2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Build failed in Jenkins: epics-pvDatabase-linux32 #508
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 27 Jan 2022 10:39:02 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/508/display/redirect>
Changes:
Started by upstream project "epics-pvAccess-linux32" build number 455
originally caused by:
 Started by upstream project "epics-pvData-linux32" build number 222
  Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/.git> # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://github.com/epics-base/pvDatabaseCPP.git # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvDatabaseCPP.git
 > git --version # timeout=10
 > git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://github.com/epics-base/pvDatabaseCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 05d54c61e169587aeac2f82005be495cf45e0163 (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 05d54c61e169587aeac2f82005be495cf45e0163 # timeout=10
Commit message: "Merge pull request #75 from sveseli/master"
 > git rev-list --no-walk 05d54c61e169587aeac2f82005be495cf45e0163 # timeout=10
[epics-pvDatabase-linux32] $ /bin/sh -xe /tmp/jenkins8967345469096117337.sh
+ echo 'PVASRV = /local/jenkins/workspace/epics-pvaSrv-linux32'
+ echo 'PVACCESS = /local/jenkins/workspace/epics-pvAccess-linux32'
+ echo 'PVDATA = /local/jenkins/workspace/epics-pvData-linux32'
+ echo 'PVCOMMON = /local/jenkins/workspace/epics-pvCommon-linux32'
+ echo 'EPICS_BASE = /local/jenkins/workspace/epics-base-3.16-linux32'
+ make linux-x86
make -C ./configure linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/configure'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/configure/O.linux-x86'>
Installing CFG file ../../cfg/CONFIG_PVDATABASE_VERSION
mkdir ../../cfg
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/convertRelease.pl checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/configure/O.linux-x86'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/configure'>
make -C ./src linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/src'>
mkdir -p O.Common
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/src/O.linux-x86'>
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvdbcrTraceRecord.d  ../../src/special/pvdbcrTraceRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvdbcrProcessRecord.d  ../../src/special/pvdbcrProcessRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvdbcrRemoveRecord.d  ../../src/special/pvdbcrRemoveRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvdbcrAddRecord.d  ../../src/special/pvdbcrAddRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvdbcrScalarArrayRecord.d  ../../src/special/pvdbcrScalarArrayRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvdbcrScalarRecord.d  ../../src/special/pvdbcrScalarRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF scalarAlarmSupport.d  ../../src/support/scalarAlarmSupport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF controlSupport.d  ../../src/support/controlSupport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF registerChannelProviderLocal.d  ../../src/pvAccess/registerChannelProviderLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF monitorFactory.d  ../../src/pvAccess/monitorFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF channelLocal.d  ../../src/pvAccess/channelLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF channelProviderLocal.d  ../../src/pvAccess/channelProviderLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvDatabase.d  ../../src/database/pvDatabase.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvRecord.d  ../../src/database/pvRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvTimestampPlugin.d  ../../src/copy/pvTimestampPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvDeadbandPlugin.d  ../../src/copy/pvDeadbandPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvArrayPlugin.d  ../../src/copy/pvArrayPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvCopy.d  ../../src/copy/pvCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include   -I/local/jenkins/workspace/epics-pvCommon-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvPlugin.d  ../../src/copy/pvPlugin.cpp
Installing dbd file ../../dbd/registerChannelProviderLocal.dbd
mkdir ../../dbd
Installing dbd file ../../dbd/pvdbcrScalarRecord.dbd
Installing dbd file ../../dbd/pvdbcrScalarArrayRecord.dbd
Installing dbd file ../../dbd/pvdbcrAddRecord.dbd
Installing dbd file ../../dbd/pvdbcrRemoveRecord.dbd
Installing dbd file ../../dbd/pvdbcrProcessRecord.dbd
Installing dbd file ../../dbd/pvdbcrTraceRecord.dbd
Installing dbd file ../../dbd/pvdbcrAllRecords.dbd
Installing generic include file ../../include/pv/pvPlugin.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/pvStructureCopy.h
Installing generic include file ../../include/pv/pvArrayPlugin.h
Installing generic include file ../../include/pv/pvDeadbandPlugin.h
Installing generic include file ../../include/pv/pvTimestampPlugin.h
Installing generic include file ../../include/pv/pvDatabase.h
Installing generic include file ../../include/pv/channelProviderLocal.h
Installing generic include file ../../include/pv/pvSupport.h
Installing generic include file ../../include/pv/controlSupport.h
Installing generic include file ../../include/pv/scalarAlarmSupport.h
Installing generic include file ../../include/pv/pvdbcrScalarRecord.h
Installing generic include file ../../include/pv/pvdbcrScalarArrayRecord.h
Installing generic include file ../../include/pv/pvdbcrAddRecord.h
Installing generic include file ../../include/pv/pvdbcrRemoveRecord.h
Installing generic include file ../../include/pv/pvdbcrProcessRecord.h
Installing generic include file ../../include/pv/pvdbcrTraceRecord.h
make[2]: *** No rule to make target '../../lib/linux-x86/libpvData.a', needed by 'libpvDatabase.a'.  Stop.
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/src/O.linux-x86'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_ARCHS:62: recipe for target 'linux-x86' failed
make[1]: *** [linux-x86] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvDatabase-linux32/ws/src'>
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'src.linux-x86' failed
make: *** [src.linux-x86] Error 2
Build step 'Execute shell' marked build as failure
Jenkins build is back to normal : epics-pvDatabase-linux32 #509 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-normativeTypes-linux32 #294 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-pvaClient-linux32 #710 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-normativeTypes-linux32 #295 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-pvDatabase-linux32 #509 APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
