See <https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/294/display/redirect>
Changes:
Started by upstream project "epics-pvData-linux32" build number 222
originally caused by:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/>
The recommended git tool is: NONE
No credentials specified
> git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/.git> # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://github.com/epics-base/normativeTypesCPP.git # timeout=10
Cleaning workspace
> git rev-parse --verify HEAD # timeout=10
Resetting working tree
> git reset --hard # timeout=10
> git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/normativeTypesCPP.git
> git --version # timeout=10
> git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://github.com/epics-base/normativeTypesCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 7a2d264f2cb107bfd10adb23bc2b73d8323a79e4 (refs/remotes/origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 7a2d264f2cb107bfd10adb23bc2b73d8323a79e4 # timeout=10
Commit message: "removed empty lines at end of file"
> git rev-list --no-walk 7a2d264f2cb107bfd10adb23bc2b73d8323a79e4 # timeout=10
[epics-normativeTypes-linux32] $ /bin/sh -xe /tmp/jenkins2614753846831845082.sh
+ echo 'PVDATA = /local/jenkins/workspace/epics-pvData-linux32'
+ echo 'PVCOMMON = /local/jenkins/workspace/epics-pvCommon-linux32'
+ echo 'EPICS_BASE = /local/jenkins/workspace/epics-base-3.16-linux32'
+ make linux-x86
make -C ./configure linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/configure'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/configure/O.linux-x86'>
Installing CFG file ../../cfg/CONFIG_NTYPES_VERSION
mkdir ../../cfg
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/convertRelease.pl checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/configure/O.linux-x86'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/configure'>
make -C ./src linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/src'>
mkdir -p O.Common
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/src/O.linux-x86'>
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntndarrayAttribute.d ../ntndarrayAttribute.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF nturi.d ../nturi.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF nthistogram.d ../nthistogram.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntcontinuum.d ../ntcontinuum.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntattribute.d ../ntattribute.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntaggregate.d ../ntaggregate.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntunion.d ../ntunion.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntenum.d ../ntenum.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntmatrix.d ../ntmatrix.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntndarray.d ../ntndarray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntscalarMultiChannel.d ../ntscalarMultiChannel.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntmultiChannel.d ../ntmultiChannel.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF nttable.d ../nttable.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntnameValue.d ../ntnameValue.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntscalarArray.d ../ntscalarArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntscalar.d ../ntscalar.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntfield.d ../ntfield.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntid.d ../ntid.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include -MM -MF ntutils.d ../ntutils.cpp
Installing generic include file ../../include/pv/nt.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/ntutils.h
Installing generic include file ../../include/pv/ntid.h
Installing generic include file ../../include/pv/ntfield.h
Installing generic include file ../../include/pv/ntscalar.h
Installing generic include file ../../include/pv/ntscalarArray.h
Installing generic include file ../../include/pv/ntnameValue.h
Installing generic include file ../../include/pv/nttable.h
Installing generic include file ../../include/pv/ntmultiChannel.h
Installing generic include file ../../include/pv/ntscalarMultiChannel.h
Installing generic include file ../../include/pv/ntndarray.h
Installing generic include file ../../include/pv/ntmatrix.h
Installing generic include file ../../include/pv/ntenum.h
Installing generic include file ../../include/pv/ntunion.h
Installing generic include file ../../include/pv/ntaggregate.h
Installing generic include file ../../include/pv/ntattribute.h
Installing generic include file ../../include/pv/ntcontinuum.h
Installing generic include file ../../include/pv/nthistogram.h
Installing generic include file ../../include/pv/nturi.h
Installing generic include file ../../include/pv/ntndarrayAttribute.h
make[2]: *** No rule to make target '../../lib/linux-x86/libpvData.a', needed by 'libnt.a'. Stop.
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/src/O.linux-x86'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_ARCHS:62: recipe for target 'linux-x86' failed
make[1]: *** [linux-x86] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-normativeTypes-linux32/ws/src'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'src.linux-x86' failed
make: *** [src.linux-x86] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.linux-x86/*.tap
Did not find any matching files.
- Jenkins build is back to normal : epics-normativeTypes-linux32 #295 APS Jenkins via Core-talk
Build failed in Jenkins: epics-pvAccess-linux32 #455 APS Jenkins via Core-talk
Build failed in Jenkins: epics-pvDatabase-linux32 #508 APS Jenkins via Core-talk
<2022>
2025
2026
Jenkins build is back to normal : epics-pvAccess-linux32 #456 APS Jenkins via Core-talk
<2022>
2025
2026
