I mean : If not recompiled. E.g., not your program but some user's who brought the compiled program with them.
Programs assuming that PVNAME_STRINGSZ is always enough memory to store a record name unchecked may get buffer overruns.
Inside the IOC, most things should work [TM].
Channel Access clients need to remember they have to use "long string" type (arrays of byte) when such names are part of the data. (E.g., when setting link fields.)
Other external applications to check include: Operator Interface Alarm handling Archive engines Archive retrieval Development environment Configuration management / databases Directory services (ChannelFinder etc.)
Cheers, ~Ralph
- Long PV names in EPICS base Simon Rose via Core-talk
- AW: Long PV names in EPICS base Zimoch Dirk (PSI) via Core-talk
Build failed: EPICS Base 7 base-7.0-457 AppVeyor via Core-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 14 Sep 2022 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
