2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: epics-7.0 » mac - Build # 378 - Failure!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 24 Jan 2022 16:00:04 -0600 (CST)
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/378/
This job failed to build.
Started by upstream project "epics-7.0" build number 378
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace /Users/jenkins/workspace/epics-7.0/OS/mac
The recommended git tool is: NONE
No credentials specified
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base/
 > git init /Users/jenkins/workspace/epics-7.0/OS/mac # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > git --version # timeout=10
 > git --version # 'git version 2.21.1 (Apple Git-122.3)'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Avoid second fetch
Checking out Revision 7cb80d5a179bdaf9c857436f9f428bf2020c3fb4 (refs/remotes/origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 7cb80d5a179bdaf9c857436f9f428bf2020c3fb4 # timeout=10
Commit message: "Merge Dirk's fix_epicsInt8 branch into 7.0"
 > git rev-list --no-walk 1c3aa018464136a1d0f546ab4ed0b950610ae58e # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
 > git submodule foreach --recursive git reset --hard # timeout=10
 > git submodule foreach git clean -fdx # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
 > git submodule update modules/pvData # timeout=10
 > git submodule update modules/pvAccess # timeout=10
 > git submodule update modules/normativeTypes # timeout=10
 > git submodule update modules/pvaClient # timeout=10
 > git submodule update modules/pvDatabase # timeout=10
 > git submodule update modules/pva2pva # timeout=10
 > git submodule update .ci # timeout=10
No emails were triggered.
[mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/jenkins7390828205067582944.sh
+ git submodule foreach 'git checkout master && git pull'
Entering '.ci'
Previous HEAD position was 75bae77 Add repo-configuration for CentOS6 (afterlife)
Switched to branch 'master'
Your branch is up to date with 'origin/master'.
Already up to date.
Entering 'modules/normativeTypes'
Already up to date.
Entering 'modules/pvAccess'
Previous HEAD position was 284de4f Set next development version
Already up to date.
Entering 'modules/pvData'
Already up to date.
Entering 'modules/pvDatabase'
Previous HEAD position was 0cf7065 Set next development version
Already up to date.
Entering 'modules/pva2pva'
Previous HEAD position was 61ec071 Set next development version
Already up to date.
Entering 'modules/pvaClient'
Already up to date.
+ csac=configure/os/CONFIG_SITE.darwin-x86.Common
+ echo 'CROSS_COMPILER_TARGET_ARCHS :='
+ case $EPICS_HOST_ARCH in
+ echo 'CROSS_COMPILER_TARGET_ARCHS += ios-arm'
+ EXTRA='-j4 -Orecurse'
+ echo ------------------------------------------------------------------
+ /Users/jenkins/bin/make -j4 -Orecurse host
fcntl(): Bad file descriptor
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure'
mkdir -p O.Common
perl -CSD ../src/tools/makeMakefile.pl O.darwin-x86 ../..
perl -CSD ../src/tools/makeMakefile.pl O.ios-arm ../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.darwin-x86'
cc -x c -E              -DUNIX  -Ddarwin    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/clang -I../../include/os/Darwin -I../../include         ../toolchain.c > TOOLCHAIN.darwin-x86.darwin-x86
Installing CFG file ../../cfg/TOOLCHAIN.darwin-x86.darwin-x86
mkdir ../../cfg
Installing CFG file ../../cfg/CONFIG_LIBCOM_MODULE
Installing CFG file ../../cfg/CONFIG_LIBCOM_VERSION
Installing CFG file ../../cfg/CONFIG_CA_VERSION
Installing CFG file ../../cfg/CONFIG_CA_MODULE
Installing CFG file ../../cfg/CONFIG_DATABASE_MODULE
Installing CFG file ../../cfg/CONFIG_DATABASE_VERSION
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.darwin-x86'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src'
/Users/jenkins/bin/make -C ./tools install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools'
mkdir -p O.Common
perl -CSD ../../src/tools/makeMakefile.pl O.darwin-x86 ../../..
perl -CSD ../../src/tools/makeMakefile.pl O.ios-arm ../../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.darwin-x86'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodXHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o makeAPIheader.html ../makeAPIheader.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podToHtml.html ../podToHtml.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podRemove.html ../podRemove.pl
Installing script ../../../bin/darwin-x86/assembleSnippets.pl
mkdir ../../../bin
mkdir ../../../bin/darwin-x86
Installing script ../../../bin/darwin-x86/convertRelease.pl
Installing script ../../../bin/darwin-x86/cvsclean.pl
Installing script ../../../bin/darwin-x86/depclean.pl
Installing script ../../../bin/darwin-x86/dos2unix.pl
Installing script ../../../bin/darwin-x86/epicsProve.pl
Installing script ../../../bin/darwin-x86/expandVars.pl
Installing script ../../../bin/darwin-x86/fullPathName.pl
Installing script ../../../bin/darwin-x86/installEpics.pl
Installing script ../../../bin/darwin-x86/makeAPIheader.pl
Installing script ../../../bin/darwin-x86/makeMakefile.pl
Installing script ../../../bin/darwin-x86/makeTestfile.pl
Installing script ../../../bin/darwin-x86/mkmf.pl
Installing script ../../../bin/darwin-x86/munch.pl
Installing script ../../../bin/darwin-x86/podToHtml.pl
Installing script ../../../bin/darwin-x86/podRemove.pl
Installing script ../../../bin/darwin-x86/replaceVAR.pl
Installing script ../../../bin/darwin-x86/tap-to-junit-xml.pl
Installing script ../../../bin/darwin-x86/testFailures.pl
Installing script ../../../bin/darwin-x86/useManifestTool.pl
Installing script ../../../bin/darwin-x86/genVersionHeader.pl
Installing script ../../../bin/darwin-x86/makeRPath.py
Installing generated html ../../../html/./EPICS/Getopts.html
mkdir ../../../html/./EPICS
Installing generated html ../../../html/./makeAPIheader.html
Installing generated html ../../../html/./munch.html
Installing generated html ../../../html/./podToHtml.html
Installing generated html ../../../html/./podRemove.html
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
Installing generated html ../../../html/./EPICS/Path.html
Installing generated html ../../../html/./fullPathName.html
Installing generated html ../../../html/./EPICS/Readfile.html
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools'
/Users/jenkins/bin/make -C template/ext install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext'
mkdir -p O.Common
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.darwin-x86'
Installing ../../../../templates/makeBaseExt/top/README
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
Installing ../../../../templates/makeBaseExt/top/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG
mkdir ../../../../templates/makeBaseExt/top/configure
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
mkdir ../../../../templates/makeBaseExt/top/configure/os
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
Installing ../../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../../templates/makeBaseExt/top/src
Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/exampleExt
Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/simpleExt
Installing script ../../../../bin/darwin-x86/makeBaseExt.pl
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext'
/Users/jenkins/bin/make -C template/base install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base'
mkdir -p O.Common
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.darwin-x86'
Installing script ../../../../bin/darwin-x86/makeBaseApp.pl
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
mkdir ../../../../templates/makeBaseApp/top/configure
Installing ../../../../templates/makeBaseApp/top/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../../templates/makeBaseApp/top/configure/RULES
Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src'
/Users/jenkins/bin/make -C ./test install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test'
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools'
mkdir -p O.Common
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../.. -a darwin-x86 ../Snippets.plt Snippets.t
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test'
/Users/jenkins/bin/make -C ./modules install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules'
Creating RELEASE.darwin-x86.local with
    EPICS_BASE = /Users/jenkins/workspace/epics-7.0/OS/mac
/Users/jenkins/bin/make -C ./libcom install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src/O.darwin-x86'
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
perl -CSD ../misc/makeEpicsVersion.pl -o epicsVersion.h   ../../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 7.0.6.2-DEV
Installing created executable ../../../../bin/darwin-x86/bldEnvData.pl
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeAPIheader.pl -o ../O.Common/libComAPI.h libCom
Installing generated generic include file ../../../../include/libComAPI.h
mkdir ../../../../include
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_gen.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_gen.o ../yajl/yajl_gen.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_lex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_lex.o ../yajl/yajl_lex.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_parser.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_parser.o ../yajl/yajl_parser.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_buf.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_buf.o ../yajl/yajl_buf.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_encode.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_encode.o ../yajl/yajl_encode.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_alloc.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_alloc.o ../yajl/yajl_alloc.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl.o ../yajl/yajl.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueuePassive.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueuePassive.o ../timer/timerQueuePassive.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueueActiveMgr.o ../timer/timerQueueActiveMgr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueueActive.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueueActive.o ../timer/timerQueueActive.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueue.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueue.o ../timer/timerQueue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timer.o ../timer/timer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimer.o ../timer/epicsTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsRingBytes.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsRingBytes.o ../ring/epicsRingBytes.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m taskwd.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         taskwd.o ../taskwd/taskwd.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsRingPointer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsRingPointer.o ../ring/epicsRingPointer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m threadPool.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         threadPool.o ../pool/threadPool.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m poolJob.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         poolJob.o ../pool/poolJob.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdFindAddr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdFindAddr.o ../osi/os/Darwin/osdFindAddr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdBackTrace.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdBackTrace.o ../osi/os/Darwin/osdBackTrace.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLibVMEOSD.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         devLibVMEOSD.o ../osi/os/default/devLibVMEOSD.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStackTrace.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStackTrace.o ../osi/epicsStackTrace.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLibVME.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         devLibVME.o ../osi/devLibVME.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdgetexec.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdgetexec.o ../osi/os/Darwin/osdgetexec.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdMessageQueue.o ../osi/os/default/osdMessageQueue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdNetIntf.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdNetIntf.o ../osi/os/Darwin/osdNetIntf.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdProcess.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdProcess.o ../osi/os/posix/osdProcess.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdMonotonic.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdMonotonic.o ../osi/os/Darwin/osdMonotonic.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdTime.o ../osi/os/Darwin/osdTime.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdEvent.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdEvent.o ../osi/os/posix/osdEvent.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSpin.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSpin.o ../osi/os/posix/osdSpin.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdMutex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdMutex.o ../osi/os/posix/osdMutex.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdThreadHooks.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdThreadHooks.o ../osi/os/default/osdThreadHooks.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdThreadExtra.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdThreadExtra.o ../osi/os/posix/osdThreadExtra.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdStdio.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdStdio.o ../osi/os/posix/osdStdio.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdio.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdio.o ../osi/epicsStdio.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdThread.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdThread.o ../osi/os/posix/osdThread.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTempFile.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTempFile.o ../osi/os/posix/epicsTempFile.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsReadline.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsReadline.o ../osi/epicsReadline.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdEnv.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdEnv.o ../osi/os/default/osdEnv.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSignal.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSignal.o ../osi/os/posix/osdSignal.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdPoolStatus.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdPoolStatus.o ../osi/os/default/osdPoolStatus.