@mdavidsave correct, pnRequest must never be NULL since (unless you pass
in a bad dbrType) it will always be dereferenced to populate
parser->elems and will be written to if the parse succeeds.
Could the two "if (status == S_db_badField)" tests in dbConstLink.c
become just "if (status)" please, since we'd almost certainly want the
same context message to be printed for any other error status values get
returned from the same routine. Add a space after the ellipsis in each
message perhaps?
With those suggestions this looks good to me, thanks!
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1982847
Title:
cryptic error message "parse error: premature EOF"
Status in EPICS Base:
New
Bug description:
In EPICS 7, if an array input link (e.g. waveform.INP) is an explicit
empty string, the parser prints a cryptic message without any helpful
context.
Example:
record(waveform, "x")
field(INP, "")
dbConvertJSON: parse error: premature EOF
(right here) ------^
Not very enlightening.
It does not happen if INP is not set at all and it does not happen at least up to R3.16.1 but at least since 7.0.4.1 (I have not tested anything in between) and up to commit d82ab81.
It also does not happen with scalar input links (e.g. ai.INP).
First of all, any parser error should print a context (I prefer record.field) similar to this:
dbConvertJSON: parse error: premature EOF in x.INP
Unfortunately, dbPutConvertJSON (the function printing the
dbConvertJSON message) does not have the context. All it has is the
string. So maybe it should not print the message at all but leave it
to the caller. The only callers are in dbConstLink.c. The interface
should be modified to pass either the context (plink instead of
plink->value.constantStr) or the error message (which is complicated)
or an additional message should be printed by the outer context
(difficult to find out when dbPutConvertJSON actually printed an error
message).
Second, passing "" should not result in an error at all.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1982847/+subscriptions
- [Bug 1982847] [NEW] cryptic error message "parse error: premature EOF" Dirk Zimoch via Core-talk
[Bug 1982847] Re: cryptic error message "parse error: premature EOF" Dirk Zimoch via Core-talk
<2022>
2025
2026
<2022>
2025
2026
