See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/287/display/redirect?page=changes>
Changes:
[Michael Davidsaver] Com: clear IP_MULTICAST_ALL on Linux
[dirk.zimoch] extend link test to hex numbers
[dirk.zimoch] mention hex numbers for HW links in release notes
[Michael Davidsaver] ca: silence warning
[Michael Davidsaver] Com: avoid implicit use of epicsStdio in posix epicsThread.c
[Michael Davidsaver] Com: posix warn of use of epicsThread from child after fork()
[dirk.zimoch] Make sure epicsInt8 is signed on all architectures
[Andrew Johnson] Merge Heinz & Andrew's rtems-osd-event branch into 7.0
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/ws/>
The recommended git tool is: NONE
No credentials specified
> C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\epics-base-7.0-win64\.git # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Using shallow fetch with depth 5
Fetching upstream changes from https://git.launchpad.net/epics-base
> C:/Program Files/Git/cmd/git.exe --version # timeout=10
> git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files/Git/cmd/git.exe fetch --no-tags --force --progress --depth=5 -- https://git.launchpad.net/epics-base +refs/heads/7.0:refs/remotes/origin/7.0 # timeout=10
> C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/7.0^{commit}" # timeout=10
Checking out Revision 7cb80d5a179bdaf9c857436f9f428bf2020c3fb4 (refs/remotes/origin/7.0)
> C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
> C:/Program Files/Git/cmd/git.exe checkout -f 7cb80d5a179bdaf9c857436f9f428bf2020c3fb4 # timeout=10
Commit message: "Merge Dirk's fix_epicsInt8 branch into 7.0"
> C:/Program Files/Git/cmd/git.exe rev-list --no-walk 1c3aa018464136a1d0f546ab4ed0b950610ae58e # timeout=10
Cleaning workspace
> C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
> C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
[epics-base-7.0-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins4101218339465146110.bat
jenkins@JEEVES C:\jenkins\win64-2\workspace\epics-base-7.0-win64>make -j4 -O --no-print-directory
'make' is not recognized as an internal or external command,
operable program or batch file.
jenkins@JEEVES C:\jenkins\win64-2\workspace\epics-base-7.0-win64>exit 9009
Build step 'Execute Windows batch command' marked build as failure
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Build failed: EPICS Base 7 base-7.0-460 AppVeyor via Core-talk
epics-7.0 » linux64 - Build # 378 - Failure! APS Jenkins via Core-talk
<2022>
2025
2026
<2022>
2025
2026
