2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: epics-7.0 » linux64 - Build # 378 - Failure!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 24 Jan 2022 14:31:59 -0600 (CST)
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/378/
This job failed to build.
Started by upstream project "epics-7.0" build number 378
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on the built-in node in workspace /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/.git # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > git --version # timeout=10
 > git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10
Checking out Revision 7cb80d5a179bdaf9c857436f9f428bf2020c3fb4 (refs/remotes/origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 7cb80d5a179bdaf9c857436f9f428bf2020c3fb4 # timeout=10
Commit message: "Merge Dirk's fix_epicsInt8 branch into 7.0"
 > git rev-list --no-walk 1c3aa018464136a1d0f546ab4ed0b950610ae58e # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
 > git submodule foreach --recursive git reset --hard # timeout=10
 > git submodule foreach git clean -fdx # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
 > git submodule update modules/pvData # timeout=10
 > git submodule update modules/pvAccess # timeout=10
 > git submodule update modules/normativeTypes # timeout=10
 > git submodule update modules/pvaClient # timeout=10
 > git submodule update modules/pvDatabase # timeout=10
 > git submodule update modules/pva2pva # timeout=10
 > git submodule update .ci # timeout=10
No emails were triggered.
[linux64] $ /bin/sh -xe /tmp/jenkins8122380138370473022.sh
+ git submodule foreach 'git checkout master && git pull'
Entering '.ci'
Already on 'master'
Your branch is up-to-date with 'origin/master'.
>From https://github.com/epics-base/ci-scripts
   75bae77..93062ba  master     -> origin/master
Updating 75bae77..93062ba
Fast-forward
 .appveyor.yml                       | 3 ---
 README.md                           | 2 +-
 appveyor/.appveyor.yml.example-full | 3 ---
 appveyor/.appveyor.yml.example-mini | 2 --
 appveyor/README.md                  | 4 ++--
 cue-test.py                         | 2 +-
 cue.py                              | 1 +
 test01.set                          | 2 +-
 8 files changed, 6 insertions(+), 13 deletions(-)
Entering 'modules/normativeTypes'
Already on 'master'
Already up-to-date.
Entering 'modules/pvAccess'
Previous HEAD position was 284de4f... Set next development version
Switched to branch 'master'
Already up-to-date.
Entering 'modules/pvData'
Already on 'master'
Already up-to-date.
Entering 'modules/pvDatabase'
Already on 'master'
>From https://github.com/epics-base/pvDatabaseCPP
   0cf7065..05d54c6  master     -> origin/master
Updating 0cf7065..05d54c6
Fast-forward
 documentation/RELEASE_NOTES.md |  6 ++++++
 src/copy/pvCopy.cpp            | 16 ++++++++++++----
 src/database/pvRecord.cpp      |  5 ++++-
 test/src/testPVCopy.cpp        | 39 ++++++++++++++++++++++++++++++++++++++-
 4 files changed, 60 insertions(+), 6 deletions(-)
Entering 'modules/pva2pva'
Previous HEAD position was 61ec071... Set next development version
Already up-to-date.
Entering 'modules/pvaClient'
Already on 'master'
Already up-to-date.
+ csac=configure/os/CONFIG_SITE.linux-x86_64.Common
+ echo 'CROSS_COMPILER_TARGET_ARCHS :='
+ case $EPICS_HOST_ARCH in
+ echo 'CROSS_COMPILER_TARGET_ARCHS += vxWorks-ppc32'
+ echo 'CROSS_COMPILER_TARGET_ARCHS += vxWorks-ppc32sf'
+ echo 'CROSS_COMPILER_TARGET_ARCHS += RTEMS-uC5282'
+ echo 'RTEMS_VERSION = 4.10.2'
+ echo 'RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)'
+ EXTRA='-j4 -Orecurse'
+ echo ------------------------------------------------------------------
+ /Jenkins/jenkins/bin/make -j4 -Orecurse host
/Jenkins/jenkins/bin/make -C ./configure install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure'
perl -CSD ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD ../src/tools/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD ../src/tools/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD ../src/tools/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.linux-x86_64'
/usr/bin/gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.linux-x86_64.linux-x86_64
Installing CFG file ../../cfg/TOOLCHAIN.linux-x86_64.linux-x86_64
mkdir ../../cfg
Installing CFG file ../../cfg/CONFIG_LIBCOM_VERSION
Installing CFG file ../../cfg/CONFIG_CA_VERSION
Installing CFG file ../../cfg/CONFIG_LIBCOM_MODULE
Installing CFG file ../../cfg/CONFIG_CA_MODULE
Installing CFG file ../../cfg/CONFIG_DATABASE_MODULE
Installing CFG file ../../cfg/CONFIG_DATABASE_VERSION
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.linux-x86_64'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src'
/Jenkins/jenkins/bin/make -C ./tools install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.linux-x86_64 ../../..
perl -CSD ../../src/tools/makeMakefile.pl O.vxWorks-ppc32sf ../../..
mkdir -p O.Common
perl -CSD ../../src/tools/makeMakefile.pl O.RTEMS-uC5282 ../../..
perl -CSD ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
mkdir ../../../lib
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
mkdir ../../../lib
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodXHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o makeAPIheader.html ../makeAPIheader.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podToHtml.html ../podToHtml.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podRemove.html ../podRemove.pl
Installing script ../../../bin/linux-x86_64/convertRelease.pl
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64
Installing script ../../../bin/linux-x86_64/assembleSnippets.pl
mkdir ../../../bin
Installing script ../../../bin/linux-x86_64/depclean.pl
Installing script ../../../bin/linux-x86_64/cvsclean.pl
Installing script ../../../bin/linux-x86_64/epicsProve.pl
Installing script ../../../bin/linux-x86_64/dos2unix.pl
Installing script ../../../bin/linux-x86_64/fullPathName.pl
Installing script ../../../bin/linux-x86_64/expandVars.pl
Installing script ../../../bin/linux-x86_64/installEpics.pl
Installing script ../../../bin/linux-x86_64/makeAPIheader.pl
Installing script ../../../bin/linux-x86_64/makeMakefile.pl
Installing script ../../../bin/linux-x86_64/makeTestfile.pl
Installing script ../../../bin/linux-x86_64/mkmf.pl
Installing script ../../../bin/linux-x86_64/munch.pl
Installing script ../../../bin/linux-x86_64/podToHtml.pl
Installing script ../../../bin/linux-x86_64/podRemove.pl
Installing script ../../../bin/linux-x86_64/replaceVAR.pl
Installing script ../../../bin/linux-x86_64/tap-to-junit-xml.pl
Installing script ../../../bin/linux-x86_64/testFailures.pl
Installing script ../../../bin/linux-x86_64/useManifestTool.pl
Installing script ../../../bin/linux-x86_64/genVersionHeader.pl
Installing script ../../../bin/linux-x86_64/makeRPath.py
Installing generated html ../../../html/./EPICS/Getopts.html
mkdir ../../../html/./EPICS
Installing generated html ../../../html/./EPICS/Path.html
Installing generated html ../../../html/./EPICS/Readfile.html
Installing generated html ../../../html/./fullPathName.html
Installing generated html ../../../html/./makeAPIheader.html
Installing generated html ../../../html/./munch.html
Installing generated html ../../../html/./podRemove.html
Installing generated html ../../../html/./podToHtml.html
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools'
/Jenkins/jenkins/bin/make -C template/base install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../..
