Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/414/ This job failed to build. Started by upstream project "epics-7.0" build number 414 originally caused by: Started by user Andrew Johnson Running as SYSTEM [EnvInject] - Loading node environment variables. Building remotely on linux32-1 (linux32) in workspace /local/jenkins/workspace/epics-7.0/OS/linux32 The recommended git tool is: NONE No credentials specified > git rev-parse --resolve-git-dir /local/jenkins/workspace/epics-7.0/OS/linux32/.git # timeout=10 Fetching changes from the remote Git repository > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10 Fetching upstream changes from https://git.launchpad.net/epics-base/ > git --version # timeout=10 > git --version # 'git version 1.7.1' Setting http proxy: webproxy1.anl.gov:9091 > git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10 Checking out Revision 007279cf2905cd006879b780a50faeb592d20cd9 (refs/remotes/origin/7.0) > git config core.sparsecheckout # timeout=10 > git checkout -f 007279cf2905cd006879b780a50faeb592d20cd9 # timeout=10 Commit message: "Release notes updated" > git rev-list --no-walk 007279cf2905cd006879b780a50faeb592d20cd9 # timeout=10 Cleaning workspace > git rev-parse --verify HEAD # timeout=10 Resetting working tree > git reset --hard # timeout=10 > git clean -fdx # timeout=10 > git submodule foreach --recursive git reset --hard # timeout=10 > git submodule foreach git clean -fdx # timeout=10 > git remote # timeout=10 > git submodule init # timeout=10 > git submodule sync # timeout=10 > git config --get remote.origin.url # timeout=10 > git submodule init # timeout=10 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10 > git config --get submodule.modules/pvData.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10 > git config --get submodule.modules/pvAccess.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10 > git config --get submodule.modules/normativeTypes.url # timeout=10 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10 > git config --get submodule.modules/pvaClient.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10 > git config --get submodule.modules/pvDatabase.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10 > git config --get submodule.modules/pva2pva.url # timeout=10 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10 > git config --get submodule..ci.url # timeout=10 > git config -f .gitmodules --get submodule..ci.path # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvData # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvAccess # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/normativeTypes # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvaClient # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pvDatabase # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update modules/pva2pva # timeout=10 Setting http proxy: webproxy1.anl.gov:9091 > git submodule update .ci # timeout=10 hudson.plugins.git.GitException: Command "git submodule update .ci" returned status code 1: stdout: stderr: fatal: reference is not a tree: 8a2666a9deeb6c618bcc73ba80f1a83a878c7a84 Unable to checkout '8a2666a9deeb6c618bcc73ba80f1a83a878c7a84' in submodule path '.ci' at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2671) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2096) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:84) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$7.lambda$execute$0(CliGitAPIImpl.java:1505) at com.google.common.util.concurrent.TrustedListenableFutureTask$TrustedFutureInterruptibleTask.runInterruptibly(TrustedListenableFutureTask.java:131) at com.google.common.util.concurrent.InterruptibleTask.run(InterruptibleTask.java:74) at com.google.common.util.concurrent.TrustedListenableFutureTask.run(TrustedListenableFutureTask.java:82) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at com.google.common.util.concurrent.MoreExecutors$DirectExecutorService.execute(MoreExecutors.java:323) at java.util.concurrent.ExecutorCompletionService.submit(ExecutorCompletionService.java:181) at org.jenkinsci.plugins.gitclient.cgit.GitCommandsExecutor.submitRemainingCommand(GitCommandsExecutor.java:98) at org.jenkinsci.plugins.gitclient.cgit.GitCommandsExecutor.invokeAll(GitCommandsExecutor.java:92) Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to linux32-1 at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1784) at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356) at hudson.remoting.Channel.call(Channel.java:1000) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:143) at sun.reflect.GeneratedMethodAccessor148.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:129) at com.sun.proxy.$Proxy75.execute(Unknown Source) at hudson.plugins.git.extensions.impl.SubmoduleOption.onCheckoutCompleted(SubmoduleOption.java:160) at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1393) at hudson.scm.SCM.checkout(SCM.java:540) at hudson.model.AbstractProject.checkout(AbstractProject.java:1217) at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:647) at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85) at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:519) at hudson.model.Run.execute(Run.java:1897) at hudson.matrix.MatrixRun.run(MatrixRun.java:153) at hudson.model.ResourceController.execute(ResourceController.java:101) at hudson.model.Executor.run(Executor.java:442) Caused: hudson.plugins.git.GitException at org.jenkinsci.plugins.gitclient.cgit.GitCommandsExecutor.checkResult(GitCommandsExecutor.java:110) at org.jenkinsci.plugins.gitclient.cgit.GitCommandsExecutor.invokeAll(GitCommandsExecutor.java:91) at org.jenkinsci.plugins.gitclient.cgit.GitCommandsExecutor.invokeAll(GitCommandsExecutor.java:49) at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$7.execute(CliGitAPIImpl.java:1508) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:158) at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:151) at hudson.remoting.UserRequest.perform(UserRequest.java:211) at hudson.remoting.UserRequest.perform(UserRequest.java:54) at hudson.remoting.Request$2.run(Request.java:376) at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) Caused: java.io.IOException: Could not perform submodule update at hudson.plugins.git.extensions.impl.SubmoduleOption.onCheckoutCompleted(SubmoduleOption.java:165) at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1393) at hudson.scm.SCM.checkout(SCM.java:540) at hudson.model.AbstractProject.checkout(AbstractProject.java:1217) at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:647) at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85) at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:519) at hudson.model.Run.execute(Run.java:1897) at hudson.matrix.MatrixRun.run(MatrixRun.java:153) at hudson.model.ResourceController.execute(ResourceController.java:101) at hudson.model.Executor.run(Executor.java:442) TAP Reports Processing: START Looking for TAP results report in workspace using pattern: **/O.*/*.tap Did not find any matching files. Notifying upstream projects of job completion Email was triggered for: Failure - Any Sending email for trigger: Failure - Any Sending email to: core-talk at aps.anl.gov
| ANJ, 14 Sep 2022 |
Home
News
About
Talk
Base
Modules
Extensions
