2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Build failed in Jenkins: epics-pvaPy-linux32 #970
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 28 Jan 2022 19:47:27 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/970/display/redirect?page=changes>
Changes:
[Veseli, Sinisa] distutils are being deprecated
[Veseli, Sinisa] save epics/boost build for osx
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/.git> # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://github.com/epics-base/pvaPy.git # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvaPy.git
 > git --version # timeout=10
 > git --version # 'git version 1.7.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://github.com/epics-base/pvaPy.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 4eed89b8a5859ae5742682aa3fccc6c6376a57ae (refs/remotes/origin/master)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 4eed89b8a5859ae5742682aa3fccc6c6376a57ae # timeout=10
Commit message: "save epics/boost build for osx"
 > git rev-list --no-walk 7b4cf78cfd72c510435e6ce3d000c1fd6f93c370 # timeout=10
[epics-pvaPy-linux32] $ /bin/sh -xe /tmp/jenkins140962067452505742.sh
+ rm -rf epics
+ mkdir -p epics
+ ln -s /local/jenkins/workspace/epics-base-3.16-linux32 epics/base
+ ln -s /local/jenkins/workspace/epics-pvCommon-linux32 epics/pvCommonCPP
+ ln -s /local/jenkins/workspace/epics-pvData-linux32 epics/pvDataCPP
+ ln -s /local/jenkins/workspace/epics-normativeTypes-linux32 epics/normativeTypesCPP
+ ln -s /local/jenkins/workspace/epics-pvAccess-linux32 epics/pvAccessCPP
+ ln -s /local/jenkins/workspace/epics-pvaClient-linux32 epics/pvaClientCPP
+ ln -s /local/jenkins/workspace/epics-pvDatabase-linux32 epics/pvDatabaseCPP
+ EPICS_BASE=<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base>
+ EPICS4_DIR=<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics>
+ make configure
autoreconf --install tools/autoconf
configure.ac:2: installing `./install-sh'
configure.ac:2: installing `./missing'
tools/autoconf/configure --with-top=.
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... none
checking for python... /usr/bin/python
checking for a version of Python >= '2.1.0'... yes
checking for Python include path... Traceback (most recent call last):
  File "<string>", line 1, in <module>
ImportError: No module named sysconfig
checking for Python library path... Traceback (most recent call last):
  File "<stdin>", line 4, in <module>
  File "<stdin>", line 3, in <module>
  File "<stdin>", line 2, in <module>
-L -lpython2.6
checking for Python site-packages path... Traceback (most recent call last):
checking python extra libraries... Traceback (most recent call last):
checking python extra linking flags... Traceback (most recent call last):
checking consistency of all components of python development environment... no
configure: error: in `<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/'>:
configure: error:
  Could not link test program to Python. Maybe the main Python library has been
  installed in some non-standard library path. If so, pass it to configure,
  via the LDFLAGS environment variable.
  Example: ./configure LDFLAGS="-L/usr/non-standard-path/python/lib"
   ERROR!
   You probably have to install the development version of the Python package
   for your distribution.  The exact name of this package varies among them.
See `config.log' for more details.
Makefile:53: recipe for target 'configure' failed
make: *** [configure] Error 1
Build step 'Execute shell' marked build as failure
Jenkins build is back to normal : epics-pvaPy-linux32 #971 APS Jenkins via Core-talk
Prev: [Bug 1959457] [NEW] pvget/pvput for aai/aao record types, with data type=enum, wrong results Jerzy Tarasiuk via Core-talk
Next: Jenkins build is back to normal : epics-pvaPy-linux32 #971 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