mkdir -p O.Common
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseApp.pl
Installing ../../../../templates/makeBaseApp/top/Makefile
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../../templates/makeBaseApp/top/configure
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base'
/Jenkins/jenkins/bin/make -C template/ext install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseExt.pl
Installing ../../../../templates/makeBaseExt/top/README
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
Installing ../../../../templates/makeBaseExt/top/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE
mkdir ../../../../templates/makeBaseExt/top/configure
Installing ../../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
mkdir ../../../../templates/makeBaseExt/top/configure/os
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
Installing ../../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../../templates/makeBaseExt/top/src
Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/exampleExt
Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src'
/Jenkins/jenkins/bin/make -C ./test install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test'
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../.. -a linux-x86_64 ../Snippets.plt Snippets.t
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test'
/Jenkins/jenkins/bin/make -C ./modules install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules'
Creating RELEASE.linux-x86_64.local with
    EPICS_BASE = /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/Jenkins/jenkins/bin/make -C ./libcom install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.linux-x86_64'
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD ../misc/makeEpicsVersion.pl -o epicsVersion.h   ../../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 7.0.6.2-DEV
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeAPIheader.pl -o ../O.Common/libComAPI.h libCom
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
Installing created executable ../../../../bin/linux-x86_64/bldEnvData.pl
Installing generated generic include file ../../../../include/libComAPI.h
mkdir ../../../../include
perl -CSD ../../../../bin/linux-x86_64/bldEnvData.pl  -t linux-x86_64 \
	-c gcc -s Linux ../../../../configure
Generating envData.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_lex.d  ../yajl/yajl_lex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_encode.d  ../yajl/yajl_encode.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_gen.d  ../yajl/yajl_gen.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl.d  ../yajl/yajl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_parser.d  ../yajl/yajl_parser.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_buf.d  ../yajl/yajl_buf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_alloc.d  ../yajl/yajl_alloc.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueuePassive.d  ../timer/timerQueuePassive.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueueActiveMgr.d  ../timer/timerQueueActiveMgr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueueActive.d  ../timer/timerQueueActive.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueue.d  ../timer/timerQueue.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsRingBytes.d  ../ring/epicsRingBytes.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimer.d  ../timer/epicsTimer.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF taskwd.d  ../taskwd/taskwd.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsRingPointer.d  ../ring/epicsRingPointer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timer.d  ../timer/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdBackTrace.d  ../osi/os/Linux/osdBackTrace.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF threadPool.d  ../pool/threadPool.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF poolJob.d  ../pool/poolJob.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF devLibVMEOSD.d  ../osi/os/default/devLibVMEOSD.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStackTrace.d  ../osi/epicsStackTrace.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF devLibVME.d  ../osi/devLibVME.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdgetexec.d  ../osi/os/Linux/osdgetexec.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdFindAddr.d  ../osi/os/Linux/osdFindAddr.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMessageQueue.d  ../osi/os/default/osdMessageQueue.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMonotonic.d  ../osi/os/posix/osdMonotonic.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdProcess.d  ../osi/os/posix/osdProcess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdEvent.d  ../osi/os/posix/osdEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSpin.d  ../osi/os/posix/osdSpin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdNetIntf.d  ../osi/os/Linux/osdNetIntf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMutex.d  ../osi/os/posix/osdMutex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThreadHooks.d  ../osi/os/default/osdThreadHooks.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdTime.d  ../osi/os/posix/osdTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdStdio.d  ../osi/os/posix/osdStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdio.d  ../osi/epicsStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThread.d  ../osi/os/posix/osdThread.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTempFile.d  ../osi/os/posix/epicsTempFile.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThreadExtra.d  ../osi/os/Linux/osdThreadExtra.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSignal.d  ../osi/os/posix/osdSignal.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdPoolStatus.d  ../osi/os/default/osdPoolStatus.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdEnv.d  ../osi/os/default/osdEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE   -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsReadline.d  ../osi/epicsReadline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdFindSymbol.d  ../osi/os/posix/osdFindSymbol.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdInterrupt.d  ../osi/os/default/osdInterrupt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdAssert.d  ../osi/os/default/osdAssert.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSocketConvertErrnoToString.d  ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF systemCallIntMech.d  ../osi/os/posix/systemCallIntMech.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiSock.d  ../osi/osiSock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSockUnsentCount.d  ../osi/os/Linux/osdSockUnsentCount.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSockAddrReuse.d  ../osi/os/default/osdSockAddrReuse.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiClockTime.d  ../osi/osiClockTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSock.d  ../osi/os/posix/osdSock.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMath.d  ../osi/epicsMath.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMessageQueue.d  ../osi/epicsMessageQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAtomicOSD.d  ../osi/os/posix/epicsAtomicOSD.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsGeneralTime.d  ../osi/epicsGeneralTime.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEvent.d  ../osi/epicsEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMutex.d  ../osi/epicsMutex.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsUnitTest.d  ../misc/epicsUnitTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTime.d  ../osi/epicsTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF truncateFile.d  ../misc/truncateFile.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThread.d  ../osi/epicsThread.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsString.d  ../misc/epicsString.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdlib.d  ../misc/epicsStdlib.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ipAddrToAsciiAsynchronous.d  ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsConvert.d  ../misc/epicsConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsExit.d  ../misc/epicsExit.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF alarmString.d  ../misc/alarmString.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF adjustment.d  ../misc/adjustment.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cantProceed.d  ../misc/cantProceed.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF aToIPAddr.d  ../misc/aToIPAddr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macUtil.d  ../macLib/macUtil.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macCore.d  ../macLib/macCore.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macEnv.d  ../macLib/macEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocLog.d  ../log/iocLog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF registry.d  ../iocsh/registry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF logClient.d  ../log/logClient.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF libComRegister.d  ../iocsh/libComRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF initHooks.d  ../iocsh/initHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF gpHashLib.d  ../gpHash/gpHashLib.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocsh.d  ../iocsh/iocsh.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errSymTbl.d  errSymTbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF freeListLib.d  ../freeList/freeListLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errSymLib.d  ../error/errSymLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF envData.d  envData.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errlog.d  ../error/errlog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ellSort.d  ../ellLib/ellSort.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ellLib.d  ../ellLib/ellLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF envSubr.d  ../env/envSubr.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF fdManager.d  ../fdmgr/fdManager.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF fdmgr.d  ../fdmgr/fdmgr.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF dbmf.d  ../dbmf/dbmf.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF resourceLib.d  ../cxxTemplates/resourceLib.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSingletonMutex.d  ../cxxTemplates/epicsSingletonMutex.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cvtFast.d  ../cvtFast/cvtFast.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF bucketLib.d  ../bucketLib/bucketLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF calcPerform.d  ../calc/calcPerform.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF postfix.d  ../calc/postfix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF asTrapWrite.d  ../as/asTrapWrite.c
Installing generic include file ../../../../include/valgrind/valgrind.h
mkdir ../../../../include/valgrind
Installing generated generic include file ../../../../include/libComVersion.h
Installing generic include file ../../../../include/asLib.h
Installing generic include file ../../../../include/asTrapWrite.h
Installing generic include file ../../../../include/bucketLib.h
Installing generic include file ../../../../include/postfix.h
Installing generic include file ../../../../include/cvtFast.h
Installing generic include file ../../../../include/epicsAlgorithm.h
Installing generic include file ../../../../include/resourceLib.h
Installing generic include file ../../../../include/tsDLList.h
Installing generic include file ../../../../include/tsSLList.h
Installing generic include file ../../../../include/tsFreeList.h
Installing generic include file ../../../../include/epicsSingleton.h
Installing generic include file ../../../../include/tsMinMax.h
Installing generic include file ../../../../include/epicsGuard.h
Installing generic include file ../../../../include/ellLib.h
Installing generic include file ../../../../include/dbmf.h
Installing generic include file ../../../../include/envDefs.h
Installing generic include file ../../../../include/epicsPrint.h
Installing generic include file ../../../../include/errMdef.h
Installing generic include file ../../../../include/errSymTbl.h
Installing generic include file ../../../../include/errlog.h
Installing generic include file ../../../../include/fdManager.h
Installing generic include file ../../../../include/fdmgr.h
Installing generic include file ../../../../include/flex.skel.static
Installing generic include file ../../../../include/freeList.h
Installing generic include file ../../../../include/gpHash.h
Installing generic include file ../../../../include/iocsh.h
Installing generic include file ../../../../include/initHooks.h
Installing generic include file ../../../../include/registry.h
Installing generic include file ../../../../include/libComRegister.h
Installing generic include file ../../../../include/iocLog.h
Installing generic include file ../../../../include/logClient.h
Installing generic include file ../../../../include/macLib.h
Installing generic include file ../../../../include/alarm.h
Installing generic include file ../../../../include/alarmString.h
Installing generic include file ../../../../include/adjustment.h
Installing generic include file ../../../../include/cantProceed.h
Installing generic include file ../../../../include/dbDefs.h
Installing generic include file ../../../../include/epicsConvert.h
Installing generic include file ../../../../include/epicsExit.h
Installing generic include file ../../../../include/epicsStdlib.h
Installing generic include file ../../../../include/epicsString.h
Installing generic include file ../../../../include/epicsTypes.h
Installing generic include file ../../../../include/shareLib.h
Installing generic include file ../../../../include/epicsExport.h
Installing generic include file ../../../../include/locationException.h
Installing generic include file ../../../../include/ipAddrToAsciiAsynchronous.h
Installing generic include file ../../../../include/compilerDependencies.h
Installing generic include file ../../../../include/epicsUnitTest.h
Installing generic include file ../../../../include/testMain.h
Installing generated generic include file ../../../../include/epicsVersion.h
Installing generic include file ../../../../include/osiFileName.h