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdInterrupt.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdInterrupt.o ../osi/os/default/osdInterrupt.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdFindSymbol.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdFindSymbol.o ../osi/os/posix/osdFindSymbol.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdAssert.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdAssert.o ../osi/os/default/osdAssert.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSocketConvertErrnoToString.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSocketConvertErrnoToString.o ../osi/os/default/epicsSocketConvertErrnoToString.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m systemCallIntMech.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         systemCallIntMech.o ../osi/os/posix/systemCallIntMech.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osiSock.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osiSock.o ../osi/osiSock.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSockUnsentCount.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSockUnsentCount.o ../osi/os/Darwin/osdSockUnsentCount.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSockAddrReuse.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSockAddrReuse.o ../osi/os/default/osdSockAddrReuse.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSock.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSock.o ../osi/os/posix/osdSock.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osiClockTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osiClockTime.o ../osi/osiClockTime.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsGeneralTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsGeneralTime.o ../osi/epicsGeneralTime.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAtomicOSD.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAtomicOSD.o ../osi/os/posix/epicsAtomicOSD.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMath.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMath.o ../osi/epicsMath.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMessageQueue.o ../osi/epicsMessageQueue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEvent.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEvent.o ../osi/epicsEvent.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTime.o ../osi/epicsTime.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMutex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMutex.o ../osi/epicsMutex.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThread.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThread.o ../osi/epicsThread.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsUnitTest.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsUnitTest.o ../misc/epicsUnitTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ipAddrToAsciiAsynchronous.o ../misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m truncateFile.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         truncateFile.o ../misc/truncateFile.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsString.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsString.o ../misc/epicsString.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdlib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdlib.o ../misc/epicsStdlib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsExit.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsExit.o ../misc/epicsExit.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsConvert.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsConvert.o ../misc/epicsConvert.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m adjustment.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         adjustment.o ../misc/adjustment.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cantProceed.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cantProceed.o ../misc/cantProceed.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aToIPAddr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         aToIPAddr.o ../misc/aToIPAddr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m alarmString.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         alarmString.o ../misc/alarmString.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macUtil.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macUtil.o ../macLib/macUtil.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macEnv.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macEnv.o ../macLib/macEnv.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macCore.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macCore.o ../macLib/macCore.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocLog.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocLog.o ../log/iocLog.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m logClient.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         logClient.o ../log/logClient.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registry.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         registry.o ../iocsh/registry.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m libComRegister.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         libComRegister.o ../iocsh/libComRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m initHooks.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         initHooks.o ../iocsh/initHooks.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m gpHashLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         gpHashLib.o ../gpHash/gpHashLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocsh.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocsh.o ../iocsh/iocsh.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m freeListLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         freeListLib.o ../freeList/freeListLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m errSymTbl.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         errSymTbl.o errSymTbl.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m fdManager.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         fdManager.o ../fdmgr/fdManager.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m fdmgr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         fdmgr.o ../fdmgr/fdmgr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m errSymLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         errSymLib.o ../error/errSymLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m errlog.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         errlog.o ../error/errlog.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m envSubr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         envSubr.o ../env/envSubr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ellSort.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ellSort.o ../ellLib/ellSort.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ellLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ellLib.o ../ellLib/ellLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbmf.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         dbmf.o ../dbmf/dbmf.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSingletonMutex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSingletonMutex.o ../cxxTemplates/epicsSingletonMutex.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m resourceLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         resourceLib.o ../cxxTemplates/resourceLib.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cvtFast.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cvtFast.o ../cvtFast/cvtFast.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m calcPerform.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         calcPerform.o ../calc/calcPerform.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m postfix.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         postfix.o ../calc/postfix.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bucketLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         bucketLib.o ../bucketLib/bucketLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asTrapWrite.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         asTrapWrite.o ../as/asTrapWrite.c
Installing generic include file ../../../../include/valgrind/valgrind.h
mkdir ../../../../include/valgrind
Installing generic include file ../../../../include/asLib.h
Installing generic include file ../../../../include/asTrapWrite.h
Installing generated generic include file ../../../../include/libComVersion.h
Installing generic include file ../../../../include/bucketLib.h
Installing generic include file ../../../../include/postfix.h
Installing generic include file ../../../../include/cvtFast.h
Installing generic include file ../../../../include/epicsAlgorithm.h
Installing generic include file ../../../../include/resourceLib.h
Installing generic include file ../../../../include/tsDLList.h
Installing generic include file ../../../../include/tsSLList.h
perl -CSD ../../../../bin/darwin-x86/bldEnvData.pl  -t darwin-x86 \
	-c clang -s Darwin ../../../../configure
Generating envData.c
Installing generic include file ../../../../include/tsMinMax.h
Installing generic include file ../../../../include/tsFreeList.h
Installing generic include file ../../../../include/epicsSingleton.h
Installing generic include file ../../../../include/epicsGuard.h
Installing generic include file ../../../../include/dbmf.h
Installing generic include file ../../../../include/ellLib.h
Installing generic include file ../../../../include/envDefs.h
Installing generic include file ../../../../include/epicsPrint.h
Installing generic include file ../../../../include/errMdef.h
Installing generic include file ../../../../include/errSymTbl.h
Installing generic include file ../../../../include/errlog.h
Installing generic include file ../../../../include/fdManager.h
Installing generic include file ../../../../include/fdmgr.h
Installing generic include file ../../../../include/flex.skel.static
Installing generic include file ../../../../include/freeList.h
Installing generic include file ../../../../include/gpHash.h
Installing generic include file ../../../../include/iocsh.h
Installing generic include file ../../../../include/initHooks.h
Installing generic include file ../../../../include/registry.h
Installing generic include file ../../../../include/libComRegister.h
Installing generic include file ../../../../include/iocLog.h
Installing generic include file ../../../../include/logClient.h
Installing generic include file ../../../../include/macLib.h
Installing generic include file ../../../../include/alarm.h
Installing generic include file ../../../../include/alarmString.h
Installing generic include file ../../../../include/adjustment.h
Installing generic include file ../../../../include/cantProceed.h
Installing generic include file ../../../../include/dbDefs.h
Installing generic include file ../../../../include/epicsConvert.h
Installing generic include file ../../../../include/epicsExit.h
Installing generic include file ../../../../include/epicsStdlib.h
Installing generic include file ../../../../include/epicsString.h
Installing generic include file ../../../../include/epicsTypes.h
Installing generic include file ../../../../include/shareLib.h
Installing generic include file ../../../../include/locationException.h
Installing generic include file ../../../../include/epicsExport.h
Installing generic include file ../../../../include/ipAddrToAsciiAsynchronous.h
Installing generic include file ../../../../include/compilerDependencies.h
Installing generic include file ../../../../include/epicsUnitTest.h
Installing generated generic include file ../../../../include/epicsVersion.h
Installing generic include file ../../../../include/testMain.h
Installing compiler dependent include file ../../../../include/compiler/clang/compilerSpecific.h
mkdir ../../../../include/compiler
mkdir ../../../../include/compiler/clang
Installing generic include file ../../../../include/osiSock.h
Installing OS dependent include file ../../../../include/os/Darwin/osdSock.h
mkdir ../../../../include/os
mkdir ../../../../include/os/Darwin
Installing generic include file ../../../../include/osiFileName.h
Installing generic include file ../../../../include/epicsInterrupt.h
Installing OS dependent include file ../../../../include/os/Darwin/osdInterrupt.h
Installing generic include file ../../../../include/epicsMutex.h
Installing generic include file ../../../../include/epicsSpin.h
Installing OS dependent include file ../../../../include/os/Darwin/osdMutex.h
Installing generic include file ../../../../include/epicsEvent.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsMath.h
Installing OS dependent include file ../../../../include/os/Darwin/osdEvent.h
Installing OS dependent include file ../../../../include/os/Darwin/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/Darwin/osdStrtod.h
Installing generic include file ../../../../include/epicsAssert.h
Installing generic include file ../../../../include/epicsFindSymbol.h
Installing generic include file ../../../../include/osiPoolStatus.h
Installing OS dependent include file ../../../../include/os/Darwin/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/Darwin/osdThread.h
Installing generic include file ../../../../include/epicsThread.h
Installing generic include file ../../../../include/epicsTime.h
Installing generic include file ../../../../include/epicsGeneralTime.h
Installing OS dependent include file ../../../../include/os/Darwin/osdTime.h
Installing generic include file ../../../../include/generalTimeSup.h
Installing generic include file ../../../../include/osiClockTime.h
Installing generic include file ../../../../include/epicsSignal.h
Installing OS dependent include file ../../../../include/os/Darwin/osiUnistd.h
Installing generic include file ../../../../include/osiWireFormat.h
Installing generic include file ../../../../include/osiProcess.h
Installing OS dependent include file ../../../../include/os/Darwin/osdWireFormat.h
Installing generic include file ../../../../include/epicsAtomic.h
Installing OS dependent include file ../../../../include/os/Darwin/osdWireConfig.h
Installing generic include file ../../../../include/epicsAtomicDefault.h
Installing compiler dependent include file ../../../../include/compiler/clang/epicsAtomicCD.h
Installing generic include file ../../../../include/epicsEndian.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsAtomicOSD.h
Installing generic include file ../../../../include/epicsReadline.h
Installing generic include file ../../../../include/epicsStdioRedirect.h
Installing generic include file ../../../../include/epicsStdio.h
Installing generic include file ../../../../include/epicsMessageQueue.h
