2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: epics-base/.ci submodule problem
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 1 Aug 2022 12:21:10 -0500
APS Jenkins seems to be unable to clone the epics-base repo (I'm not sure why that just succeeded on macOS, which is running exactly the same commands as the Linux agents) due to something in the .ci submodule.
On 8/1/22 11:56 AM, APS Jenkins via Core-talk wrote:
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/413/
This job failed to build.
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > git submodule update modules/pvData # timeout=10
 > git submodule update modules/pvAccess # timeout=10
 > git submodule update modules/normativeTypes # timeout=10
 > git submodule update modules/pvaClient # timeout=10
 > git submodule update modules/pvDatabase # timeout=10
 > git submodule update modules/pva2pva # timeout=10
 > git submodule update .ci # timeout=10
hudson.plugins.git.GitException: Command "git submodule update .ci" returned status code 1:
stdout: Cloning into '.ci'...
stderr: fatal: reference is not a tree: 8a2666a9deeb6c618bcc73ba80f1a83a878c7a84
Unable to checkout '8a2666a9deeb6c618bcc73ba80f1a83a878c7a84' in submodule path '.ci'
I'm guessing we may just need to commit a 'git add .ci; git commit' to the 7.0 branch to fix that but I'm not certain, can someone explain what happened to the ci submodule?
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: epics-base/.ci submodule problem Michael Davidsaver via Core-talk
epics-7.0 » linux64 - Build # 412 - Failure! APS Jenkins via Core-talk
epics-7.0 » linux64 - Build # 413 - Still Failing! APS Jenkins via Core-talk
Prev: epics-7.0 » mac - Build # 413 - Fixed! APS Jenkins via Core-talk
Next: Re: epics-base/.ci submodule problem Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: epics-7.0 » linux64 - Build # 413 - Still Failing! APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
