2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: AW: Long PV names in EPICS base
From: "Zimoch Dirk \(PSI\) via Core-talk" <core-talk at aps.anl.gov>
To: Simon Rose <Simon.Rose at ess.eu>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 14 Jan 2022 09:29:11 +0000
Programs assuming that PVNAME_STRINGSZ is always enough memory to store a record name unchecked may get buffer overruns.
Von: Core-talk <core-talk-bounces at aps.anl.gov> Im Auftrag von Simon Rose via Core-talk
Gesendet: Freitag, 14. Januar 2022 09:32
An: AppVeyor via Core-talk <core-talk at aps.anl.gov>
Betreff: Long PV names in EPICS base
Hi all -
Suppose that we wanted to allow EPICS to have longer PV names than the default 60 characters. It seems that this is possible by modifying two files:
  • PVNAME_STRINGSZ in modules/libcom/src/misc/dbDefs.h
  • The “Record Name” field in modules/database/src/ioc/db/dbCommon.dbd.pod
If you modify these two locations, then you can have records with PVs whose names are longer. ca/pvget/put seem to work find regardless, so this seems like a very simple change. However…
Is there anything else that is missing that would need to be changed here? In particular, I wonder if there are any concerns with linking records to each other, or any other unexpected consequences.
______________________
Simon Rose
Software Engineer
Control System Software and Services
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 72 179 23 07
E-mail: simon.rose at ess.eu
signature_601184643
AW: Long PV names in EPICS base Zimoch Dirk (PSI) via Core-talk
Long PV names in EPICS base Simon Rose via Core-talk
Prev: Long PV names in EPICS base Simon Rose via Core-talk
Next: AW: Long PV names in EPICS base Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