Installing generic include file ../../../../include/osiSock.h
Installing compiler dependent include file ../../../../include/compiler/gcc/compilerSpecific.h
mkdir ../../../../include/compiler
mkdir ../../../../include/compiler/gcc
Installing generic include file ../../../../include/epicsInterrupt.h
Installing OS dependent include file ../../../../include/os/Linux/osdSock.h
mkdir ../../../../include/os
mkdir ../../../../include/os/Linux
Installing generic include file ../../../../include/epicsMutex.h
Installing OS dependent include file ../../../../include/os/Linux/osdInterrupt.h
Installing OS dependent include file ../../../../include/os/Linux/osdMutex.h
Installing generic include file ../../../../include/epicsSpin.h
Installing generic include file ../../../../include/epicsEvent.h
Installing OS dependent include file ../../../../include/os/Linux/osdEvent.h
Installing OS dependent include file ../../../../include/os/Linux/epicsMath.h
Installing OS dependent include file ../../../../include/os/Linux/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/Linux/osdStrtod.h
Installing generic include file ../../../../include/epicsAssert.h
Installing generic include file ../../../../include/epicsFindSymbol.h
Installing generic include file ../../../../include/osiPoolStatus.h
Installing OS dependent include file ../../../../include/os/Linux/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/Linux/osdThread.h
Installing generic include file ../../../../include/epicsThread.h
Installing generic include file ../../../../include/epicsTime.h
Installing generic include file ../../../../include/epicsGeneralTime.h
Installing OS dependent include file ../../../../include/os/Linux/osdTime.h
Installing generic include file ../../../../include/generalTimeSup.h
Installing generic include file ../../../../include/osiClockTime.h
Installing generic include file ../../../../include/epicsSignal.h
Installing generic include file ../../../../include/osiProcess.h
Installing OS dependent include file ../../../../include/os/Linux/osiUnistd.h
Installing generic include file ../../../../include/osiWireFormat.h
Installing OS dependent include file ../../../../include/os/Linux/osdWireConfig.h
Installing OS dependent include file ../../../../include/os/Linux/osdWireFormat.h
Installing generic include file ../../../../include/epicsAtomic.h
Installing generic include file ../../../../include/epicsAtomicDefault.h
Installing OS dependent include file ../../../../include/os/Linux/epicsAtomicOSD.h
Installing compiler dependent include file ../../../../include/compiler/gcc/epicsAtomicCD.h
Installing generic include file ../../../../include/epicsEndian.h
Installing generic include file ../../../../include/epicsReadline.h
Installing generic include file ../../../../include/epicsMessageQueue.h
Installing generic include file ../../../../include/epicsStdio.h
Installing generic include file ../../../../include/epicsStdioRedirect.h
Installing generic include file ../../../../include/epicsTempFile.h
Installing OS dependent include file ../../../../include/os/Linux/epicsGetopt.h
Installing generic include file ../../../../include/epicsStackTrace.h
Installing generic include file ../../../../include/devLib.h
Installing generic include file ../../../../include/devLibVME.h
Installing generic include file ../../../../include/devLibVMEImpl.h
Installing OS dependent include file ../../../../include/os/Linux/osdVME.h
Installing OS dependent include file ../../../../include/os/Linux/epicsMMIO.h
Installing generic include file ../../../../include/epicsAtomicGCC.h
Installing OS dependent include file ../../../../include/os/Linux/epicsMMIODef.h
Installing generic include file ../../../../include/epicsThreadPool.h
Installing generic include file ../../../../include/epicsRingPointer.h
Installing generic include file ../../../../include/taskwd.h
Installing generic include file ../../../../include/epicsRingBytes.h
Installing generic include file ../../../../include/epicsTimer.h
Installing generic include file ../../../../include/yajl_alloc.h
Installing generic include file ../../../../include/yajl_common.h
Installing generic include file ../../../../include/yajl_parse.h
Installing generic include file ../../../../include/yajl_gen.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF verbose.d  ../yacc/verbose.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF warshall.d  ../yacc/warshall.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF symtab.d  ../yacc/symtab.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF skeleton.d  ../yacc/skeleton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF output.d  ../yacc/output.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF mkpar.d  ../yacc/mkpar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF antelope.d  ../yacc/antelope.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF reader.d  ../yacc/reader.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF lr0.d  ../yacc/lr0.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF lalr.d  ../yacc/lalr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF error.d  ../yacc/error.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF closure.d  ../yacc/closure.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF sym.d  ../flex/sym.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF tblcmp.d  ../flex/tblcmp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF nfa.d  ../flex/nfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocLogServer.d  ../log/iocLogServer.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF misc.d  ../flex/misc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF gen.d  ../flex/gen.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ecs.d  ../flex/ecs.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ccl.d  ../flex/ccl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF dfa.d  ../flex/dfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/ccl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/ecs.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/misc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/gen.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/nfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/dfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/sym.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/error.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/closure.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/tblcmp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/antelope.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/lr0.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/lalr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/mkpar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/skeleton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/symtab.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/verbose.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/warshall.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/output.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/reader.c
/usr/bin/g++ -o antelope  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o
Installing created executable ../../../../bin/linux-x86_64/antelope
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -bparse -l -d ../flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF parse.d  parse.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c parse.c
/usr/bin/g++ -o e_flex  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
Installing created executable ../../../../bin/linux-x86_64/e_flex
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF asLib.d  asLib.c
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm
Expanding ../log/S99logServer@ to S99logServer
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../log/S99logServer@ S99logServer
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../as/asTrapWrite.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../calc/postfix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../bucketLib/bucketLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../calc/calcPerform.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cxxTemplates/resourceLib.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cxxTemplates/epicsSingletonMutex.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../dbmf/dbmf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cvtFast/cvtFast.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ellLib/ellSort.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ellLib/ellLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c envData.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../env/envSubr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c asLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../error/errSymLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c errSymTbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../error/errlog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../freeList/freeListLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../gpHash/gpHashLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/initHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/registry.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/iocsh.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../fdmgr/fdmgr.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/libComRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../log/iocLog.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../fdmgr/fdManager.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLib/macEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/alarmString.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLib/macUtil.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../log/logClient.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLib/macCore.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/adjustment.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/aToIPAddr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/cantProceed.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsExit.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/truncateFile.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsStdlib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsString.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsUnitTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMutex.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMessageQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsThread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMath.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/epicsAtomicOSD.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/osiClockTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsGeneralTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSock.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsTime.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdSockAddrReuse.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdSockUnsentCount.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/systemCallIntMech.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/osiSock.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdFindSymbol.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdAssert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdPoolStatus.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdInterrupt.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSignal.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/epicsTempFile.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE   -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsReadline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdThreadExtra.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdThreadHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdMutex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSpin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdMonotonic.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdThread.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdProcess.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdgetexec.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdNetIntf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/devLibVMEOSD.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsStackTrace.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdBackTrace.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdMessageQueue.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/devLibVME.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../pool/poolJob.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdFindAddr.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ring/epicsRingPointer.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../pool/threadPool.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ring/epicsRingBytes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../taskwd/taskwd.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/epicsTimer.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueueActive.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_alloc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_buf.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueuePassive.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueueActiveMgr.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_encode.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_parser.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_gen.c
Installing created executable ../../../../bin/linux-x86_64/S99logServer
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_lex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../log/iocLogServer.c
/usr/bin/ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/usr/bin/ranlib libCom.a
/usr/bin/g++ -o libCom.so.3.21.1  -shared -fPIC -Wl,-hlibCom.so.3.21.1 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../../lib/linux-x86_64/libCom.so.3.21.1
ln -s libCom.so.3.21.1 ../../../../lib/linux-x86_64/libCom.so
Installing library ../../../../lib/linux-x86_64/libCom.a
/usr/bin/g++ -o iocLogServer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
Installing created executable ../../../../bin/linux-x86_64/iocLogServer
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src'
/Jenkins/jenkins/bin/make -C ./vxWorks install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../..
