2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1983472] Re: Format %z unknown to vxWorks
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 03 Aug 2022 12:29:17 -0000
** Description changed:
  VxWorks even in version 6.9 does not know the printf format specifier
  %z. It will instead print a literal z (and shift all arguments to the
- next format o course).
+ next format of course).
  This is related to bug #1740426 but not exactly the same.
  Affected code in EPICS 7 (as found by grep %z):
  modules/pvData/src/factory/FieldCreateFactory.cpp:    sprintf(buffer, "%s<%zu>", ScalarTypeFunc::name(getElementType()), size);
  modules/pvData/src/factory/FieldCreateFactory.cpp:    sprintf(buffer, "%s[%zu]", ScalarTypeFunc::name(getElementType()), size);
  modules/pvData/testApp/pv/testPVData.cpp:#define SHOW(T) testDiag("sizeof(" #T ")==%zu", sizeof(T))
  modules/pvData/testApp/pv/performstruct.cpp:        printf("# %zu sample   %f +- %f %s\n", count, mean/mult, std/mult, unit);
  modules/pvData/testApp/pv/performstruct.cpp:        sprintf(buf, "field%zu", i);
  modules/pvAccess/pvtoolsSrc/pvlist.cpp:            "Broadcast address #%zu: %s.", i, inetAddressToString(broadcastAddresses[i]).c_str());
  modules/pvAccess/pvtoolsSrc/pvlist.cpp:            LOG(logLevelDebug, "UDP Tx (%zu) -> %s", sendBuffer.getPosition(), strBuffer);
  modules/pvAccess/src/remote/blockingUDPTransport.cpp:        LOG(logLevelDebug, "UDP Tx (%zu) %s -> %s.",
  modules/pvAccess/src/remote/blockingUDPTransport.cpp:        LOG(logLevelDebug, "Sending %zu bytes %s -> %s.",
  modules/pvAccess/src/remote/blockingUDPTransport.cpp:                "Broadcast address #%zu: %s. (%sunicast)", i, inetAddressToString(list[i]).c_str(),
  modules/pvAccess/src/remote/transportRegistry.cpp:    LOG(logLevelDebug, "Context still has %zu transport(s) active and closing...", temp.size());
  modules/pvAccess/src/remote/codec.cpp:            "Transport to %s still has %zu channel(s) active and closing...",
  modules/pvAccess/src/remote/codec.cpp:                "Transport to %s still has %zu client(s) active and closing...",
  modules/pvAccess/src/server/responseHandlers.cpp:                    LOG(logLevelError, "Monitor Logic Error: send outside of window %zu", _window_closed.size());
  modules/pvAccess/src/ioc/reftrackioc.cpp:            printf(" %s : %zu (delta %zd)\n",
  modules/pvAccess/src/ioc/reftrackioc.cpp:            printf(" %s : %zu\n", it->first.c_str(), it->second.current);
  modules/pvAccess/testApp/remote/testmonitorfifo.cpp:        testDiag("Spamming %zu", nfree);
  modules/pvAccess/testApp/remote/testmonitorfifo.cpp:            testDiag("nfree=%zu %c", nfree, (nfree>0)?'T':'F');
  modules/pvAccess/testApp/remote/testmonitorfifo.cpp:            testDiag("Count %d nfree=%zu %c", c, nfree, (nfree>0)?'T':'F');
  modules/pvAccess/testApp/remote/testChannelConnect.cpp:                sprintf(buf, "test%zu", (i+1));
  modules/pva2pva/pdbApp/pdbgroup.cpp:    printf("  Atomic Get/Put:%s Monitor:%s Members:%zu\n",
  modules/pva2pva/pdbApp/pvalink_jlif.cpp:                printf(" #disconn=%zu prov=%s", pval->lchan->num_disconnect, pval->lchan->providerName.c_str());
  modules/pva2pva/pdbApp/pvalink.cpp:            fprintf(stderr, "pvaLink leaves %zu channels open\n",
  modules/pva2pva/pdbApp/pvalink.cpp:                printf("conn=%c %zu disconnects, %zu type changes",
  modules/pva2pva/pdbApp/pvalink.cpp:        printf("  %zu/%zu channels connected used by %zu links\n",
  modules/pva2pva/testApp/testpdb.cpp:            testDiag("Cnt %s = %zu (%ld)", it->first.c_str(), it->second.current, it->second.delta);
  modules/libcom/test/epicsErrlogTest.c:    testOk(pvt.count >= N && pvt.count<=N+2, "Logged %u messages, expected %zu", pvt.count, N+1);
  modules/libcom/test/yajl_test.c:                fprintf(stderr, "%zu is an invalid buffer size\n",
  modules/libcom/test/yajl_test.c:                "failed to allocate read buffer of %zu bytes, exiting.",
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1983472
Title:
Status in EPICS Base:
  New
Bug description:
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1983472/+subscriptions
[Bug 1983472] [NEW] Format %z unknown to vxWorks Dirk Zimoch via Core-talk
Prev: [Bug 1983472] [NEW] Format %z unknown to vxWorks Dirk Zimoch via Core-talk
Next: [Bug 1983385] Re: iocLogPrefix incompatible with VxWorks logMsg Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: [Bug 1740426] Re: portable printf() spec for size_t, long long, and others mdavidsaver via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