Installing generic include file ../../../../include/epicsTempFile.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsGetopt.h
Installing generic include file ../../../../include/epicsStackTrace.h
Installing generic include file ../../../../include/devLibVME.h
Installing generic include file ../../../../include/devLib.h
Installing generic include file ../../../../include/devLibVMEImpl.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsMMIODef.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsMMIO.h
Installing OS dependent include file ../../../../include/os/Darwin/osdVME.h
Installing generic include file ../../../../include/epicsAtomicGCC.h
Installing generic include file ../../../../include/epicsThreadPool.h
Installing generic include file ../../../../include/epicsRingPointer.h
Installing generic include file ../../../../include/epicsRingBytes.h
Installing generic include file ../../../../include/taskwd.h
Installing generic include file ../../../../include/epicsTimer.h
Installing generic include file ../../../../include/yajl_alloc.h
Installing generic include file ../../../../include/yajl_common.h
Installing generic include file ../../../../include/yajl_gen.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m warshall.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         warshall.o ../yacc/warshall.c
Installing generic include file ../../../../include/yajl_parse.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m verbose.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         verbose.o ../yacc/verbose.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m symtab.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         symtab.o ../yacc/symtab.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m skeleton.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         skeleton.o ../yacc/skeleton.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m reader.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         reader.o ../yacc/reader.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m output.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         output.o ../yacc/output.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mkpar.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         mkpar.o ../yacc/mkpar.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m antelope.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         antelope.o ../yacc/antelope.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lr0.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         lr0.o ../yacc/lr0.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lalr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         lalr.o ../yacc/lalr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m error.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         error.o ../yacc/error.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m closure.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         closure.o ../yacc/closure.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tblcmp.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         tblcmp.o ../flex/tblcmp.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocLogServer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocLogServer.o ../log/iocLogServer.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m sym.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         sym.o ../flex/sym.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nfa.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         nfa.o ../flex/nfa.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m misc.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         misc.o ../flex/misc.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m gen.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         gen.o ../flex/gen.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ecs.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ecs.o ../flex/ecs.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dfa.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         dfa.o ../flex/dfa.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ccl.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ccl.o ../flex/ccl.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m envData.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         envData.o envData.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/ecs.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/misc.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/nfa.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/sym.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/tblcmp.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/closure.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/error.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/lalr.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/lr0.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/antelope.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/mkpar.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/output.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/reader.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/skeleton.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/symtab.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/verbose.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/warshall.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/ccl.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/dfa.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/gen.c
c++ -o antelope  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o
Installing created executable ../../../../bin/darwin-x86/antelope
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -bparse -l -d ../flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parse.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         parse.o parse.c
cc         -DDEFAULT_SKELETON_FILE=flex.skel.static     -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c parse.c
c++ -o e_flex  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
Installing created executable ../../../../bin/darwin-x86/e_flex
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/e_flex -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         asLib.o asLib.c
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm
Expanding ../log/S99logServer@ to S99logServer
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -t ../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../log/S99logServer@ S99logServer
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../as/asTrapWrite.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../calc/postfix.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../calc/calcPerform.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../bucketLib/bucketLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cvtFast/cvtFast.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../dbmf/dbmf.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ellLib/ellLib.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cxxTemplates/epicsSingletonMutex.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ellLib/ellSort.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c envData.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cxxTemplates/resourceLib.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../error/errlog.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../env/envSubr.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c errSymTbl.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../error/errSymLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../freeList/freeListLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../gpHash/gpHashLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c asLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/initHooks.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/registry.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/iocsh.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/libComRegister.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../log/iocLog.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../log/logClient.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLib/macCore.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLib/macEnv.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/alarmString.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLib/macUtil.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/aToIPAddr.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/adjustment.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/cantProceed.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsConvert.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsExit.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsStdlib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/truncateFile.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsString.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsUnitTest.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/ipAddrToAsciiAsynchronous.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../fdmgr/fdManager.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsEvent.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsMutex.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsThread.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsMessageQueue.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsMath.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/epicsAtomicOSD.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/osiClockTime.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsGeneralTime.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdSockAddrReuse.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdSock.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsTime.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdSockUnsentCount.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/systemCallIntMech.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/osiSock.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdAssert.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdFindSymbol.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdInterrupt.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdPoolStatus.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdSignal.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdEnv.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/epicsTempFile.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdStdio.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsStdio.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE    -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsReadline.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdThreadExtra.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdThreadHooks.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdMutex.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdSpin.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdThread.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdEvent.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdProcess.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdNetIntf.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdTime.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdMessageQueue.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/devLibVME.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/devLibVMEOSD.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsStackTrace.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdgetexec.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdFindAddr.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdBackTrace.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../pool/poolJob.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../pool/threadPool.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ring/epicsRingPointer.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ring/epicsRingBytes.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../taskwd/taskwd.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/epicsTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timer.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdMonotonic.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueue.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueueActive.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueueActiveMgr.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_alloc.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_buf.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_encode.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_gen.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueuePassive.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_parser.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../log/iocLogServer.c
Installing created executable ../../../../bin/darwin-x86/S99logServer
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_lex.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../fdmgr/fdmgr.cpp
c++ -o libCom.3.21.1.dylib  -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libCom.3.21.1.dylib -compatibility_version 3.21.1 -current_version 3.21.1 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o          -lreadline -lm
Installing shared library ../../../../lib/darwin-x86/libCom.3.21.1.dylib
ln -s libCom.3.21.1.dylib ../../../../lib/darwin-x86/libCom.dylib
/usr/bin/ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/usr/bin/ranlib libCom.a
Installing library ../../../../lib/darwin-x86/libCom.a
c++ -o iocLogServer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            iocLogServer.o    -lCom
Installing created executable ../../../../bin/darwin-x86/iocLogServer
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src'
/Users/jenkins/bin/make -C ./vxWorks install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks/O.darwin-x86'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks'
/Users/jenkins/bin/make -C ./RTEMS install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS/O.darwin-x86'
Installing generic include file ../../../../include/epicsRtemsInitHooks.h
Installing generic include file ../../../../include/epicsMemFs.h
Installing script ../../../../bin/darwin-x86/epicsMakeMemFs.pl
Installing generic include file ../../../../include/epicsNtp.h
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS'
/Users/jenkins/bin/make -C ./test install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cvtFastPerform.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cvtFastPerform.o ../cvtFastPerform.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m buckTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         buckTest.o ../buckTest.c
INSTALL_LOCATION=../../../..
