Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/412/ This job failed to build. Started by upstream project "epics-7.0" build number 412 originally caused by: Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Started by an SCM change Running as SYSTEM [EnvInject] - Loading node environment variables. Building on the built-in node in workspace /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64 The recommended git tool is: NONE No credentials specified > git rev-parse --resolve-git-dir /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/.git # timeout=10 Fetching changes from the remote Git repository > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10 Fetching upstream changes from https://git.launchpad.net/epics-base/ > git --version # timeout=10 > git --version # 'git version 1.8.3.1' Setting http proxy: webproxy1.anl.gov:9091 > git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10 Checking out Revision 007279cf2905cd006879b780a50faeb592d20cd9 (refs/remotes/origin/7.0) > git config core.sparsecheckout # timeout=10 > git checkout -f 007279cf2905cd006879b780a50faeb592d20cd9 # timeout=10 Commit message: "Release notes updated" > git rev-list --no-walk d82ab819ef751f5c1f0c7e4427cbef466fc4629e # timeout=10 Cleaning workspace > git rev-parse --verify HEAD # timeout=10 Resetting working tree > git reset --hard # timeout=10 > git clean -fdx # timeout=10 > git submodule foreach --recursive git reset --hard # timeout=10 > git submodule foreach git clean -fdx # timeout=10 > git remote # timeout=10 > git submodule init # timeout=10 > git submodule sync # timeout=10 > git config --get remote.origin.url # timeout=10 > git submodule init # timeout=10 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10 > git config --get submodule.modules/pvData.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10 > git config --get submodule.modules/pvAccess.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10 > git config --get submodule.modules/normativeTypes.url # timeout=10 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10 > git config --get submodule.modules/pvaClient.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10 > git config --get submodule.modules/pvDatabase.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10 > git config --get submodule.modules/pva2pva.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10 > git config --get submodule..ci.url # timeout=10 > git config -f .gitmodules --get submodule..ci.path # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvData # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvAccess # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/normativeTypes # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvaClient # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvDatabase # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pva2pva # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update .ci # timeout=10 No emails were triggered. [linux64] $ /bin/sh -xe /tmp/jenkins6992717721415384953.sh + git submodule foreach 'git checkout master && git pull' Entering '.ci' Already on 'master' Your branch is up-to-date with 'origin/master'. >From https://github.com/epics-base/ci-scripts + 8a2666a...aea7906 master -> origin/master (forced update) * [new tag] v3.4.0 -> v3.4.0 Auto-merging github-actions/ci-scripts-build.yml.example-full Auto-merging .github/workflows/build-and-test.yml CONFLICT (content): Merge conflict in .github/workflows/build-and-test.yml Automatic merge failed; fix conflicts and then commit the result. Stopping at '.ci'; script returned non-zero status. Build step 'Execute shell' marked build as failure TAP Reports Processing: START Looking for TAP results report in workspace using pattern: **/O.*/*.tap Did not find any matching files. Notifying upstream projects of job completion Email was triggered for: Failure - Any Sending email for trigger: Failure - Any Sending email to: core-talk at aps.anl.gov
| ANJ, 14 Sep 2022 |
Home
News
About
Talk
Base
Modules
Extensions
