2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: RE: readline in base 7.0.7
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Thu, 8 Sep 2022 18:44:51 +0000
> You will need to manually specify COMMANDLINE_LIBRARY for the time being.  (and hopefully put an OS upgrade on your roadmap)
This is unfortunate, since the automatic detection worked fine in base 7.0.6.1.
The release notes really should say that manual editing is now required for older compilers, while it previously was not.  They should also say which version of gcc is required to have the automatic detection work.  I now need to spend a few hours rebuilding base and synApps for a bunch of architectures.
We have a number of machines where vendor support for kernel drivers limits such upgrades.  RHEL 7 has 2 more years before EOL, and is still used on many APS beamlines.
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Thursday, September 8, 2022 1:29 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: core-talk at aps.anl.gov
Subject: Re: readline in base 7.0.7
On 9/8/22 10:40, Mark Rivers via Core-talk wrote:
> I just built base 7.0.7 on Centos 7 with no changes to the files in configure/os.
Right, I wasn't paying attention.  Automatic detection now depends on GCC version.  As I recall, centos7 has GCC 4.8, which is too old.
> My IOCs now are not built with libreadline, while in base 7.0.6.1 they were, again with no changes to the configure/os files.
> I see this change between base 7.0.6.1 and base 7.0.7
> corvette:base-7.0.7/configure/os>git diff R7.0.6.1 R7.0.7
> CONFIG_SITE.Common.linux-x
> CONFIG_SITE.Common.linux-x86        CONFIG_SITE.Common.linux-x86_64
> CONFIG_SITE.Common.linux-xscale_be
> diff --git a/configure/os/CONFIG_SITE.Common.linux-x86_64
> b/configure/os/CONFIG_SITE.Common.linux-x86_64
> index e098b76..b98385f 100644
> --- a/configure/os/CONFIG_SITE.Common.linux-x86_64
> +++ b/configure/os/CONFIG_SITE.Common.linux-x86_64
> @@ -15,10 +15,6 @@
> #    to inform the system of the shared library location.
> -# Use GNU Readline if the header file is installed
> -COMMANDLINE_LIBRARY = $(strip $(if $(wildcard \
> -    $(GNU_DIR)/include/readline/readline.h), READLINE, EPICS))
> # If libreadline needs additional libraries to be linked with it, try
> # uncommenting each of the lines below in turn, starting with the top
> # one and working downwards, until the build succeeds. Do a 'make rebuild'
> The release notes say:
> *Automatic COMMANDLINE_LIBRARY w/ newer compilers*
> When built with a compiler supporting __has_include<>, the presence of the <readline/readline.h> will be used to automatically determine a default value for COMMANDLINE_LIBRARY.
> Mingw builds with readline support now link -ltermcap instead of -lcurses.
> This should not effect sites which set explicitly set COMMANDLINE_LIBRARY as the only definition in Base now has the form COMMANDLINE_LIBRARY ?= ....
> I interpret the first sentence here to mean that the test for
> COMMANDLINE_LIBRARY is done in the compiler if possible, but it does
> not say that the previous way of doing it in the CONFIG_SITE file (for
> older compilers) has been removed
> Does this mean that I now need to edit CONFIG_SITE.Common.linux-x86_64 to manually set COMMANDLINE_LIBRARY?
> Thanks,
> Mark
Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
readline in base 7.0.7 Mark Rivers via Core-talk
Prev: Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
Next: Build failed: EPICS Base 7 base-R7.0.7-684 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: readline in base 7.0.7 Michael Davidsaver via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