perl -CSD ../../../../modules/database/src/std/softIoc/makeInstallDir.pl "../../../.." > epicsInstallDir.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAtomicPerform.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAtomicPerform.o ../epicsAtomicPerform.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMaxThreads.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMaxThreads.o ../epicsMaxThreads.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPerform.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPerform.o ../epicsThreadPerform.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testexecname.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         testexecname.o ../testexecname.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocshTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocshTest.o ../iocshTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ipAddrToAsciiTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ipAddrToAsciiTest.o ../ipAddrToAsciiTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_test.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_test.o ../yajl_test.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osiSockTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osiSockTest.o ../osiSockTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStackTraceTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStackTraceTest.o ../epicsStackTraceTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m taskwdTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         taskwdTest.o ../taskwdTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMessageQueueTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMessageQueueTest.o ../epicsMessageQueueTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aslibtest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         aslibtest.o ../aslibtest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m blockingSockTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         blockingSockTest.o ../blockingSockTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macDefExpandTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macDefExpandTest.o ../macDefExpandTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cvtFastTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cvtFastTest.o ../cvtFastTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macLibTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macLibTest.o ../macLibTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAtomicTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAtomicTest.o ../epicsAtomicTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMutexTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMutexTest.o ../epicsMutexTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSpinTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSpinTest.o ../epicsSpinTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ringBytesTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ringBytesTest.o ../ringBytesTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEventTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEventTest.o ../epicsEventTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ringPointerTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ringPointerTest.o ../ringPointerTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsExitTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsExitTest.o ../epicsExitTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m initHookTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         initHookTest.o ../initHookTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimerTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimerTest.o ../epicsTimerTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadHooksTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadHooksTest.o ../epicsThreadHooksTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPoolTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPoolTest.o ../epicsThreadPoolTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPrivateTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPrivateTest.o ../epicsThreadPrivateTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPriorityTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPriorityTest.o ../epicsThreadPriorityTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadOnceTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadOnceTest.o ../epicsThreadOnceTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadClassTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadClassTest.o ../epicsThreadClassTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadTest.o ../epicsThreadTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimeZoneTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimeZoneTest.o ../epicsTimeZoneTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimeTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimeTest.o ../epicsTimeTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStringTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStringTest.o ../epicsStringTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSockResolveTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSockResolveTest.o ../epicsSockResolveTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdlibTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdlibTest.o ../epicsStdlibTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdioTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdioTest.o ../epicsStdioTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEnvUnsetTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEnvUnsetTest.o ../epicsEnvUnsetTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEnvTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEnvTest.o ../epicsEnvTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEllTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEllTest.o ../epicsEllTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMathTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMathTest.o ../epicsMathTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsErrlogTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsErrlogTest.o ../epicsErrlogTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAlgorithmTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAlgorithmTest.o ../epicsAlgorithmTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMMIOTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMMIOTest.o ../epicsMMIOTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsCalcTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsCalcTest.o ../epicsCalcTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest4.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest4.o ../epicsInlineTest4.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest3.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest3.o ../epicsInlineTest3.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest2.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest2.o ../epicsInlineTest2.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTypesTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTypesTest.o ../epicsTypesTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest1.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest1.o ../epicsInlineTest1.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsUnitTestTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsUnitTestTest.o ../epicsUnitTestTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsLoadTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsLoadTest.o ../epicsLoadTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsUnitTestTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest2.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest1.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTypesTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest4.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest3.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsAlgorithmTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMathTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMMIOTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEnvTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEnvUnsetTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEllTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStdioTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsCalcTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsErrlogTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsSockResolveTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStdlibTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTimeZoneTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStringTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadOnceTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadClassTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPriorityTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadHooksTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../initHookTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPoolTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPrivateTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsExitTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTimeTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ringBytesTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ringPointerTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsSpinTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEventTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTimerTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMutexTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macDefExpandTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLibTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../aslibtest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../taskwdTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsAtomicTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStackTraceTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../blockingSockTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMessageQueueTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../testexecname.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ipAddrToAsciiTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cvtFastTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osiSockTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl_test.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMaxThreads.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../buckTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPerform.cpp
c++          -DBUILDING_SHARED_LIBRARIES     -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsLoadTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -a darwin-x86 ../epicsUnitTestTest.plt epicsUnitTestTest.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -a darwin-x86 ../macLib.plt macLib.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -a darwin-x86 ../yajlTest.plt yajlTest.t
c++ -o epicsUnitTestTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsUnitTestTest.o    -lCom
c++ -o epicsTypesTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTypesTest.o    -lCom
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocshTest.cpp
c++ -o epicsInlineTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsInlineTest1.o epicsInlineTest2.o epicsInlineTest3.o epicsInlineTest4.o    -lCom
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cvtFastPerform.cpp
c++ -o epicsCalcTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsCalcTest.o    -lCom
c++ -o epicsAlgorithmTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsAlgorithmTest.o    -lCom
c++ -o epicsMathTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMathTest.o    -lCom
c++ -o epicsMMIOTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMMIOTest.o    -lCom
c++ -o epicsEllTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEllTest.o    -lCom
c++ -o epicsEnvTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEnvTest.o    -lCom
c++ -o epicsEnvUnsetTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEnvUnsetTest.o    -lCom
c++ -o epicsStdioTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStdioTest.o    -lCom
c++ -o epicsErrlogTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsErrlogTest.o    -lCom
c++ -o epicsSockResolveTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsSockResolveTest.o    -lCom
c++ -o epicsStringTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStringTest.o    -lCom
c++ -o epicsStdlibTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStdlibTest.o    -lCom
c++ -o epicsTimeTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTimeTest.o    -lCom
c++ -o epicsTimeZoneTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTimeZoneTest.o    -lCom
c++ -o epicsThreadTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadTest.o    -lCom
c++ -o epicsThreadClassTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadClassTest.o    -lCom
c++ -o epicsThreadPriorityTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPriorityTest.o    -lCom
c++ -o epicsThreadOnceTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadOnceTest.o    -lCom
c++ -o epicsThreadPrivateTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPrivateTest.o    -lCom
c++ -o epicsThreadHooksTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadHooksTest.o    -lCom
c++ -o epicsThreadPoolTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPoolTest.o    -lCom
c++ -o initHookTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            initHookTest.o    -lCom
c++ -o epicsExitTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsExitTest.o    -lCom
c++ -o epicsTimerTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTimerTest.o    -lCom
c++ -o ringPointerTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ringPointerTest.o    -lCom
c++ -o epicsEventTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEventTest.o    -lCom
c++ -o ringBytesTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ringBytesTest.o    -lCom
c++ -o epicsMutexTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMutexTest.o    -lCom
c++ -o epicsAtomicTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsAtomicTest.o    -lCom
c++ -o epicsSpinTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsSpinTest.o    -lCom
c++ -o macDefExpandTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            macDefExpandTest.o    -lCom
c++ -o cvtFastTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            cvtFastTest.o    -lCom
c++ -o macLibTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            macLibTest.o    -lCom
c++ -o aslibtest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            aslibtest.o    -lCom
c++ -o taskwdTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            taskwdTest.o    -lCom
c++ -o blockingSockTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            blockingSockTest.o    -lCom
c++ -o epicsMessageQueueTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMessageQueueTest.o    -lCom
c++ -o epicsStackTraceTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStackTraceTest.o    -lCom