mkdir -p O.Common
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks/O.linux-x86_64'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks'
/Jenkins/jenkins/bin/make -C ./RTEMS install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS/O.linux-x86_64'
Installing generic include file ../../../../include/epicsMemFs.h
Installing generic include file ../../../../include/epicsNtp.h
Installing generic include file ../../../../include/epicsRtemsInitHooks.h
Installing script ../../../../bin/linux-x86_64/epicsMakeMemFs.pl
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS'
/Jenkins/jenkins/bin/make -C ./test install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF buckTest.d  ../buckTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF nonEpicsThreadPriorityTest.d  ../nonEpicsThreadPriorityTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAtomicPerform.d  ../epicsAtomicPerform.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMaxThreads.d  ../epicsMaxThreads.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cvtFastPerform.d  ../cvtFastPerform.cpp
INSTALL_LOCATION=../../../..
perl -CSD ../../../../modules/database/src/std/softIoc/makeInstallDir.pl "../../../.." > epicsInstallDir.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPerform.d  ../epicsThreadPerform.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_test.d  ../yajl_test.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF testexecname.d  ../testexecname.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocshTest.d  ../iocshTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiSockTest.d  ../osiSockTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStackTraceTest.d  ../epicsStackTraceTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ipAddrToAsciiTest.d  ../ipAddrToAsciiTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMessageQueueTest.d  ../epicsMessageQueueTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF taskwdTest.d  ../taskwdTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF aslibtest.d  ../aslibtest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macLibTest.d  ../macLibTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF blockingSockTest.d  ../blockingSockTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macDefExpandTest.d  ../macDefExpandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cvtFastTest.d  ../cvtFastTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAtomicTest.d  ../epicsAtomicTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSpinTest.d  ../epicsSpinTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMutexTest.d  ../epicsMutexTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ringBytesTest.d  ../ringBytesTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEventTest.d  ../epicsEventTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ringPointerTest.d  ../ringPointerTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF initHookTest.d  ../initHookTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsExitTest.d  ../epicsExitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPoolTest.d  ../epicsThreadPoolTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimerTest.d  ../epicsTimerTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadHooksTest.d  ../epicsThreadHooksTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadOnceTest.d  ../epicsThreadOnceTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPriorityTest.d  ../epicsThreadPriorityTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPrivateTest.d  ../epicsThreadPrivateTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadClassTest.d  ../epicsThreadClassTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimeZoneTest.d  ../epicsTimeZoneTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStringTest.d  ../epicsStringTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadTest.d  ../epicsThreadTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSockResolveTest.d  ../epicsSockResolveTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimeTest.d  ../epicsTimeTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdlibTest.d  ../epicsStdlibTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdioTest.d  ../epicsStdioTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEnvUnsetTest.d  ../epicsEnvUnsetTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEllTest.d  ../epicsEllTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEnvTest.d  ../epicsEnvTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsErrlogTest.d  ../epicsErrlogTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMathTest.d  ../epicsMathTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMMIOTest.d  ../epicsMMIOTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAlgorithmTest.d  ../epicsAlgorithmTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest4.d  ../epicsInlineTest4.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest3.d  ../epicsInlineTest3.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest1.d  ../epicsInlineTest1.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsCalcTest.d  ../epicsCalcTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest2.d  ../epicsInlineTest2.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTypesTest.d  ../epicsTypesTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsUnitTestTest.d  ../epicsUnitTestTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DBUILDING_SHARED_LIBRARIES    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsLoadTest.d  ../epicsLoadTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsUnitTestTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTypesTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest2.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest1.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest3.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest4.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMathTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsAlgorithmTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMMIOTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEnvUnsetTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEnvTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEllTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStdioTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsSockResolveTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsErrlogTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsCalcTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStdlibTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTimeZoneTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStringTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadOnceTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadClassTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPriorityTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTimeTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../initHookTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPrivateTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadHooksTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsExitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPoolTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ringBytesTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ringPointerTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsSpinTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEventTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTimerTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macDefExpandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLibTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsAtomicTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../aslibtest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../taskwdTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMutexTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../blockingSockTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStackTraceTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMessageQueueTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../testexecname.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ipAddrToAsciiTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osiSockTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl_test.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DBUILDING_SHARED_LIBRARIES    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsLoadTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cvtFastTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../buckTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMaxThreads.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocshTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPerform.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../nonEpicsThreadPriorityTest.cpp
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -a linux-x86_64 ../epicsUnitTestTest.plt epicsUnitTestTest.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -a linux-x86_64 ../macLib.plt macLib.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -a linux-x86_64 ../yajlTest.plt yajlTest.t
/usr/bin/g++ -o epicsUnitTestTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsUnitTestTest.o    -lCom
/usr/bin/g++ -o epicsTypesTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTypesTest.o    -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cvtFastPerform.cpp
/usr/bin/g++ -o epicsInlineTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsInlineTest1.o epicsInlineTest2.o epicsInlineTest3.o epicsInlineTest4.o    -lCom
/usr/bin/g++ -o epicsCalcTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsCalcTest.o    -lCom
/usr/bin/g++ -o epicsAlgorithmTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsAlgorithmTest.o    -lCom
/usr/bin/g++ -o epicsMathTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMathTest.o    -lCom
/usr/bin/g++ -o epicsMMIOTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMMIOTest.o    -lCom
/usr/bin/g++ -o epicsEllTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEllTest.o    -lCom
/usr/bin/g++ -o epicsEnvTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEnvTest.o    -lCom
/usr/bin/g++ -o epicsEnvUnsetTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEnvUnsetTest.o    -lCom
/usr/bin/g++ -o epicsErrlogTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsErrlogTest.o    -lCom
/usr/bin/g++ -o epicsStdioTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStdioTest.o    -lCom
/usr/bin/g++ -o epicsStdlibTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStdlibTest.o    -lCom
/usr/bin/g++ -o epicsSockResolveTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsSockResolveTest.o    -lCom
/usr/bin/g++ -o epicsStringTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStringTest.o    -lCom
/usr/bin/g++ -o epicsTimeTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTimeTest.o    -lCom
/usr/bin/g++ -o epicsTimeZoneTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTimeZoneTest.o    -lCom
/usr/bin/g++ -o epicsThreadTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadTest.o    -lCom
/usr/bin/g++ -o epicsThreadClassTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadClassTest.o    -lCom
/usr/bin/g++ -o epicsThreadOnceTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadOnceTest.o    -lCom
/usr/bin/g++ -o epicsThreadPriorityTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPriorityTest.o    -lCom
/usr/bin/g++ -o epicsThreadPrivateTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPrivateTest.o    -lCom
/usr/bin/g++ -o epicsThreadHooksTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadHooksTest.o    -lCom
/usr/bin/g++ -o epicsThreadPoolTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPoolTest.o    -lCom
/usr/bin/g++ -o initHookTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         initHookTest.o    -lCom
/usr/bin/g++ -o epicsExitTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsExitTest.o    -lCom
/usr/bin/g++ -o epicsTimerTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTimerTest.o    -lCom
/usr/bin/g++ -o ringPointerTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ringPointerTest.o    -lCom
/usr/bin/g++ -o ringBytesTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ringBytesTest.o    -lCom
/usr/bin/g++ -o epicsEventTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEventTest.o    -lCom
/usr/bin/g++ -o epicsMutexTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMutexTest.o    -lCom
/usr/bin/g++ -o epicsSpinTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsSpinTest.o    -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsAtomicPerform.cpp
/usr/bin/g++ -o epicsAtomicTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsAtomicTest.o    -lCom
/usr/bin/g++ -o macDefExpandTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         macDefExpandTest.o    -lCom
/usr/bin/g++ -o cvtFastTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         cvtFastTest.o    -lCom
/usr/bin/g++ -o macLibTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         macLibTest.o    -lCom
/usr/bin/g++ -o aslibtest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         aslibtest.o    -lCom
/usr/bin/g++ -o taskwdTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         taskwdTest.o    -lCom
