2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-7.0-win64 #340
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 3 Sep 2022 10:55:28 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/340/display/redirect?page=changes>
Changes:
[Andrew Johnson] Add .gitignore files to the makeBase{App,Ext} templates
[Andrew Johnson] Build system fixes related to INSTALL_LOCATION
[Andrew Johnson] Fix for GitHub issue #293
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/ws/>
The recommended git tool is: NONE
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\epics-base-7.0-win64\.git # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Using shallow fetch with depth 5
Fetching upstream changes from https://git.launchpad.net/epics-base
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
 > git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --no-tags --force --progress --depth=5 -- https://git.launchpad.net/epics-base +refs/heads/7.0:refs/remotes/origin/7.0 # timeout=10
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/7.0^{commit}" # timeout=10
Checking out Revision 54c02e2c247def09ebfbfc501e29c1b4e25d42a8 (refs/remotes/origin/7.0)
 > C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files/Git/cmd/git.exe checkout -f 54c02e2c247def09ebfbfc501e29c1b4e25d42a8 # timeout=10
Commit message: "Fix for GitHub issue #293"
 > C:/Program Files/Git/cmd/git.exe rev-list --no-walk a8e8d22c31aaa2bfff6511017e883b5e751a3e0a # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
[epics-base-7.0-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins273966429356780082.bat
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>make -j4 -O --no-print-directory
make -C ./configure install
perl -CSD ../src/tools/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
cl -nologo -C -E               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include         ../toolchain.c > TOOLCHAIN.windows-x64.windows-x64
toolchain.c
"Installing CFG file ../../cfg/TOOLCHAIN.windows-x64.windows-x64"
mkdir ../../cfg
"Installing CFG file ../../cfg/CONFIG_LIBCOM_VERSION"
"Installing CFG file ../../cfg/CONFIG_LIBCOM_MODULE"
"Installing CFG file ../../cfg/CONFIG_CA_MODULE"
"Installing CFG file ../../cfg/CONFIG_CA_VERSION"
"Installing CFG file ../../cfg/CONFIG_DATABASE_VERSION"
"Installing CFG file ../../cfg/CONFIG_DATABASE_MODULE"
make -C ./src install
make -C ./tools install
perl -CSD ../../src/tools/makeMakefile.pl O.windows-x64 ../../..
make -C O.windows-x64 -f ../Makefile TOP=../../.. \
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm"
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/PodHtml.pm"
"Installing PERL_MODULES file ../../../lib/perl/EPICS/PodXHtml.pm"
"Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl"
"Installing html ../../../html/./style.css"
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o makeAPIheader.html ../makeAPIheader.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podToHtml.html ../podToHtml.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podRemove.html ../podRemove.pl
"Installing script ../../../bin/windows-x64/convertRelease.pl"
"Installing script ../../../bin/windows-x64/assembleSnippets.pl"
mkdir ../../../bin
mkdir ../../../bin/windows-x64
"Installing script ../../../bin/windows-x64/cvsclean.pl"
"Installing script ../../../bin/windows-x64/depclean.pl"
"Installing script ../../../bin/windows-x64/dos2unix.pl"
"Installing script ../../../bin/windows-x64/epicsProve.pl"
"Installing script ../../../bin/windows-x64/expandVars.pl"
"Installing script ../../../bin/windows-x64/fullPathName.pl"
"Installing script ../../../bin/windows-x64/installEpics.pl"
"Installing script ../../../bin/windows-x64/makeAPIheader.pl"
"Installing script ../../../bin/windows-x64/makeMakefile.pl"
"Installing script ../../../bin/windows-x64/makeTestfile.pl"
"Installing script ../../../bin/windows-x64/mkmf.pl"
"Installing script ../../../bin/windows-x64/podToHtml.pl"
"Installing script ../../../bin/windows-x64/munch.pl"
"Installing script ../../../bin/windows-x64/podRemove.pl"
"Installing script ../../../bin/windows-x64/replaceVAR.pl"
"Installing script ../../../bin/windows-x64/tap-to-junit-xml.pl"
"Installing script ../../../bin/windows-x64/testFailures.pl"
"Installing script ../../../bin/windows-x64/useManifestTool.pl"
"Installing script ../../../bin/windows-x64/genVersionHeader.pl"
"Installing script ../../../bin/windows-x64/makeRPath.py"
"Installing generated html ../../../html/./EPICS/Getopts.html"
mkdir ../../../html/./EPICS
"Installing generated html ../../../html/./EPICS/Path.html"
"Installing generated html ../../../html/./EPICS/Readfile.html"
"Installing generated html ../../../html/./fullPathName.html"
"Installing generated html ../../../html/./makeAPIheader.html"
"Installing generated html ../../../html/./munch.html"
"Installing generated html ../../../html/./podToHtml.html"
"Installing generated html ../../../html/./podRemove.html"
make -C template/base install
make -C template/ext install
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/ws/bin/windows-x64/makeMakefile.pl> O.windows-x64 ../../../..
make -C O.windows-x64 -f ../Makefile TOP=../../../.. \
"Installing script ../../../../bin/windows-x64/makeBaseApp.pl"
"Installing ../../../../templates/makeBaseApp/top/Makefile"
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
"Installing ../../../../templates/makeBaseApp/top/.gitignore"
"Installing ../../../../templates/makeBaseExt/top/Makefile"
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
"Installing script ../../../../bin/windows-x64/makeBaseExt.pl"
"Installing ../../../../templates/makeBaseExt/top/.gitignore"
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseApp/top/configure
"Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseExt/top/README"
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG"
mkdir ../../../../templates/makeBaseExt/top/configure
"Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE"
"Installing ../../../../templates/makeBaseApp/top/configure/Makefile"
"Installing ../../../../templates/makeBaseExt/top/configure/Makefile"
"Installing ../../../../templates/makeBaseApp/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES"
"Installing ../../../../templates/makeBaseExt/top/configure/RELEASE"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP"
"Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64"
mkdir ../../../../templates/makeBaseExt/top/configure/os
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-aarch64.darwin-aarch64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-aarch64.linux-aarch64"
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug"
"Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/exampleExt
"Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64"
"Installing ../../../../templates/makeBaseExt/top/src/Makefile"
mkdir ../../../../templates/makeBaseExt/top/src
"Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c"
"Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM"
"Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile"
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make -C ./test install
make -C ./modules install
make[1]: *** No rule to make target '../configure/CONFIG_SITE.local', needed by 'RELEASE.windows-x64.local'.  Stop.
make: *** [configure/RULES_DIRS:85: modules.install] Error 2
make: *** Waiting for unfinished jobs....
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/ws/bin/windows-x64/expandVars.pl>  -t ../../.. -a windows-x64 ../Snippets.plt Snippets.t
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Jenkins build is back to normal : epics-base-7.0-win64 #341 APS Jenkins via Core-talk
Prev: Build failed: epics-base base-7.0-893 AppVeyor via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64 #341 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