c++ -o ipAddrToAsciiTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ipAddrToAsciiTest.o    -lCom
c++ -o osiSockTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            osiSockTest.o    -lCom
c++ -o testexecname  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testexecname.o    -lCom
c++ -o yajl_test  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            yajl_test.o    -lCom
c++ -o epicsLoadTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsLoadTest.o    -lCom
c++ -o iocshTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            iocshTest.o    -lCom
c++ -o epicsThreadPerform  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPerform.o    -lCom
c++ -o epicsMaxThreads  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMaxThreads.o    -lCom
c++ -o buckTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            buckTest.o    -lCom
c++ -o cvtFastPerform  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            cvtFastPerform.o    -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsInlineTest.t epicsInlineTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTypesTest.t epicsTypesTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsCalcTest.t epicsCalcTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsAlgorithmTest.t epicsAlgorithmTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMathTest.t epicsMathTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMMIOTest.t epicsMMIOTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEllTest.t epicsEllTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEnvTest.t epicsEnvTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEnvUnsetTest.t epicsEnvUnsetTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsErrlogTest.t epicsErrlogTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStdioTest.t epicsStdioTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStdlibTest.t epicsStdlibTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsSockResolveTest.t epicsSockResolveTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStringTest.t epicsStringTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTimeTest.t epicsTimeTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTimeZoneTest.t epicsTimeZoneTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadTest.t epicsThreadTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadClassTest.t epicsThreadClassTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadOnceTest.t epicsThreadOnceTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadPriorityTest.t epicsThreadPriorityTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadPrivateTest.t epicsThreadPrivateTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadHooksTest.t epicsThreadHooksTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadPoolTest.t epicsThreadPoolTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 initHookTest.t initHookTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsExitTest.t epicsExitTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTimerTest.t epicsTimerTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ringPointerTest.t ringPointerTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ringBytesTest.t ringBytesTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEventTest.t epicsEventTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMutexTest.t epicsMutexTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsSpinTest.t epicsSpinTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsAtomicTest.t epicsAtomicTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 macDefExpandTest.t macDefExpandTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 cvtFastTest.t cvtFastTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 macLibTest.t macLibTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 aslibtest.t aslibtest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 taskwdTest.t taskwdTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 blockingSockTest.t blockingSockTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMessageQueueTest.t epicsMessageQueueTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStackTraceTest.t epicsStackTraceTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ipAddrToAsciiTest.t ipAddrToAsciiTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 osiSockTest.t osiSockTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testexecname.t testexecname
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 iocshTest.t iocshTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsLoadTest.t epicsLoadTest
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsAtomicPerform.cpp
c++ -o epicsAtomicPerform  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsAtomicPerform.o    -lCom
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom'
/Users/jenkins/bin/make -C ./ca install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src'
/Users/jenkins/bin/make -C ./template install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../../..
mkdir -p O.Common
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template/O.darwin-x86'
Installing ../../../../../templates/makeBaseApp/top/caClientApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caClientApp
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caExample.c
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caPerlApp
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/cainfo.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caput.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caget.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/camonitor.pl
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template'
/Users/jenkins/bin/make -C ./client install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client/O.darwin-x86'
Expanding ../caVersion.h@ to ../O.Common/caVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="2"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../caVersion.h@ caVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeAPIheader.pl -o ../O.Common/libCaAPI.h libCa
Installing generated generic include file ../../../../../include/libCaAPI.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caEventRateMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caEventRateMain.o ../caEventRateMain.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caEventRate.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caEventRate.o ../caEventRate.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caConnTest.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caConnTest.o ../caConnTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caConnTestMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caConnTestMain.o ../caConnTestMain.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m casw.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         casw.o ../casw.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m acctstMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         acctstMain.o ../acctstMain.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m acctst.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         acctst.o ../acctst.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m catimeMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         catimeMain.o ../catimeMain.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m catime.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         catime.o ../catime.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caRepeater.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caRepeater.o ../caRepeater.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ca_test_main.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ca_test_main.o ../test/ca_test_main.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ca_test.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ca_test.o ../test/ca_test.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m hostNameCache.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         hostNameCache.o ../hostNameCache.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m comBuf.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         comBuf.o ../comBuf.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m msgForMultiplyDefinedPV.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         msgForMultiplyDefinedPV.o ../msgForMultiplyDefinedPV.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m comQueSend.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         comQueSend.o ../comQueSend.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m comQueRecv.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         comQueRecv.o ../comQueRecv.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m localHostName.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         localHostName.o ../localHostName.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncGroupWriteNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncGroupWriteNotify.o ../syncGroupWriteNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncGroupReadNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncGroupReadNotify.o ../syncGroupReadNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncGroupNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncGroupNotify.o ../syncGroupNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncgrp.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncgrp.o ../syncgrp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m CASG.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         CASG.o ../CASG.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m putCallback.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         putCallback.o ../putCallback.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m getCopy.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         getCopy.o ../getCopy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m getCallback.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         getCallback.o ../getCallback.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m oldSubscription.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         oldSubscription.o ../oldSubscription.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m oldChannelNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         oldChannelNotify.o ../oldChannelNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bhe.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         bhe.o ../bhe.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ca_client_context.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ca_client_context.o ../ca_client_context.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tcpRecvWatchdog.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tcpRecvWatchdog.o ../tcpRecvWatchdog.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tcpSendWatchdog.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tcpSendWatchdog.o ../tcpSendWatchdog.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netSubscription.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netSubscription.o ../netSubscription.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netWriteNotifyIO.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netWriteNotifyIO.o ../netWriteNotifyIO.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netReadNotifyIO.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netReadNotifyIO.o ../netReadNotifyIO.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m noopiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         noopiiu.o ../noopiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tcpiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tcpiiu.o ../tcpiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netiiu.o ../netiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m udpiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         udpiiu.o ../udpiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nciu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         nciu.o ../nciu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m baseNMIU.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         baseNMIU.o ../baseNMIU.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m disconnectGovernorTimer.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         disconnectGovernorTimer.o ../disconnectGovernorTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m repeaterSubscribeTimer.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         repeaterSubscribeTimer.o ../repeaterSubscribeTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m searchTimer.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         searchTimer.o ../searchTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m repeater.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         repeater.o ../repeater.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m test_event.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         test_event.o ../test_event.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m convert.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         convert.o ../convert.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocinf.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         iocinf.o ../iocinf.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m access.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         access.o ../access.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacStateNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacStateNotify.o ../cacStateNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacWriteNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacWriteNotify.o ../cacWriteNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacReadNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacReadNotify.o ../cacReadNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacContextNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacContextNotify.o ../cacContextNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacChannelNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacChannelNotify.o ../cacChannelNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacChannel.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacChannel.o ../cacChannel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cac.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cac.o ../cac.cpp
Installing generic include file ../../../../../include/cadef.h
Installing generic include file ../../../../../include/caerr.h
Installing generic include file ../../../../../include/caeventmask.h
Installing generic include file ../../../../../include/caProto.h
Installing generic include file ../../../../../include/db_access.h
Installing generic include file ../../../../../include/addrList.h
Installing generic include file ../../../../../include/cacIO.h
Installing generic include file ../../../../../include/caDiagnostics.h
Installing generic include file ../../../../../include/net_convert.h
Installing html ../../../../../html/./CAref.html
Expanding ../S99caRepeater@ to S99caRepeater
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -t ../../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="2"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../S99caRepeater@ S99caRepeater