/usr/bin/g++ -o blockingSockTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         blockingSockTest.o    -lCom
/usr/bin/g++ -o epicsMessageQueueTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMessageQueueTest.o    -lCom
/usr/bin/g++ -o epicsStackTraceTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStackTraceTest.o    -lCom
/usr/bin/g++ -o ipAddrToAsciiTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ipAddrToAsciiTest.o    -lCom
/usr/bin/g++ -o osiSockTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         osiSockTest.o    -lCom
/usr/bin/g++ -o testexecname  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testexecname.o    -lCom
/usr/bin/g++ -o yajl_test  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         yajl_test.o    -lCom
/usr/bin/g++ -o iocshTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         iocshTest.o    -lCom
/usr/bin/g++ -o epicsLoadTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsLoadTest.o    -lCom
/usr/bin/g++ -o epicsThreadPerform  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPerform.o    -lCom
/usr/bin/g++ -o epicsMaxThreads  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMaxThreads.o    -lCom
/usr/bin/g++ -o buckTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         buckTest.o    -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTypesTest.t epicsTypesTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsInlineTest.t epicsInlineTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsCalcTest.t epicsCalcTest
/usr/bin/g++ -o epicsAtomicPerform  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsAtomicPerform.o    -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsAlgorithmTest.t epicsAlgorithmTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMathTest.t epicsMathTest
/usr/bin/g++ -o nonEpicsThreadPriorityTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         nonEpicsThreadPriorityTest.o    -lCom  -lpthread
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEllTest.t epicsEllTest
/usr/bin/g++ -o cvtFastPerform  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         cvtFastPerform.o    -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMMIOTest.t epicsMMIOTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEnvTest.t epicsEnvTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEnvUnsetTest.t epicsEnvUnsetTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsErrlogTest.t epicsErrlogTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStdioTest.t epicsStdioTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStdlibTest.t epicsStdlibTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStringTest.t epicsStringTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsSockResolveTest.t epicsSockResolveTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTimeZoneTest.t epicsTimeZoneTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTimeTest.t epicsTimeTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadTest.t epicsThreadTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadClassTest.t epicsThreadClassTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadPriorityTest.t epicsThreadPriorityTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadOnceTest.t epicsThreadOnceTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadPrivateTest.t epicsThreadPrivateTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadHooksTest.t epicsThreadHooksTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadPoolTest.t epicsThreadPoolTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 initHookTest.t initHookTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsExitTest.t epicsExitTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTimerTest.t epicsTimerTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ringBytesTest.t ringBytesTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ringPointerTest.t ringPointerTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEventTest.t epicsEventTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMutexTest.t epicsMutexTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsSpinTest.t epicsSpinTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsAtomicTest.t epicsAtomicTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 macDefExpandTest.t macDefExpandTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 cvtFastTest.t cvtFastTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 taskwdTest.t taskwdTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 aslibtest.t aslibtest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 blockingSockTest.t blockingSockTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 macLibTest.t macLibTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ipAddrToAsciiTest.t ipAddrToAsciiTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMessageQueueTest.t epicsMessageQueueTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStackTraceTest.t epicsStackTraceTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 osiSockTest.t osiSockTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testexecname.t testexecname
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 iocshTest.t iocshTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsLoadTest.t epicsLoadTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 nonEpicsThreadPriorityTest.t nonEpicsThreadPriorityTest
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom'
/Jenkins/jenkins/bin/make -C ./ca install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src'
/Jenkins/jenkins/bin/make -C ./template install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../../..
mkdir -p O.Common
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template/O.linux-x86_64'
Installing ../../../../../templates/makeBaseApp/top/caClientApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caClientApp
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caExample.c
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caPerlApp
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/cainfo.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caget.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caput.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/camonitor.pl
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template'
/Jenkins/jenkins/bin/make -C ./client install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client/O.linux-x86_64'
Expanding ../caVersion.h@ to ../O.Common/caVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="2"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../caVersion.h@ caVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeAPIheader.pl -o ../O.Common/libCaAPI.h libCa
Installing generated generic include file ../../../../../include/libCaAPI.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caEventRateMain.d  ../caEventRateMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caConnTest.d  ../caConnTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caEventRate.d  ../caEventRate.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caConnTestMain.d  ../caConnTestMain.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF acctst.d  ../acctst.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF casw.d  ../casw.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF acctstMain.d  ../acctstMain.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF catime.d  ../catime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF catimeMain.d  ../catimeMain.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ca_test_main.d  ../test/ca_test_main.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ca_test.d  ../test/ca_test.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caRepeater.d  ../caRepeater.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF hostNameCache.d  ../hostNameCache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF comBuf.d  ../comBuf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF msgForMultiplyDefinedPV.d  ../msgForMultiplyDefinedPV.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF comQueSend.d  ../comQueSend.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF localHostName.d  ../localHostName.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF comQueRecv.d  ../comQueRecv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncGroupReadNotify.d  ../syncGroupReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncGroupWriteNotify.d  ../syncGroupWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncGroupNotify.d  ../syncGroupNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF putCallback.d  ../putCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncgrp.d  ../syncgrp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF CASG.d  ../CASG.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF getCallback.d  ../getCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF getCopy.d  ../getCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF oldSubscription.d  ../oldSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF oldChannelNotify.d  ../oldChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF bhe.d  ../bhe.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ca_client_context.d  ../ca_client_context.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tcpRecvWatchdog.d  ../tcpRecvWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tcpSendWatchdog.d  ../tcpSendWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netSubscription.d  ../netSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netWriteNotifyIO.d  ../netWriteNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF noopiiu.d  ../noopiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netReadNotifyIO.d  ../netReadNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tcpiiu.d  ../tcpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF udpiiu.d  ../udpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netiiu.d  ../netiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF baseNMIU.d  ../baseNMIU.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF nciu.d  ../nciu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF disconnectGovernorTimer.d  ../disconnectGovernorTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF repeaterSubscribeTimer.d  ../repeaterSubscribeTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF searchTimer.d  ../searchTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF repeater.d  ../repeater.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF test_event.d  ../test_event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF convert.d  ../convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF iocinf.d  ../iocinf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacStateNotify.d  ../cacStateNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF access.d  ../access.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacWriteNotify.d  ../cacWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacReadNotify.d  ../cacReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacChannelNotify.d  ../cacChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacContextNotify.d  ../cacContextNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacChannel.d  ../cacChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cac.d  ../cac.cpp
Installing generic include file ../../../../../include/cadef.h
Installing generic include file ../../../../../include/caerr.h
Installing generic include file ../../../../../include/caeventmask.h
Installing generic include file ../../../../../include/caProto.h
Installing generic include file ../../../../../include/db_access.h
Installing generic include file ../../../../../include/addrList.h
Installing generic include file ../../../../../include/cacIO.h
Installing generic include file ../../../../../include/caDiagnostics.h
Installing generic include file ../../../../../include/net_convert.h
Installing html ../../../../../html/./CAref.html
Expanding ../caRepeater.service@ to caRepeater.service
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -t ../../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="2"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../caRepeater.service@ caRepeater.service
Installing created executable ../../../../../bin/linux-x86_64/caRepeater.service
Expanding ../S99caRepeater@ to S99caRepeater
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -t ../../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="2"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../S99caRepeater@ S99caRepeater
Installing generated generic include file ../../../../../include/caVersion.h
Installing created executable ../../../../../bin/linux-x86_64/S99caRepeater
