm at openssh.com,hmac-sha2-256-etm at openssh.com,hmac-sha2-512,hmac-sha2-256
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
This is part of my /etc/ssh/ssh_config:
# Host *
#   ForwardAgent no
#   ForwardX11 no
#   RhostsRSAAuthentication no
#   RSAAuthentication yes
#   PasswordAuthentication yes
#   HostbasedAuthentication no
#   GSSAPIAuthentication no
#   GSSAPIDelegateCredentials no
#   GSSAPIKeyExchange no
#   GSSAPITrustDNS no
#   BatchMode no
#   CheckHostIP yes
#   AddressFamily any
#   ConnectTimeout 0
#   StrictHostKeyChecking ask
#   IdentityFile ~/.ssh/identity
#   IdentityFile ~/.ssh/id_rsa
#   IdentityFile ~/.ssh/id_dsa
#   IdentityFile ~/.ssh/id_ecdsa
#   IdentityFile ~/.ssh/id_ed25519
#   Port 22
#   Protocol 2
#   Cipher 3des
#   Ciphers aes128-ctr,aes192-ctr,aes256-ctr,arcfour256,arcfour128,aes128-cbc,3des-cbc
#   MACs hmac-md5,hmac-sha1,umac-64 at openssh.com,hmac-ripemd160
#   EscapeChar ~
#   Tunnel no
#   TunnelDevice any:any
#   PermitLocalCommand no
#   VisualHostKey no
#   ProxyCommand ssh -q -W %h:%p gateway.example.com
#   RekeyLimit 1G 1h
Does that the only MACs supported are the ones uncommented above, i.e.
If so what is the meaning of the ssh –Q mac output:
(base) [epics@corvette asyn]$ ssh -Q mac
hmac-sha1
hmac-sha1-96
hmac-sha2-256
hmac-sha2-512
hmac-md5
hmac-md5-96
hmac-ripemd160
hmac-ripemd160 at openssh.com
umac-128 at openssh.com
hmac-sha1-etm at openssh.com
hmac-sha1-96-etm at openssh.com
hmac-md5-etm at openssh.com
hmac-md5-96-etm at openssh.com
hmac-ripemd160-etm at openssh.com
umac-64-etm at openssh.com
umac-128-etm at openssh.com
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Tuesday, January 11, 2022 1:33 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Subject: Re: Git push problem
On 1/11/22 10:32 AM, Mark Rivers via Core-talk wrote:
> Folks,
> I am trying to push to the Github asyn repository from a Linux system that has worked for many years.
Maybe an OS upgrade is in order?  Which openssh version is currently installed?
> It worked as recently as January 6.  But now I am getting this error:
I am able to push successfully.
> $ grep Debian /etc/os-release
> PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"> $ ssh -V
> OpenSSH_8.4p1 Debian-5, OpenSSL 1.1.1k  25 Mar 2021
> corvette:~/devel/asyn>git push
fyi.
> Unable to negotiate with 140.82.113.4 port 22: no matching MAC found. Their offer: hmac-sha2-512-etm at openssh.com,hmac-sha2-256-etm at openssh.com,hmac-sha2-512,hmac-sha2-256
> When I run ssh –Q mac it seems like I have all of their support MAC types:
> corvette:~/devel/asyn>ssh -Q mac
> hmac-sha1
> hmac-sha1-96
> hmac-sha2-256
> hmac-sha2-512
> hmac-md5
> hmac-md5-96
> hmac-ripemd160
> umac-128-etm at openssh.com <mailto:umac-128-etm at openssh.com>
> My ssh keys have not changed.  I removed github.com from known_hosts just in case that was the problem.
> corvette:~/.ssh>ls -l
> total 28
> -rw------- 1 epics domain users  3243 Nov 18  2019 id_rsa
> -rw-r--r-- 1 epics domain users   750 Nov 18  2019 id_rsa.pub
> -rw-r--r-- 1 epics domain users 17340 Jan 11 12:30 known_hosts
> Any idea how to fix this?
> Thanks,
> Mark
Re: Git push problem Ralph Lange via Core-talk
Git push problem Mark Rivers via Core-talk
Re: Git push problem Michael Davidsaver via Core-talk
RE: Git push problem Mark Rivers via Core-talk
Prev: RE: Git push problem Mark Rivers via Core-talk
Next: Re: Git push problem Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
