2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: epics-pva2pva-linux32 - Build # 235 - Unstable!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 5 Jul 2022 14:30:27 -0500 (CDT)
Build and test the EPICS v4 pva2pva module on 32-bit Linux
Triggered by: epics-pvAccess-linux32
Join trigger: epics-example-linux32
Build URL: https://jenkins.aps.anl.gov/job/epics-pva2pva-linux32/235/
This job built successfully, but has failing tests.
Test results:
testmon.tap .. ok
All tests successful.
Files=1, Tests=79,  0 wallclock secs ( 0.07 usr +  0.01 sys =  0.08 CPU)
Result: PASS
testweak.tap ......... ok
testtest.tap ......... ok
testpvif.tap ......... ok
testpdb.tap .......... ok
testpvalink.tap ......
Failed 5/20 subtests
testgroupconfig.tap .. ok
testdbf_copy.tap ..... ok
Test Summary Report
testpvalink.tap    (Wstat: 0 Tests: 15 Failed: 0)
  Parse errors: Bad plan.  You planned 20 tests but ran 15.
Files=7, Tests=358,  1 wallclock secs ( 0.20 usr  0.04 sys +  0.01 cusr  0.02 csys =  0.27 CPU)
Result: FAIL
epics-pva2pva-linux32 - Build # 236 - Still Unstable! APS Jenkins via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-612 AppVeyor via Core-talk
Next: Build completed: pva2pva 1.0.36 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: epics-pva2pva-linux32 - Build # 236 - Still Unstable! APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