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacContextNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacStateNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../iocinf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../access.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../test_event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../repeater.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cac.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../disconnectGovernorTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../searchTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../baseNMIU.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../repeaterSubscribeTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../nciu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../noopiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../udpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netReadNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netWriteNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tcpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tcpSendWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tcpRecvWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../bhe.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../oldSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../ca_client_context.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../oldChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../getCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../putCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../getCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncgrp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../CASG.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncGroupNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../localHostName.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncGroupReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncGroupWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../comQueRecv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../comBuf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../hostNameCache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../comQueSend.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../msgForMultiplyDefinedPV.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../test/ca_test_main.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../test/ca_test.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caRepeater.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../catimeMain.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../catime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../acctstMain.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../acctst.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caConnTestMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caConnTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caEventRateMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../casw.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caEventRate.cpp
/usr/bin/ar -rc    libca.a     cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o
/usr/bin/ranlib libca.a
/usr/bin/g++ -o libca.so.4.14.2  -shared -fPIC -Wl,-hlibca.so.4.14.2 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64          cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../../../lib/linux-x86_64/libca.so.4.14.2
ln -s libca.so.4.14.2 ../../../../../lib/linux-x86_64/libca.so
Installing library ../../../../../lib/linux-x86_64/libca.a
/usr/bin/g++ -o ca_test  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ca_test_main.o ca_test.o    -lca -lCom -lca -lCom
/usr/bin/g++ -o caRepeater  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caRepeater.o    -lca -lCom
/usr/bin/g++ -o catime  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         catimeMain.o catime.o    -lca -lCom
/usr/bin/g++ -o acctst  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         acctstMain.o acctst.o    -lca -lCom
/usr/bin/g++ -o caConnTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caConnTestMain.o caConnTest.o    -lca -lCom
/usr/bin/g++ -o casw  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         casw.o    -lca -lCom
/usr/bin/g++ -o caEventRate  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caEventRateMain.o caEventRate.o    -lca -lCom
Installing created executable ../../../../../bin/linux-x86_64/ca_test
Installing created executable ../../../../../bin/linux-x86_64/catime
Installing created executable ../../../../../bin/linux-x86_64/acctst
Installing created executable ../../../../../bin/linux-x86_64/caConnTest
Installing created executable ../../../../../bin/linux-x86_64/casw
Installing created executable ../../../../../bin/linux-x86_64/caEventRate
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client'
/Jenkins/jenkins/bin/make -C ./tools install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools'
mkdir -p O.Common
    T_A=linux-x86_64 install
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caput.d  ../caput.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cainfo.d  ../cainfo.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF camonitor.d  ../camonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caget.d  ../caget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tool_lib.d  ../tool_lib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tool_lib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../camonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cainfo.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caput.c
/usr/bin/g++ -o caget  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caget.o tool_lib.o   -lca -lCom
/usr/bin/g++ -o camonitor  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         camonitor.o tool_lib.o   -lca -lCom
/usr/bin/g++ -o cainfo  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         cainfo.o tool_lib.o   -lca -lCom
/usr/bin/g++ -o caput  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caput.o tool_lib.o   -lca -lCom
Installing created executable ../../../../../bin/linux-x86_64/caget
Installing created executable ../../../../../bin/linux-x86_64/camonitor
Installing created executable ../../../../../bin/linux-x86_64/cainfo
Installing created executable ../../../../../bin/linux-x86_64/caput
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools'
/Jenkins/jenkins/bin/make -C ./perl install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl/O.linux-x86_64'
rm -f Cap5.c Cap5.c_new
perl -CSD /usr/bin/xsubpp -typemap /usr/share/perl5/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64   -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/usr/lib64/perl5/CORE     -MM -MF Cap5.d  Cap5.c
Installing PERL_MODULES file ../../../../../lib/perl/CA.pm
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64   -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/usr/lib64/perl5/CORE     -c Cap5.c
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -o CA.html ../CA.pm
Installing script ../../../../../bin/linux-x86_64/capr.pl
/usr/bin/g++ -o libCap5.so  -shared -fPIC -Wl,-hlibCap5.so -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         Cap5.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing generated html ../../../../../html/./CA.html
Installing loadable shared library ../../../../../lib/linux-x86_64/libCap5.so
Installing loadable shared library ../../../../../lib/perl/5.16.3/x86_64-linux-thread-multi/libCap5.so
mkdir ../../../../../lib/perl/5.16.3
mkdir ../../../../../lib/perl/5.16.3/x86_64-linux-thread-multi
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca'
/Jenkins/jenkins/bin/make -C ./database install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src'
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../../../lib/perl/DBD.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Base.pm
mkdir ../../../../../lib/perl/DBD
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Breaktable.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Device.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Driver.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Link.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Function.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Menu.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Output.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Parser.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recfield.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recordtype.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Record.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Registrar.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Variable.pm
Installing PERL_MODULES file ../../../../../lib/perl/EPICS/IOC.pm
Expanding ../epics-base.pc@ to epics-base.pc
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -DFINAL_LOCATION="/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64" -DOS_CLASS="Linux" -DCMPLR_CLASS="gcc" -DC_CFLAGS="-D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -mtune=generic -m64" -DLDFLAGS="-rdynamic -m64" -DLDLIBS="-lpthread -lreadline -lm -lrt -ldl -lgcc" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="2" -DCC="/usr/bin/gcc" -DCCC="/usr/bin/g++" -DCPP="/usr/bin/gcc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    ../epics-base.pc@ epics-base.pc
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -o IOC.html ../EPICS/IOC.pm
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -o dbdToHtml.html ../dbdToHtml.pl
Installing script ../../../../../bin/linux-x86_64/makeIncludeDbd.pl
Installing script ../../../../../bin/linux-x86_64/dbdToMenuH.pl
Installing script ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl
Installing script ../../../../../bin/linux-x86_64/dbdExpand.pl
Installing script ../../../../../bin/linux-x86_64/dbExpand.pl
Installing script ../../../../../bin/linux-x86_64/dbdToHtml.pl
Installing script ../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl
Expanding epics-base-linux-x86_64.pc@ to epics-base-linux-x86_64.pc
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -DFINAL_LOCATION="/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64" -DOS_CLASS="Linux" -DCMPLR_CLASS="gcc" -DC_CFLAGS="-D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -mtune=generic -m64" -DLDFLAGS="-rdynamic -m64" -DLDLIBS="-lpthread -lreadline -lm -lrt -ldl -lgcc" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="2" -DCC="/usr/bin/gcc" -DCCC="/usr/bin/g++" -DCPP="/usr/bin/gcc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    epics-base-linux-x86_64.pc@ epics-base-linux-x86_64.pc
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base.pc
mkdir ../../../../../lib/pkgconfig
Installing generated html ../../../../../html/./EPICS/IOC.html
Installing generated html ../../../../../html/./dbdToHtml.html
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base-linux-x86_64.pc
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools'
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template/O.linux-x86_64'
Installing ../../../../../templates/makeBaseApp/top/iocApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp
Installing ../../../../../templates/makeBaseApp/top/iocApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/Db
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/src
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/Db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/circle.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/_APPNAME_Version.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/src
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocBoot
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/iocBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template'
/Jenkins/jenkins/bin/make -C ./ioc install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc/O.linux-x86_64'
Expanding ../databaseVersion.h@ to ../O.Common/databaseVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../..   -DEPICS_DATABASE_MAJOR_VERSION="3"  -DEPICS_DATABASE_MINOR_VERSION="21"  -DEPICS_DATABASE_MAINTENANCE_VERSION="1"  -DEPICS_DATABASE_DEVELOPMENT_FLAG="1"  ../databaseVersion.h@ databaseVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuConvert.dbd ../bpt/menuConvert.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuAlarmSevr.dbd ../db/menuAlarmSevr.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuAlarmStat.dbd ../db/menuAlarmStat.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuFtype.dbd ../db/menuFtype.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuIvoa.dbd ../db/menuIvoa.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuOmsl.dbd ../db/menuOmsl.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuPini.dbd ../db/menuPini.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuPost.dbd ../db/menuPost.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuPriority.dbd ../db/menuPriority.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuYesNo.dbd ../db/menuYesNo.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuSimm.dbd ../db/menuSimm.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuScan.dbd ../db/menuScan.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o dbCommonRecord.dbd ../db/dbCommonRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeAPIheader.pl -o ../O.Common/dbCoreAPI.h dbCore
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/genVersionHeader.pl   -t ../../../../.. -N EPICS_VCS_VERSION -V "" ../O.Common/epicsVCS.h
Creating VCS header ../O.Common/epicsVCS.h
    EPICS_VCS_VERSION = "R7.0.6.1-59-g7cb80d5a179bdaf9c857-dirty"
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLoadTemplate_lex.c ../dbtemplate/dbLoadTemplate_lex.l
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLex.c ../dbStatic/dbLex.l
Global symbol "$warned" requires explicit package name at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/../../lib/perl/DBD/Breaktable.pm line 31.