Installing created executable ../../../../../bin/darwin-x86/S99caRepeater
Installing generated generic include file ../../../../../include/caVersion.h
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacChannelNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacChannel.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacContextNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacReadNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacWriteNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacStateNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../iocinf.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../access.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../convert.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../test_event.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cac.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../repeater.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../disconnectGovernorTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../searchTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../baseNMIU.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../repeaterSubscribeTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../nciu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../noopiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../udpiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netReadNotifyIO.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tcpiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netWriteNotifyIO.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netSubscription.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tcpSendWatchdog.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tcpRecvWatchdog.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../bhe.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../ca_client_context.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../oldChannelNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../oldSubscription.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../getCallback.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../getCopy.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../putCallback.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncgrp.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../CASG.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncGroupNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncGroupReadNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncGroupWriteNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../localHostName.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../comBuf.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../comQueRecv.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../comQueSend.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../hostNameCache.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../test/ca_test_main.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../msgForMultiplyDefinedPV.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../test/ca_test.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../catimeMain.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caRepeater.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../catime.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../acctstMain.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caConnTestMain.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../acctst.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caConnTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../casw.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caEventRateMain.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caEventRate.cpp
/usr/bin/ar -rc    libca.a     cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o
/usr/bin/ranlib libca.a
c++ -o libca.4.14.2.dylib  -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libca.4.14.2.dylib -compatibility_version 4.14.2 -current_version 4.14.2 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64             cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom      -lreadline -lm
Installing shared library ../../../../../lib/darwin-x86/libca.4.14.2.dylib
ln -s libca.4.14.2.dylib ../../../../../lib/darwin-x86/libca.dylib
Installing library ../../../../../lib/darwin-x86/libca.a
c++ -o ca_test  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ca_test_main.o ca_test.o    -lca -lCom -lca -lCom
c++ -o caRepeater  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caRepeater.o    -lca -lCom
c++ -o catime  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            catimeMain.o catime.o    -lca -lCom
c++ -o acctst  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            acctstMain.o acctst.o    -lca -lCom
c++ -o caConnTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caConnTestMain.o caConnTest.o    -lca -lCom
c++ -o casw  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            casw.o    -lca -lCom
c++ -o caEventRate  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caEventRateMain.o caEventRate.o    -lca -lCom
Installing created executable ../../../../../bin/darwin-x86/ca_test
Installing created executable ../../../../../bin/darwin-x86/caRepeater
Installing created executable ../../../../../bin/darwin-x86/catime
Installing created executable ../../../../../bin/darwin-x86/acctst
Installing created executable ../../../../../bin/darwin-x86/caConnTest
Installing created executable ../../../../../bin/darwin-x86/casw
Installing created executable ../../../../../bin/darwin-x86/caEventRate
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client'
/Users/jenkins/bin/make -C ./tools install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools'
mkdir -p O.Common
    T_A=darwin-x86 install
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caput.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caput.o ../caput.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cainfo.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cainfo.o ../cainfo.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m camonitor.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         camonitor.o ../camonitor.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caget.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caget.o ../caget.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tool_lib.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tool_lib.o ../tool_lib.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caget.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tool_lib.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../camonitor.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cainfo.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caput.c
c++ -o caget  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caget.o tool_lib.o   -lca -lCom
c++ -o camonitor  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            camonitor.o tool_lib.o   -lca -lCom
c++ -o cainfo  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            cainfo.o tool_lib.o   -lca -lCom
c++ -o caput  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caput.o tool_lib.o   -lca -lCom
Installing created executable ../../../../../bin/darwin-x86/caget
Installing created executable ../../../../../bin/darwin-x86/camonitor
Installing created executable ../../../../../bin/darwin-x86/cainfo
Installing created executable ../../../../../bin/darwin-x86/caput
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools'
/Users/jenkins/bin/make -C ./perl install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl/O.darwin-x86'
rm -f Cap5.c Cap5.c_new
perl -CSD /opt/local/bin/xsubpp -typemap /opt/local/lib/perl5/5.22/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m Cap5.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/opt/local/lib/perl5/5.22/darwin-thread-multi-2level/CORE     Cap5.o Cap5.c
Installing PERL_MODULES file ../../../../../lib/perl/CA.pm
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -o CA.html ../CA.pm
Installing script ../../../../../bin/darwin-x86/capr.pl
Installing generated html ../../../../../html/./CA.html
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration   -pipe -Os  -fno-common -DPERL_DARWIN -I/opt/local/include -fno-strict-aliasing -fstack-protector -I/opt/local/include -DPERL_USE_SAFE_PUTENV    -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/opt/local/lib/perl5/5.22/darwin-thread-multi-2level/CORE     -c Cap5.c
c++ -o Cap5.bundle  -bundle -undefined dynamic_lookup -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            Cap5.o    -lca -lCom      -lreadline -lm
Installing loadable shared library ../../../../../lib/perl/5.22.2/darwin-thread-multi-2level/Cap5.bundle
mkdir ../../../../../lib/perl/5.22.2
mkdir ../../../../../lib/perl/5.22.2/darwin-thread-multi-2level
Installing loadable shared library ../../../../../lib/darwin-x86/Cap5.bundle
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca'
/Users/jenkins/bin/make -C ./database install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src'
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools/O.darwin-x86'
Installing PERL_MODULES file ../../../../../lib/perl/DBD.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Base.pm
mkdir ../../../../../lib/perl/DBD
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Breaktable.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Device.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Driver.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Link.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Function.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Menu.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Output.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Parser.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recfield.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recordtype.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Record.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Registrar.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Variable.pm
Installing PERL_MODULES file ../../../../../lib/perl/EPICS/IOC.pm
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -o IOC.html ../EPICS/IOC.pm
Expanding ../epics-base.pc@ to epics-base.pc
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -DFINAL_LOCATION="/Users/jenkins/workspace/epics-7.0/OS/mac" -DOS_CLASS="Darwin" -DCMPLR_CLASS="clang" -DC_CFLAGS="-DUNIX -Ddarwin -arch x86_64 -fno-common" -DLDFLAGS="-arch x86_64" -DLDLIBS="-lreadline -lm" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="2" -DCC="cc" -DCCC="c++" -DCPP="cc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    ../epics-base.pc@ epics-base.pc
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -o dbdToHtml.html ../dbdToHtml.pl
Installing script ../../../../../bin/darwin-x86/makeIncludeDbd.pl
Installing script ../../../../../bin/darwin-x86/dbdToMenuH.pl
Installing script ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl
Installing script ../../../../../bin/darwin-x86/dbdExpand.pl
Installing script ../../../../../bin/darwin-x86/dbExpand.pl
Installing script ../../../../../bin/darwin-x86/dbdToHtml.pl
Installing script ../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base.pc
mkdir ../../../../../lib/pkgconfig
Expanding epics-base-darwin-x86.pc@ to epics-base-darwin-x86.pc
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -DFINAL_LOCATION="/Users/jenkins/workspace/epics-7.0/OS/mac" -DOS_CLASS="Darwin" -DCMPLR_CLASS="clang" -DC_CFLAGS="-DUNIX -Ddarwin -arch x86_64 -fno-common" -DLDFLAGS="-arch x86_64" -DLDLIBS="-lreadline -lm" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="2" -DCC="cc" -DCCC="c++" -DCPP="cc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    epics-base-darwin-x86.pc@ epics-base-darwin-x86.pc
Installing generated html ../../../../../html/./EPICS/IOC.html
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base-darwin-x86.pc
Installing generated html ../../../../../html/./dbdToHtml.html
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools'
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template/O.darwin-x86'
Installing ../../../../../templates/makeBaseApp/top/iocApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp
Installing ../../../../../templates/makeBaseApp/top/iocApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/Db
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/src
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/Db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/circle.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/_APPNAME_Version.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/src
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocBoot
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/iocBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template'
/Users/jenkins/bin/make -C ./ioc install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc/O.darwin-x86'
Expanding ../databaseVersion.h@ to ../O.Common/databaseVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../..   -DEPICS_DATABASE_MAJOR_VERSION="3"  -DEPICS_DATABASE_MINOR_VERSION="21"  -DEPICS_DATABASE_MAINTENANCE_VERSION="1"  -DEPICS_DATABASE_DEVELOPMENT_FLAG="1"  ../databaseVersion.h@ databaseVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuConvert.dbd ../bpt/menuConvert.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuAlarmSevr.dbd ../db/menuAlarmSevr.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuAlarmStat.dbd ../db/menuAlarmStat.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuFtype.dbd ../db/menuFtype.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuIvoa.dbd ../db/menuIvoa.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuOmsl.dbd ../db/menuOmsl.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuPini.dbd ../db/menuPini.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuPost.dbd ../db/menuPost.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuPriority.dbd ../db/menuPriority.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuYesNo.dbd ../db/menuYesNo.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuSimm.dbd ../db/menuSimm.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuScan.dbd ../db/menuScan.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o dbCommonRecord.dbd ../db/dbCommonRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeAPIheader.pl -o ../O.Common/dbCoreAPI.h dbCore
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLoadTemplate_lex.c ../dbtemplate/dbLoadTemplate_lex.l
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLex.c ../dbStatic/dbLex.l
Global symbol "$warned" requires explicit package name (did you forget to declare "my $warned"?) at /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/../../lib/perl/DBD/Breaktable.pm line 31.
Compilation failed in require at /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/../../lib/perl/DBD.pm line 13.
BEGIN failed--compilation aborted at /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/../../lib/perl/DBD.pm line 13.
Compilation failed in require at ../../../../../bin/darwin-x86/dbdToMenuH.pl line 18.
