Hi Dirk,
On 8/26/22 8:05 AM, Zimoch Dirk (PSI) via Core-talk wrote:
Since I migrated most of our IOCs from VxWorks 5.5 to VxWorks 6.9, I notices a severe network driver problem.
After running fine for weeks or months, suddenly the tNet0 tasks consumed 100% CPU and stays so, which of course makes
the IOC unusable. Only reboot helps. This happens on multiple IOCs but not synchronously.
It looks like the tNet0 task is constantly timing out and trying to drop some connection. But I cannot find out which
one. Any network diagnostics function freezes in ipcom_block_wait at a semaphore.
Has anyone seen this behavior before?
It hasn't happened here at APS to my knowledge. Is it unique to a
particular board type, or a specific network interface driver? What
sub-version of VxWorks 6.9 are you running, and have you checked with
the Wind River knowledge forums and/or support?
- Andrew
tt tNet0
0x0012c68c vxTaskEntry +0x48 : ipcomNetTask ()
0x00113c40 ipcomNetTask +0x34 : jobQueueProcess ()
0x0029d9d8 jobQueueProcess+0xe8 : 0x00241584 ()
0x002415b4 ipcom_atomic_sub_and_return+0x9c : 0x001f9208 ()
0x001f9274 ipnet_timeout_cancel+0xe4 : 0x00226910 ()
0x0022699c iptcp_drop_connection+0x8a4: ipcom_list_remove ()
value = 0 = 0x0
tt tNet0
0x00226a48 iptcp_drop_connection+0x950: 0x0022b380 ()
0x0022c4e0 sockInfo +0x2ca4: ipcom_list_insert_first (0x1f, 0x1f)
value = 0 = 0x0
tt tNet0
0x0022c4bc sockInfo +0x2c80: 0x0022c58c ()
value = 0 = 0x0
tt tNet0
value = 0 = 0x0
tt tNet0
value = 0 = 0x0
Dirk
Complexity comes for free, Simplicity you have to work for.
- VxWorks network problem Zimoch Dirk (PSI) via Core-talk
Build failed: epics-base base-7.0-57 AppVeyor via Core-talk
epics-7.0 » linux32 - Build # 426 - Still Unstable! APS Jenkins via Core-talk
<2022>
2025
2026
Re: VxWorks network problem Michael Davidsaver via Core-talk
<2022>
2025
2026
