2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Build failed in Jenkins: epics-pvaClient-linux32 #710
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 27 Jan 2022 10:39:12 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/710/display/redirect>
Changes:
Started by upstream project "epics-pvAccess-linux32" build number 455
originally caused by:
 Started by upstream project "epics-pvData-linux32" build number 222
  Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/.git> # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://github.com/epics-base/pvaClientCPP.git # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvaClientCPP.git
 > git --version # timeout=10
 > git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://github.com/epics-base/pvaClientCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 8ed07fef96e41d35d47ab61276e29eb1a81e7fec (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 8ed07fef96e41d35d47ab61276e29eb1a81e7fec # timeout=10
Commit message: "Set next development version"
 > git rev-list --no-walk 8ed07fef96e41d35d47ab61276e29eb1a81e7fec # timeout=10
[epics-pvaClient-linux32] $ /bin/sh -xe /tmp/jenkins4289466886357681180.sh
+ echo 'PVDATABASE = /local/jenkins/workspace/epics-pvDatabase-linux32'
+ echo 'PVACCESS = /local/jenkins/workspace/epics-pvAccess-linux32'
+ echo 'NORMATIVE = /local/jenkins/workspace/epics-normativeTypes-linux32'
+ echo 'PVDATA = /local/jenkins/workspace/epics-pvData-linux32'
+ echo 'EPICS_BASE = /local/jenkins/workspace/epics-base-3.16-linux32'
+ /local/jenkins/bin/make -O -j3 linux-x86
/local/jenkins/bin/make -C ./configure linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/configure'>
mkdir -p O.Common
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/configure'>
perl -CSD /local/jenkins/workspace/epics-base-3.16-linux32/bin/linux-x86/makeMakefile.pl O.linux-x86 ../..
/local/jenkins/bin/make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/configure/O.linux-x86'>
Installing CFG file ../../cfg/CONFIG_PVACLIENT_VERSION
mkdir ../../cfg
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/configure/O.linux-x86'>
/local/jenkins/bin/make -C ./src linux-x86
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/src'>
mkdir -p O.Common
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/src'>
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/src/O.linux-x86'>
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientNTMultiMonitor.d  ../pvaClientNTMultiMonitor.cpp
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaClient-linux32/ws/src/O.linux-x86'>
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientRPC.d  ../pvaClientRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientNTMultiGet.d  ../pvaClientNTMultiGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientNTMultiPut.d  ../pvaClientNTMultiPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientNTMultiData.d  ../pvaClientNTMultiData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientMultiMonitorDouble.d  ../pvaClientMultiMonitorDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientMultiGetDouble.d  ../pvaClientMultiGetDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientMultiPutDouble.d  ../pvaClientMultiPutDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientMultiChannel.d  ../pvaClientMultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientMonitor.d  ../pvaClientMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientPutGet.d  ../pvaClientPutGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientPut.d  ../pvaClientPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientGet.d  ../pvaClientGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientProcess.d  ../pvaClientProcess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientChannel.d  ../pvaClientChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientMonitorData.d  ../pvaClientMonitorData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientGetData.d  ../pvaClientGetData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientPutData.d  ../pvaClientPutData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClientData.d  ../pvaClientData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/local/jenkins/workspace/epics-pvDatabase-linux32/include   -I/local/jenkins/workspace/epics-pvAccess-linux32/include   -I/local/jenkins/workspace/epics-normativeTypes-linux32/include   -I/local/jenkins/workspace/epics-pvData-linux32/include -I/local/jenkins/workspace/epics-base-3.16-linux32/include/compiler/gcc -I/local/jenkins/workspace/epics-base-3.16-linux32/include/os/Linux -I/local/jenkins/workspace/epics-base-3.16-linux32/include        -MM -MF pvaClient.d  ../pvaClient.cpp
make[2]: *** No rule to make target '../../lib/linux-x86/libnt.a', needed by 'libpvaClient.a'.  Stop.
make[2]: *** Waiting for unfinished jobs....
mkdir ../../include
mkdir ../../include/pv
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_ARCHS:62: recipe for target 'linux-x86' failed
make[1]: *** [linux-x86] Error 2
/local/jenkins/workspace/epics-base-3.16-linux32/configure/RULES_DIRS:84: recipe for target 'src.linux-x86' failed
make: *** [src.linux-x86] Error 2
Build step 'Execute shell' marked build as failure
Jenkins build is back to normal : epics-pvaClient-linux32 #711 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-pvDatabase-linux32 #508 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-example-linux32 #890 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-pvDatabase-linux32 #509 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-pvaClient-linux32 #711 APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
