2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-7.0-win64 #325
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 1 Aug 2022 10:37:24 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/325/display/redirect?page=changes>
Changes:
[Michael Davidsaver] osiClockTime.c: Clarify message wording
[Michael Davidsaver] Set useNTP if VxWorks sync task is suspended
[Michael Davidsaver] VxWorks: Re-run tz2timezone() whenever the year increases
[Michael Davidsaver] VxWorks: Stop VxWorks clock sync if EPICS_TS_FORCE_NTPTIME
[Michael Davidsaver] Release notes updated
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/ws/>
The recommended git tool is: NONE
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\epics-base-7.0-win64\.git # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Using shallow fetch with depth 5
Fetching upstream changes from https://git.launchpad.net/epics-base
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
 > git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --no-tags --force --progress --depth=5 -- https://git.launchpad.net/epics-base +refs/heads/7.0:refs/remotes/origin/7.0 # timeout=10
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/7.0^{commit}" # timeout=10
Checking out Revision 007279cf2905cd006879b780a50faeb592d20cd9 (refs/remotes/origin/7.0)
 > C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files/Git/cmd/git.exe checkout -f 007279cf2905cd006879b780a50faeb592d20cd9 # timeout=10
Commit message: "Release notes updated"
 > C:/Program Files/Git/cmd/git.exe rev-list --no-walk d82ab819ef751f5c1f0c7e4427cbef466fc4629e # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
[epics-base-7.0-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins7692957615241576003.bat
jenkins@JEEVES C:\jenkins\win64-2\workspace\epics-base-7.0-win64>make -j4 -O --no-print-directory
'make' is not recognized as an internal or external command,
operable program or batch file.
jenkins@JEEVES C:\jenkins\win64-2\workspace\epics-base-7.0-win64>exit 9009
Build step 'Execute Windows batch command' marked build as failure
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Jenkins build is back to normal : epics-base-7.0-win64 #326 APS Jenkins via Core-talk
Prev: epics-7.0 » linux64 - Build # 412 - Failure! APS Jenkins via Core-talk
Next: epics-7.0 » linux32 - Build # 412 - Failure! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: epics-7.0 » linux64 - Build # 415 - Fixed! APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64 #326 APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
