2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: lgtm.com, and a heads-up about gcc 10
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Andrew Johnson <anj at anl.gov>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 14 Feb 2022 13:09:13 -0800
On 2/14/22 11:06, Andrew Johnson via Core-talk wrote:
I've been spending a few minutes playing with a code security analysis site lgtm.com <https://lgtm.com/> which seems to be related to GitHub somehow. It was already doing something with Base when I found it (but only the Python code analysis was working). I tried configuring it to actually build Base but the build failed because it seems to be using GCC-10. Here's the section of my build log <https://lgtm.com/logs/73be3c22d3f026355b2ea6f03ffead65696a2358/lang:cpp> showing the failure, in modules/pvData/testApp:
I'm not sure what to make of this.  Since upgrading to Debian 11, I've been
successfully building Base et. al. with gcc 10.2.1.  I don't see this
"inlining failed in call to always_inline" message as either a warning
or an error (when building for amd64).
[2022-02-14 18:26:31] [build-stdout] /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/opt/src/include/compiler/gcc -I/opt/src/include/os/Linux -I/opt/src/include -I/opt/src/include/compiler/gcc -I/opt/src/include/os/Linux -I/opt/src/include -c ../../testApp/misc/testSharedVector.cpp [2022-02-14 18:26:32] [build-stderr] In file included from /opt/src/include/pv/pvData.h:23, [2022-02-14 18:26:32] [build-stderr] from /opt/src/include/pv/pvUnitTest.h:15, [2022-02-14 18:26:32] [build-stderr] from ../../testApp/misc/testSharedVector.cpp:15: [2022-02-14 18:26:32] [build-stderr] /opt/src/include/pv/typeCast.h: In static member function ‘static epics::pvData::shared_vector<TO> epics::pvData::detail::shared_vector_converter<TO, FROM, Enable>::op(const epics::pvData::shared_vector<FROM>&) [with TO = float; FROM = int; Enable = void]’: [2022-02-14 18:26:32] [build-stderr] /opt/src/include/pv/typeCast.h:195:24: error: inlining failed in call to always_inline ‘TO epics::pvData::castUnsafe(const FROM&) [with TO = float; FROM = int]’: indirect function call with a yet undetermined callee [2022-02-14 18:26:32] [build-stderr] 195 | static FORCE_INLINE TO castUnsafe(const FROM& from) [2022-02-14 18:26:32] [build-stderr] | ^~~~~~~~~~ [2022-02-14 18:26:32] [build-stderr] In file included from /usr/include/c++/9/algorithm:62, [2022-02-14 18:26:32] [build-stderr] from /opt/src/include/pv/pvData.h:15, [2022-02-14 18:26:32] [build-stderr] from /opt/src/include/pv/pvUnitTest.h:15, [2022-02-14 18:26:32] [build-stderr] from ../../testApp/misc/testSharedVector.cpp:15: [2022-02-14 18:26:32] [build-stderr] /usr/include/c++/9/bits/stl_algo.h:4337:24: note: called from here [2022-02-14 18:26:32] [build-stderr] 4337 | *__result = __unary_op(*__first); [2022-02-14 18:26:32] [build-stderr] | ~~~~~~~~~~^~~~~~~~~~ [2022-02-14 18:26:32] [build-stderr] In file included from /opt/src/include/pv/pvData.h:23, [2022-02-14 18:26:32] [build-stderr] from /opt/src/include/pv/pvUnitTest.h:15, [2022-02-14 18:26:32] [build-stderr] from ../../testApp/misc/testSharedVector.cpp:15: [2022-02-14 18:26:32] [build-stderr] /opt/src/include/pv/typeCast.h: In static member function ‘static epics::pvData::shared_vector<TO> epics::pvData::detail::shared_vector_converter<TO, FROM, Enable>::op(const epics::pvData::shared_vector<FROM>&) [with TO = double; FROM = int; Enable = void]’: [2022-02-14 18:26:32] [build-stderr] /opt/src/include/pv/typeCast.h:195:24: error: inlining failed in call to always_inline ‘TO epics::pvData::castUnsafe(const FROM&) [with TO = double; FROM = int]’: indirect function call with a yet undetermined callee [2022-02-14 18:26:32] [build-stderr] 195 | static FORCE_INLINE TO castUnsafe(const FROM& from) [2022-02-14 18:26:32] [build-stderr] | ^~~~~~~~~~ [2022-02-14 18:26:32] [build-stderr] In file included from /usr/include/c++/9/algorithm:62, [2022-02-14 18:26:32] [build-stderr] from /opt/src/include/pv/pvData.h:15, [2022-02-14 18:26:32] [build-stderr] from /opt/src/include/pv/pvUnitTest.h:15, [2022-02-14 18:26:32] [build-stderr] from ../../testApp/misc/testSharedVector.cpp:15: [2022-02-14 18:26:32] [build-stderr] /usr/include/c++/9/bits/stl_algo.h:4337:24: note: called from here [2022-02-14 18:26:32] [build-stderr] 4337 | *__result = __unary_op(*__first); [2022-02-14 18:26:32] [build-stderr] | ~~~~~~~~~~^~~~~~~~~~ [2022-02-14 18:26:34] [build-stdout] make[4]: Leaving directory '/opt/src/modules/pvData/testApp/O.linux-x86_64'
To play with it on lgtm.com (which builds on a recent version of Ubuntu) you can paste in some analysis configuration YAML here <https://lgtm.com/builds/test/g/epics-base/epics-base> to configure it without having to add a file to the repo, this is what I used to get the above:
|extraction: cpp: index: build_command: "make"|
It is possible to tell it to install a different version of gcc using a prepare: section but I don't know what the right packages would be. It was interesting to see that it automatically installed g++ /during/ the above build the first time it was called, is that something which Ubuntu does (or can do) now?
Not sure if this is likely to be useful for us, but I thought it might be worth exploring. I haven't been able to look into the actual code analysis it can do yet.
- Andrew
Complexity comes for free, Simplicity you have to work for.
lgtm.com, and a heads-up about gcc 10 Andrew Johnson via Core-talk
Prev: lgtm.com, and a heads-up about gcc 10 Andrew Johnson via Core-talk
Next: epics-7.0 » linux32 - Build # 383 - Fixed! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Build failed: EPICS Base 7 base-7.0-472 AppVeyor via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
