On 8/29/22 00:57, Zimoch Dirk (PSI) wrote:
Does vxworks expose any packet packet Tx/Rx counters?
After it happens, VxWorks 6 does not expose any network related information any more because everything network related
(such as ifconfig) hangs at a semaphore.
An upstream intelligent switch could also give some of this information.
I found one strange thing in our logs though:
CAS: request from 172.19.10.40:46228 => CAS: Missaligned protocol rejected
These messages show up on several systems, but may be completely unrelated.
I suspect some Java CA clients.
Are there more lines to this message? Maybe a security scanner?
- VxWorks network problem Zimoch Dirk (PSI) via Core-talk
- Re: VxWorks network problem Michael Davidsaver via Core-talk
- Re: VxWorks network problem Zimoch Dirk (PSI) via Core-talk
Build failed: epics-base base-lnkfs-890 AppVeyor via Core-talk
<2022>
2025
2026
<2022>
2025
2026
