2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: epics-base/.ci submodule problem
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Andrew Johnson <anj at anl.gov>
Cc: core-talk at aps.anl.gov
Date: Mon, 1 Aug 2022 10:30:25 -0700
On 8/1/22 10:21, Andrew Johnson via Core-talk wrote:
APS Jenkins seems to be unable to clone the epics-base repo (I'm not sure why that just succeeded on macOS, which is running exactly the same commands as the Linux agents) due to something in the .ci submodule.
It looks like there was a force push to 'master' in ci-scripts
some time on or after the 24th.  ("origin/master" in my checkout
was still pointing to the g8a2666a rev.)
So as not to have a dangling submodule reference in the Base history
I have created a tag "v3.3.0-10-g8a2666a" to keep that rev. reachable.
On 8/1/22 11:56 AM, APS Jenkins via Core-talk wrote:
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/413/
This job failed to build.
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > git submodule update modules/pvData # timeout=10
 > git submodule update modules/pvAccess # timeout=10
 > git submodule update modules/normativeTypes # timeout=10
 > git submodule update modules/pvaClient # timeout=10
 > git submodule update modules/pvDatabase # timeout=10
 > git submodule update modules/pva2pva # timeout=10
 > git submodule update .ci # timeout=10
hudson.plugins.git.GitException: Command "git submodule update .ci" returned status code 1:
stdout: Cloning into '.ci'...
stderr: fatal: reference is not a tree: 8a2666a9deeb6c618bcc73ba80f1a83a878c7a84
Unable to checkout '8a2666a9deeb6c618bcc73ba80f1a83a878c7a84' in submodule path '.ci'
I'm guessing we may just need to commit a 'git add .ci; git commit' to the 7.0 branch to fix that but I'm not certain, can someone explain what happened to the ci submodule?
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: epics-base/.ci submodule problem Andrew Johnson via Core-talk
epics-7.0 » linux64 - Build # 412 - Failure! APS Jenkins via Core-talk
epics-7.0 » linux64 - Build # 413 - Still Failing! APS Jenkins via Core-talk
Prev: epics-base/.ci submodule problem Andrew Johnson via Core-talk
Next: epics-7.0 » linux32 - Build # 414 - Still Failing! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: epics-base/.ci submodule problem Andrew Johnson via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