Compilation failed in require at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/../../lib/perl/DBD.pm line 13.
BEGIN failed--compilation aborted at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/../../lib/perl/DBD.pm line 13.
Compilation failed in require at ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl line 16.
BEGIN failed--compilation aborted at ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl line 16.
Compilation failed in require at ../../../../../bin/linux-x86_64/dbdToMenuH.pl line 18.
BEGIN failed--compilation aborted at ../../../../../bin/linux-x86_64/dbdToMenuH.pl line 18.
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.h ../O.Common/menuConvert.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmSevr.h ../O.Common/menuAlarmSevr.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmStat.h ../O.Common/menuAlarmStat.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuFtype.h ../O.Common/menuFtype.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuIvoa.h ../O.Common/menuIvoa.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuOmsl.h ../O.Common/menuOmsl.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPini.h ../O.Common/menuPini.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPost.h ../O.Common/menuPost.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPriority.h ../O.Common/menuPriority.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuYesNo.h ../O.Common/menuYesNo.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuSimm.h ../O.Common/menuSimm.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuScan.h ../O.Common/menuScan.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I ../db  -I ../O.Common -o dbCommon.h ../O.Common/dbCommonRecord.dbd
Installing generated generic include file ../../../../../include/dbCoreAPI.h
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -bdbLoadTemplate  ../dbtemplate/dbLoadTemplate.y
mv dbLoadTemplate.tab.c dbLoadTemplate.c
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -bdbYacc  ../dbStatic/dbYacc.y
mv dbYacc.tab.c dbYacc.c
make[5]: *** No rule to make target '../O.Common/menuConvert.h', needed by 'inc'.  Stop.
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc/O.linux-x86_64'
../../../../configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[4]: *** [install.linux-x86_64] Error 2
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc'
../../../configure/RULES_DIRS:85: recipe for target 'ioc.install.linux-x86_64' failed
make[3]: *** [ioc.install.linux-x86_64] Error 2
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src'
../../configure/RULES_DIRS:85: recipe for target 'src.install.linux-x86_64' failed
make[2]: *** [src.install.linux-x86_64] Error 2
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database'
../configure/RULES_DIRS:85: recipe for target 'database.install.linux-x86_64' failed
make[1]: *** [database.install.linux-x86_64] Error 2
make[1]: *** Waiting for unfinished jobs....
/Jenkins/jenkins/bin/make -C ./pvData install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData'
/Jenkins/jenkins/bin/make -C ./configure install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/convertRelease.pl checkRelease
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_PVDATA_VERSION
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src/O.linux-x86_64'
mkdir -p ../O.Common/pv
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -DEPICS_PVD_MAJOR_VERSION="8" -DEPICS_PVD_MINOR_VERSION="0" -DEPICS_PVD_MAINTENANCE_VERSION="5" -DEPICS_PVD_DEVELOPMENT_FLAG="1" -t /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64    ../pv/pvdVersionNum.h@ ../O.Common/pv/pvdVersionNum.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF print.d  ../../src/json/print.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parseinto.d  ../../src/json/parseinto.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parseany.d  ../../src/json/parseany.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parsehelper.d  ../../src/json/parsehelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF requestmapper.d  ../../src/copy/requestmapper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF bitSetUtil.d  ../../src/pvMisc/bitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF createRequest.d  ../../src/copy/createRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvTimeStamp.d  ../../src/property/pvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF timeStamp.d  ../../src/property/timeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvEnumerated.d  ../../src/property/pvEnumerated.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvDisplay.d  ../../src/property/pvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvControl.d  ../../src/property/pvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF alarm.d  ../../src/property/alarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvAlarm.d  ../../src/property/pvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF printer.d  ../../src/factory/printer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF StandardField.d  ../../src/factory/StandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF StandardPVField.d  ../../src/factory/StandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF Compare.d  ../../src/factory/Compare.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvSubArrayCopy.d  ../../src/factory/pvSubArrayCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF Convert.d  ../../src/factory/Convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVDataCreateFactory.d  ../../src/factory/PVDataCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVUnionArray.d  ../../src/factory/PVUnionArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVUnion.d  ../../src/factory/PVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVStructureArray.d  ../../src/factory/PVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVStructure.d  ../../src/factory/PVStructure.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVScalarArray.d  ../../src/factory/PVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVArray.d  ../../src/factory/PVArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVScalar.d  ../../src/factory/PVScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVField.d  ../../src/factory/PVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF TypeFunc.d  ../../src/factory/TypeFunc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF FieldCreateFactory.d  ../../src/factory/FieldCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdVersion.d  ../../src/pv/pvdVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF valueBuilder.d  ../../src/pv/valueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF debugPtr.d  ../../src/misc/debugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF anyscalar.d  ../../src/misc/anyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF reftrack.d  ../../src/misc/reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvUnitTest.d  ../../src/misc/pvUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF thread.d  ../../src/misc/thread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parseToPOD.d  ../../src/misc/parseToPOD.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF typeCast.d  ../../src/misc/typeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF status.d  ../../src/misc/status.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF timer.d  ../../src/misc/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF event.d  ../../src/misc/event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF serializeHelper.d  ../../src/misc/serializeHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF epicsException.d  ../../src/misc/epicsException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF byteBuffer.d  ../../src/misc/byteBuffer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF bitSet.d  ../../src/misc/bitSet.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/noDefaultMethods.h
mkdir /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/lock.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/serialize.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/bitSet.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/byteBuffer.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/epicsException.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/serializeHelper.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/event.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/thread.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/timer.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/status.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/sharedPtr.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/debugPtr.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/typeCast.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/sharedVector.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/templateMeta.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/current_function.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvUnitTest.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/reftrack.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/anyscalar.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvType.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvIntrospect.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/valueBuilder.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvData.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/convert.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/standardField.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/standardPVField.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvSubArrayCopy.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/typemap.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdVersion.h
Installing generated generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdVersionNum.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/factory.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/alarm.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvAlarm.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/control.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvControl.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/display.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvDisplay.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvEnumerated.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/timeStamp.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvTimeStamp.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/createRequest.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/bitSetUtil.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/json.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/byteBuffer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/bitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/epicsException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/serializeHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/status.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/thread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/parseToPOD.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/debugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/pvUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/anyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pv/pvdVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/typeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pv/valueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/TypeFunc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVStructure.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/FieldCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVUnionArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/Convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/Compare.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/pvSubArrayCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/StandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/StandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/alarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/printer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVDataCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/timeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvEnumerated.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pvMisc/bitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/parsehelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/requestmapper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/parseany.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/createRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/print.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/parseinto.cpp
/usr/bin/ar -rc    libpvData.a     byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o
/usr/bin/ranlib libpvData.a
/usr/bin/g++ -o libpvData.so.8.0.5  -shared -fPIC -Wl,-hlibpvData.so.8.0.5 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64          byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o   -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvData.so.8.0.5
ln -s libpvData.so.8.0.5 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvData.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvData.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src'
/Jenkins/jenkins/bin/make -C ./examples install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
mkdir -p O.Common
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF unittest.d  ../unittest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../unittest.cpp