BEGIN failed--compilation aborted at ../../../../../bin/darwin-x86/dbdToMenuH.pl line 18.
Compilation failed in require at ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl line 16.
BEGIN failed--compilation aborted at ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl line 16.
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.h ../O.Common/menuConvert.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmSevr.h ../O.Common/menuAlarmSevr.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmStat.h ../O.Common/menuAlarmStat.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuFtype.h ../O.Common/menuFtype.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuIvoa.h ../O.Common/menuIvoa.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuOmsl.h ../O.Common/menuOmsl.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPini.h ../O.Common/menuPini.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPost.h ../O.Common/menuPost.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPriority.h ../O.Common/menuPriority.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuYesNo.h ../O.Common/menuYesNo.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuSimm.h ../O.Common/menuSimm.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuScan.h ../O.Common/menuScan.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl -I ../db  -I ../O.Common -o dbCommon.h ../O.Common/dbCommonRecord.dbd
Installing generated generic include file ../../../../../include/dbCoreAPI.h
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -bdbYacc  ../dbStatic/dbYacc.y
mv dbYacc.tab.c dbYacc.c
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -bdbLoadTemplate  ../dbtemplate/dbLoadTemplate.y
mv dbLoadTemplate.tab.c dbLoadTemplate.c
make[5]: INTERNAL: Exiting with 1 jobserver tokens (should be 0)!
make[5]: *** No rule to make target '../O.Common/menuConvert.h', needed by 'inc'.  Stop.
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc/O.darwin-x86'
../../../../configure/RULES_ARCHS:58: recipe for target 'install.darwin-x86' failed
make[4]: *** [install.darwin-x86] Error 2
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc'
../../../configure/RULES_DIRS:85: recipe for target 'ioc.install.darwin-x86' failed
make[3]: *** [ioc.install.darwin-x86] Error 2
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src'
../../configure/RULES_DIRS:85: recipe for target 'src.install.darwin-x86' failed
make[2]: *** [src.install.darwin-x86] Error 2
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database'
../configure/RULES_DIRS:85: recipe for target 'database.install.darwin-x86' failed
make[1]: *** [database.install.darwin-x86] Error 2
make[1]: *** Waiting for unfinished jobs....
/Users/jenkins/bin/make -C ./pvData install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData'
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure'
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/convertRelease.pl checkRelease
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_PVDATA_VERSION
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
mkdir -p O.Common
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../..
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src/O.darwin-x86'
mkdir -p ../O.Common/pv
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -DEPICS_PVD_MAJOR_VERSION="8" -DEPICS_PVD_MINOR_VERSION="0" -DEPICS_PVD_MAINTENANCE_VERSION="5" -DEPICS_PVD_DEVELOPMENT_FLAG="1" -t /Users/jenkins/workspace/epics-7.0/OS/mac    ../pv/pvdVersionNum.h@ ../O.Common/pv/pvdVersionNum.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m print.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        print.o ../../src/json/print.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parseinto.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parseinto.o ../../src/json/parseinto.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parseany.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parseany.o ../../src/json/parseany.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parsehelper.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parsehelper.o ../../src/json/parsehelper.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bitSetUtil.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        bitSetUtil.o ../../src/pvMisc/bitSetUtil.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m requestmapper.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        requestmapper.o ../../src/copy/requestmapper.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m createRequest.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        createRequest.o ../../src/copy/createRequest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvTimeStamp.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvTimeStamp.o ../../src/property/pvTimeStamp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timeStamp.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        timeStamp.o ../../src/property/timeStamp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvEnumerated.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvEnumerated.o ../../src/property/pvEnumerated.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvDisplay.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvDisplay.o ../../src/property/pvDisplay.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvControl.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvControl.o ../../src/property/pvControl.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvAlarm.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvAlarm.o ../../src/property/pvAlarm.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m alarm.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        alarm.o ../../src/property/alarm.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m printer.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        printer.o ../../src/factory/printer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m StandardPVField.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        StandardPVField.o ../../src/factory/StandardPVField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m StandardField.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        StandardField.o ../../src/factory/StandardField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m Compare.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        Compare.o ../../src/factory/Compare.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvSubArrayCopy.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvSubArrayCopy.o ../../src/factory/pvSubArrayCopy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m Convert.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        Convert.o ../../src/factory/Convert.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVDataCreateFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVDataCreateFactory.o ../../src/factory/PVDataCreateFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVUnionArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVUnionArray.o ../../src/factory/PVUnionArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVUnion.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVUnion.o ../../src/factory/PVUnion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVStructureArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVStructureArray.o ../../src/factory/PVStructureArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVStructure.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVStructure.o ../../src/factory/PVStructure.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVScalarArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVScalarArray.o ../../src/factory/PVScalarArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVArray.o ../../src/factory/PVArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVScalar.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVScalar.o ../../src/factory/PVScalar.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVField.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVField.o ../../src/factory/PVField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m FieldCreateFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        FieldCreateFactory.o ../../src/factory/FieldCreateFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdVersion.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdVersion.o ../../src/pv/pvdVersion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m TypeFunc.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        TypeFunc.o ../../src/factory/TypeFunc.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m valueBuilder.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        valueBuilder.o ../../src/pv/valueBuilder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m debugPtr.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        debugPtr.o ../../src/misc/debugPtr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m reftrack.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        reftrack.o ../../src/misc/reftrack.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m anyscalar.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        anyscalar.o ../../src/misc/anyscalar.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parseToPOD.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parseToPOD.o ../../src/misc/parseToPOD.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvUnitTest.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvUnitTest.o ../../src/misc/pvUnitTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m thread.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        thread.o ../../src/misc/thread.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m typeCast.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        typeCast.o ../../src/misc/typeCast.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m status.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        status.o ../../src/misc/status.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timer.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        timer.o ../../src/misc/timer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m event.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        event.o ../../src/misc/event.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m serializeHelper.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        serializeHelper.o ../../src/misc/serializeHelper.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsException.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        epicsException.o ../../src/misc/epicsException.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bitSet.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        bitSet.o ../../src/misc/bitSet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m byteBuffer.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        byteBuffer.o ../../src/misc/byteBuffer.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/noDefaultMethods.h
mkdir /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/lock.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/serialize.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/bitSet.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/byteBuffer.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/epicsException.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/serializeHelper.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/event.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/thread.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/timer.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/status.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/sharedPtr.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/debugPtr.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/typeCast.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/sharedVector.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/templateMeta.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/current_function.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvUnitTest.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/reftrack.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/anyscalar.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvType.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvIntrospect.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/valueBuilder.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvData.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/convert.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/standardField.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/standardPVField.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvSubArrayCopy.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/typemap.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdVersion.h
Installing generated generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdVersionNum.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/factory.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/alarm.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvAlarm.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/control.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvControl.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/display.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvDisplay.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvEnumerated.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/timeStamp.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvTimeStamp.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/createRequest.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/bitSetUtil.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/json.h
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/byteBuffer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/epicsException.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/bitSet.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/event.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/serializeHelper.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/timer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/status.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/thread.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/parseToPOD.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/debugPtr.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/pvUnitTest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/typeCast.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pv/pvdVersion.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/anyscalar.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/reftrack.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pv/valueBuilder.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/TypeFunc.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVScalar.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/FieldCreateFactory.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVStructure.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVStructureArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVUnion.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVUnionArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/Convert.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVScalarArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/pvSubArrayCopy.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/Compare.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/StandardField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVDataCreateFactory.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/alarm.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/StandardPVField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvControl.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvAlarm.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/printer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvDisplay.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvEnumerated.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/timeStamp.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvTimeStamp.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pvMisc/bitSetUtil.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/requestmapper.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/parsehelper.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/createRequest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/parseany.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/print.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/parseinto.cpp
