Build and test the EPICS v4 pva2pva module on 32-bit Linux Triggered by: epics-pvAccess-linux32 Build URL: https://jenkins.aps.anl.gov/job/epics-pva2pva-linux32/236/ This job built successfully, but has failing tests. Test results: testmon.tap .. ok All tests successful. Files=1, Tests=79, 0 wallclock secs ( 0.13 usr + 0.00 sys = 0.13 CPU) Result: PASS testweak.tap ......... ok testtest.tap ......... ok testpvif.tap ......... ok testpdb.tap .......... ok testpvalink.tap ...... Failed 5/20 subtests testgroupconfig.tap .. ok testdbf_copy.tap ..... ok Test Summary Report ------------------- testpvalink.tap (Wstat: 0 Tests: 15 Failed: 0) Parse errors: Bad plan. You planned 20 tests but ran 15. Files=7, Tests=358, 1 wallclock secs ( 0.36 usr 0.04 sys + 0.00 cusr 0.02 csys = 0.42 CPU) Result: FAIL
| ANJ, 26 Oct 2022 |
Home
News
About
Talk
Base
Modules
Extensions