/usr/bin/g++ -o unittest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         unittest.o    -lpvData -lCom
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples'
/Jenkins/jenkins/bin/make -C ./testApp install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testCreateRequest.d  ../../testApp/copy/testCreateRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testValueBuilder.d  ../../testApp/pv/testValueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testProperty.d  ../../testApp/property/testProperty.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testFieldBuilder.d  ../../testApp/pv/testFieldBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testOperators.d  ../../testApp/pv/testOperators.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVStructureArray.d  ../../testApp/pv/testPVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVScalarArray.d  ../../testApp/pv/testPVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testConvert.d  ../../testApp/pv/testConvert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVUnion.d  ../../testApp/pv/testPVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVData.d  ../../testApp/pv/testPVData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testStandardPVField.d  ../../testApp/pv/testStandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testStandardField.d  ../../testApp/pv/testStandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVType.d  ../../testApp/pv/testPVType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testIntrospect.d  ../../testApp/pv/testIntrospect.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testBitSetUtil.d  ../../testApp/pv/testBitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testprinter.d  ../../testApp/misc/testprinter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testanyscalar.d  ../../testApp/misc/testanyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF test_reftrack.d  ../../testApp/misc/test_reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testjson.d  ../../testApp/misc/testjson.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testUnitTest.d  ../../testApp/misc/testUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testTypeCast.d  ../../testApp/misc/testTypeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testTimeStamp.d  ../../testApp/misc/testTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testDebugPtr.d  ../../testApp/misc/testDebugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testBaseException.d  ../../testApp/misc/testBaseException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testSharedVector.d  ../../testApp/misc/testSharedVector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testByteOrder.d  ../../testApp/misc/testByteOrder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testSerialization.d  ../../testApp/misc/testSerialization.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testByteBuffer.d  ../../testApp/misc/testByteBuffer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testEvent.d  ../../testApp/misc/testEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testOverrunBitSet.d  ../../testApp/misc/testOverrunBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testBitSet.d  ../../testApp/misc/testBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testTimer.d  ../../testApp/misc/testTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testThread.d  ../../testApp/misc/testThread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF performstruct.d  ../../testApp/pv/performstruct.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testThread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/performstruct.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testByteOrder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testBaseException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testDebugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testOverrunBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testByteBuffer.cpp
In file included from /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvUnitTest.h:11:0,
                 from ../../testApp/misc/testByteBuffer.cpp:19:
../../testApp/misc/testByteBuffer.cpp: In function ‘void testBasicOperations()’:
../../testApp/misc/testByteBuffer.cpp:164:36: warning: ‘const char* epics::pvData::ByteBuffer::getArray() const’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/byteBuffer.h:682) [-Wdeprecated-declarations]
     testOk1(strncmp(buff->getArray(),&src[2],6)==0);
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/epicsUnitTest.h:183:30: note: in definition of macro ‘testOk1’
 #define testOk1(cond) testOk(cond, "%s", #cond)
../../testApp/misc/testByteBuffer.cpp: In function ‘void testInverseEndianness(int, const char*)’:
../../testApp/misc/testByteBuffer.cpp:191:35: warning: ‘const char* epics::pvData::ByteBuffer::getArray() const’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/byteBuffer.h:682) [-Wdeprecated-declarations]
     testOk1(strncmp(buf->getArray(),expect,6)==0);
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testSharedVector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/test_reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testanyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testjson.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testTypeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testBitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testprinter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testSerialization.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testStandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testIntrospect.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testStandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testConvert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testOperators.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testValueBuilder.cpp
/usr/bin/g++ -o performstruct  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         performstruct.o    -lpvData -lCom  -lrt
/usr/bin/g++ -o testThread  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testThread.o    -lpvData -lCom
/usr/bin/g++ -o testEvent  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testEvent.o    -lpvData -lCom
/usr/bin/g++ -o testTimer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testTimer.o    -lpvData -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testFieldBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/property/testProperty.cpp
/usr/bin/g++ -o testBitSet  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testBitSet.o    -lpvData -lCom
/usr/bin/g++ -o testOverrunBitSet  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testOverrunBitSet.o    -lpvData -lCom
/usr/bin/g++ -o testByteOrder  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testByteOrder.o    -lpvData -lCom
/usr/bin/g++ -o testByteBuffer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testByteBuffer.o    -lpvData -lCom
/usr/bin/g++ -o testBaseException  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testBaseException.o    -lpvData -lCom
/usr/bin/g++ -o testDebugPtr  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testDebugPtr.o    -lpvData -lCom
/usr/bin/g++ -o testSharedVector  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testSharedVector.o    -lpvData -lCom
/usr/bin/g++ -o testTimeStamp  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testTimeStamp.o    -lpvData -lCom
/usr/bin/g++ -o testSerialization  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testSerialization.o    -lpvData -lCom
/usr/bin/g++ -o testTypeCast  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testTypeCast.o    -lpvData -lCom
/usr/bin/g++ -o testUnitTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testUnitTest.o    -lpvData -lCom
/usr/bin/g++ -o testjson  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testjson.o    -lpvData -lCom
/usr/bin/g++ -o test_reftrack  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         test_reftrack.o    -lpvData -lCom
/usr/bin/g++ -o testanyscalar  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testanyscalar.o    -lpvData -lCom
/usr/bin/g++ -o testprinter  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testprinter.o    -lpvData -lCom
/usr/bin/g++ -o testBitSetUtil  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testBitSetUtil.o    -lpvData -lCom
/usr/bin/g++ -o testIntrospect  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testIntrospect.o    -lpvData -lCom
/usr/bin/g++ -o testPVType  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVType.o    -lpvData -lCom
/usr/bin/g++ -o testStandardField  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testStandardField.o    -lpvData -lCom
/usr/bin/g++ -o testStandardPVField  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testStandardPVField.o    -lpvData -lCom
/usr/bin/g++ -o testPVUnion  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVUnion.o    -lpvData -lCom
/usr/bin/g++ -o testPVData  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVData.o    -lpvData -lCom
/usr/bin/g++ -o testConvert  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testConvert.o    -lpvData -lCom
/usr/bin/g++ -o testPVScalarArray  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVScalarArray.o    -lpvData -lCom
/usr/bin/g++ -o testPVStructureArray  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVStructureArray.o    -lpvData -lCom
/usr/bin/g++ -o testOperators  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testOperators.o    -lpvData -lCom
/usr/bin/g++ -o testFieldBuilder  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testFieldBuilder.o    -lpvData -lCom
/usr/bin/g++ -o testValueBuilder  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testValueBuilder.o    -lpvData -lCom
/usr/bin/g++ -o testProperty  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testProperty.o    -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testEvent.t testEvent
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testTimer.t testTimer
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testThread.t testThread
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testBitSet.t testBitSet
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testOverrunBitSet.t testOverrunBitSet
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testByteBuffer.t testByteBuffer
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testBaseException.t testBaseException
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testSharedVector.t testSharedVector
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testDebugPtr.t testDebugPtr
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testSerialization.t testSerialization
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testTimeStamp.t testTimeStamp
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testTypeCast.t testTypeCast
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testUnitTest.t testUnitTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testjson.t testjson
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 test_reftrack.t test_reftrack
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testanyscalar.t testanyscalar
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testprinter.t testprinter
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testBitSetUtil.t testBitSetUtil
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testIntrospect.t testIntrospect
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVType.t testPVType
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testStandardField.t testStandardField
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testStandardPVField.t testStandardPVField
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVData.t testPVData
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVUnion.t testPVUnion
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testConvert.t testConvert
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVScalarArray.t testPVScalarArray
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVStructureArray.t testPVStructureArray
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testOperators.t testOperators
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testValueBuilder.t testValueBuilder
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testFieldBuilder.t testFieldBuilder
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testProperty.t testProperty
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/copy/testCreateRequest.cpp
/usr/bin/g++ -o testCreateRequest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testCreateRequest.o    -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testCreateRequest.t testCreateRequest
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules'
configure/RULES_DIRS:85: recipe for target 'modules.install.linux-x86_64' failed
make: *** [modules.install.linux-x86_64] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
Notifying upstream projects of job completion
Email was triggered for: Failure - Any
Sending email for trigger: Failure - Any
Sending email to: core-talk at aps.anl.gov
epics-7.0 » linux64 - Build # 379 - Fixed! APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-7.0-win64 #287 APS Jenkins via Core-talk
Next: epics-7.0 » linux32 - Build # 378 - Failure! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: epics-7.0 » linux64 - Build # 379 - Fixed! APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