c++ -o libpvData.8.0.5.dylib  -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.8.0.5.dylib -compatibility_version 8.0.5 -current_version 8.0.5 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64             byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o   -lCom      -lreadline -lm
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.8.0.5.dylib
ln -s libpvData.8.0.5.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.dylib
/usr/bin/ar -rc    libpvData.a     byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libpvData.a(byteBuffer.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libpvData.a(debugPtr.o) has no symbols
/usr/bin/ranlib libpvData.a
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src'
/Users/jenkins/bin/make -C ./examples install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m unittest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        unittest.o ../unittest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../unittest.cpp
c++ -o unittest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            unittest.o    -lpvData -lCom
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples'
/Users/jenkins/bin/make -C ./testApp install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testValueBuilder.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testValueBuilder.o ../../testApp/pv/testValueBuilder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testCreateRequest.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testCreateRequest.o ../../testApp/copy/testCreateRequest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testProperty.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testProperty.o ../../testApp/property/testProperty.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testFieldBuilder.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testFieldBuilder.o ../../testApp/pv/testFieldBuilder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testOperators.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testOperators.o ../../testApp/pv/testOperators.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVScalarArray.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVScalarArray.o ../../testApp/pv/testPVScalarArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVStructureArray.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVStructureArray.o ../../testApp/pv/testPVStructureArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testConvert.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testConvert.o ../../testApp/pv/testConvert.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVUnion.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVUnion.o ../../testApp/pv/testPVUnion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testStandardPVField.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testStandardPVField.o ../../testApp/pv/testStandardPVField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVData.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVData.o ../../testApp/pv/testPVData.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVType.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVType.o ../../testApp/pv/testPVType.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testStandardField.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testStandardField.o ../../testApp/pv/testStandardField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testIntrospect.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testIntrospect.o ../../testApp/pv/testIntrospect.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testBitSetUtil.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testBitSetUtil.o ../../testApp/pv/testBitSetUtil.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testprinter.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testprinter.o ../../testApp/misc/testprinter.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testanyscalar.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testanyscalar.o ../../testApp/misc/testanyscalar.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m test_reftrack.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        test_reftrack.o ../../testApp/misc/test_reftrack.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testUnitTest.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testUnitTest.o ../../testApp/misc/testUnitTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testjson.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testjson.o ../../testApp/misc/testjson.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testTypeCast.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testTypeCast.o ../../testApp/misc/testTypeCast.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testTimeStamp.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testTimeStamp.o ../../testApp/misc/testTimeStamp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testSerialization.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testSerialization.o ../../testApp/misc/testSerialization.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testDebugPtr.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testDebugPtr.o ../../testApp/misc/testDebugPtr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testSharedVector.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testSharedVector.o ../../testApp/misc/testSharedVector.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testBaseException.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testBaseException.o ../../testApp/misc/testBaseException.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testByteOrder.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testByteOrder.o ../../testApp/misc/testByteOrder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testByteBuffer.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testByteBuffer.o ../../testApp/misc/testByteBuffer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testOverrunBitSet.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testOverrunBitSet.o ../../testApp/misc/testOverrunBitSet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testEvent.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testEvent.o ../../testApp/misc/testEvent.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testBitSet.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testBitSet.o ../../testApp/misc/testBitSet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testTimer.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testTimer.o ../../testApp/misc/testTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testThread.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testThread.o ../../testApp/misc/testThread.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testEvent.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testThread.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testTimer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testByteOrder.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testBitSet.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testOverrunBitSet.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testBaseException.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testDebugPtr.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testByteBuffer.cpp
../../testApp/misc/testByteBuffer.cpp:164:27: warning: 'getArray' is deprecated [-Wdeprecated-declarations]
    testOk1(strncmp(buff->getArray(),&src[2],6)==0);
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/byteBuffer.h:682:54: note: 'getArray' has been explicitly marked deprecated here
    EPICS_ALWAYS_INLINE const char* getArray() const EPICS_DEPRECATED
/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang/compilerSpecific.h:54:41: note: expanded from macro 'EPICS_DEPRECATED'
#define EPICS_DEPRECATED __attribute__((deprecated))
../../testApp/misc/testByteBuffer.cpp:191:26: warning: 'getArray' is deprecated [-Wdeprecated-declarations]
    testOk1(strncmp(buf->getArray(),expect,6)==0);
2 warnings generated.
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testTimeStamp.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testSharedVector.cpp
../../testApp/misc/testSharedVector.cpp:157:9: warning: explicitly assigning value of variable of type 'pvd::shared_vector<pvd::int32>' (aka 'shared_vector<int>') to itself [-Wself-assign-overloaded]
    one = one; // no-op
1 warning generated.
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testUnitTest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testjson.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testTypeCast.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/test_reftrack.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testSerialization.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testanyscalar.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVType.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testBitSetUtil.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testStandardField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testIntrospect.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testprinter.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testStandardPVField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testConvert.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVUnion.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVStructureArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testOperators.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVScalarArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVData.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testFieldBuilder.cpp
c++ -o testThread  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testThread.o    -lpvData -lCom
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testValueBuilder.cpp
c++ -o testEvent  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testEvent.o    -lpvData -lCom
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/property/testProperty.cpp
c++ -o testTimer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testTimer.o    -lpvData -lCom
c++ -o testBitSet  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testBitSet.o    -lpvData -lCom
c++ -o testOverrunBitSet  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testOverrunBitSet.o    -lpvData -lCom
c++ -o testByteOrder  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testByteOrder.o    -lpvData -lCom
c++ -o testSharedVector  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testSharedVector.o    -lpvData -lCom
c++ -o testBaseException  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testBaseException.o    -lpvData -lCom
c++ -o testByteBuffer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testByteBuffer.o    -lpvData -lCom
c++ -o testDebugPtr  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testDebugPtr.o    -lpvData -lCom
c++ -o testTimeStamp  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testTimeStamp.o    -lpvData -lCom
c++ -o testSerialization  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testSerialization.o    -lpvData -lCom
c++ -o testUnitTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testUnitTest.o    -lpvData -lCom
c++ -o testTypeCast  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testTypeCast.o    -lpvData -lCom
c++ -o testjson  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testjson.o    -lpvData -lCom
c++ -o test_reftrack  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            test_reftrack.o    -lpvData -lCom
c++ -o testanyscalar  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testanyscalar.o    -lpvData -lCom
c++ -o testprinter  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testprinter.o    -lpvData -lCom
c++ -o testBitSetUtil  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testBitSetUtil.o    -lpvData -lCom
c++ -o testIntrospect  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testIntrospect.o    -lpvData -lCom
c++ -o testPVType  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVType.o    -lpvData -lCom
c++ -o testStandardField  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testStandardField.o    -lpvData -lCom
c++ -o testStandardPVField  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testStandardPVField.o    -lpvData -lCom
c++ -o testPVData  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVData.o    -lpvData -lCom
c++ -o testPVUnion  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVUnion.o    -lpvData -lCom
c++ -o testPVScalarArray  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVScalarArray.o    -lpvData -lCom
c++ -o testConvert  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testConvert.o    -lpvData -lCom
c++ -o testPVStructureArray  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVStructureArray.o    -lpvData -lCom
c++ -o testOperators  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testOperators.o    -lpvData -lCom
c++ -o testFieldBuilder  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testFieldBuilder.o    -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testThread.t testThread
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testEvent.t testEvent
c++ -o testValueBuilder  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testValueBuilder.o    -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testTimer.t testTimer
c++ -o testProperty  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testProperty.o    -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testBitSet.t testBitSet
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testOverrunBitSet.t testOverrunBitSet
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testByteBuffer.t testByteBuffer
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testBaseException.t testBaseException
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testSharedVector.t testSharedVector
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testDebugPtr.t testDebugPtr
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testSerialization.t testSerialization
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testTimeStamp.t testTimeStamp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testTypeCast.t testTypeCast
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testUnitTest.t testUnitTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testjson.t testjson
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 test_reftrack.t test_reftrack
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testanyscalar.t testanyscalar
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testprinter.t testprinter
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testBitSetUtil.t testBitSetUtil
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testIntrospect.t testIntrospect
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVType.t testPVType
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testStandardField.t testStandardField
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testStandardPVField.t testStandardPVField
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVData.t testPVData
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVUnion.t testPVUnion
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testConvert.t testConvert
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVScalarArray.t testPVScalarArray
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVStructureArray.t testPVStructureArray
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testOperators.t testOperators
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testFieldBuilder.t testFieldBuilder
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testValueBuilder.t testValueBuilder
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testProperty.t testProperty
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/copy/testCreateRequest.cpp
c++ -o testCreateRequest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testCreateRequest.o    -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testCreateRequest.t testCreateRequest
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules'
configure/RULES_DIRS:85: recipe for target 'modules.install.darwin-x86' failed
make: *** [modules.install.darwin-x86] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
Notifying upstream projects of job completion
Email was triggered for: Failure - Any
Sending email for trigger: Failure - Any
Sending email to: core-talk at aps.anl.gov
epics-7.0 » mac - Build # 379 - Fixed! APS Jenkins via Core-talk
Prev: epics-7.0 » linux32 - Build # 378 - Failure! APS Jenkins via Core-talk
Next: epics-7.0 » mac - Build # 379 - Fixed! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: epics-7.0 » linux32 - Build # 379 - Fixed! APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
