2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: Windows builds — can anyone explain this?
From: Freddie Akeroyd - STFC UKRI via Core-talk <core-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Thu, 27 Jan 2022 00:41:45 +0000
Sorry, I see you already said that – for some reason my outlook client put that sentence in a really small font at the end and I didn’t see it initially. Not sure why it works in one case and not the other, but will see if I can determine that
Freddie
Sent: 27 January 2022 00:38
To: Johnson, Andrew N. <anj at anl.gov>
Cc: core-talk at aps.anl.gov
Hi Andrew,
I get that error in our builds too, but just for simmTest and nowhere else in the log. I can remove it by adjusting the path for MSI in the build rule with either
$(abspath $(MSI3_15)) -D $(DBFLAGS) -o $(COMMONDEP_TARGET) -S$< $(TEMPLATE_FILENAME) > $@
Or
$(subst /,\,$(MSI3_15)) -D $(DBFLAGS) -o $(COMMONDEP_TARGET) -S$< $(TEMPLATE_FILENAME) > $@
For some reason it doesn’t like ../..  at that time and errors at the first .. but giving it a ..\.. path instead works ok
Freddie
From: Core-talk <core-talk-bounces at aps.anl.gov> On Behalf Of Johnson, Andrew N. via Core-talk
Sent: 24 January 2022 23:47
To: EPICS core-talk <core-talk at aps.anl.gov>
Subject: Windows builds — can anyone explain this?
Here are 2 excerpts from the most recent APS Jenkins build log of the 7.0 tree on windows-x64 when it’s running msi.exe. Can anyone with Windows experience explain why the second call to msi succeeds without giving the same error as the first one? The first call happens while GNUmake is recreating its makefiles (which is what .d files really are) so the failure there isn’t supposed to stop the build. Do you see the same failure on your builds?
../../../../../../bin/windows-x64/msi.exe -D    -I. -I.. -I../O.Common -I../../../../../../db -o ../O.Common/simmTest.db -S../simmTest.substitutions  > simmTest.db.d
'..' is not recognized as an internal or external command,
operable program or batch file.
"Inflating database from ../simmTest.substitutions "
../../../../../../bin/windows-x64/msi.exe    -I. -I.. -I../O.Common -I../../../../../../db -o simmTest.db -S../simmTest.substitutions
The error “'..' is not recognized as an internal or external command” happens when we use forward-slashes in a Windows command path, which we do above so I know that needs fixing, but why doesn’t it fail the second time we call msi.exe?
The build rules for the first command are:
%.db$(DEP): ../%$(SUBST_SUFFIX)
@$(RM) $@
$(MSI3_15) -D $(DBFLAGS) -o $(COMMONDEP_TARGET) -S$< $(TEMPLATE_FILENAME) > $@
and for the second:
$(COMMON_DIR)/%.db: ../%$(SUBST_SUFFIX)
$(ECHO) "Inflating database from $< $(TEMPLATE_FILENAME)"
@$(RM) $(notdir $@)
$(MSI3_15) $(DBFLAGS) -o $(notdir $@) -S$< $(TEMPLATE_FILENAME)
@$(MV) $(notdir $@) $@
Any ideas?
- Andrew
Complexity comes for free, simplicity you have to work for.
@$(RM) $@
and for the second:
@$(RM) $(notdir $@)
Any ideas?
- Andrew
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
RE: Windows builds — can anyone explain this? Freddie Akeroyd - STFC UKRI via Core-talk
Windows builds — can anyone explain this? Johnson, Andrew N. via Core-talk
Prev: RE: Windows builds — can anyone explain this? Freddie Akeroyd - STFC UKRI via Core-talk
Next: RE: Windows builds — can anyone explain this? Freddie Akeroyd - STFC UKRI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
