2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: [Bug 1995728] [NEW] registerRecordDeviceDriver.pl bug
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 04 Nov 2022 14:06:20 -0000
Public bug reported:
In EPICS 7, when processing a dbd file with a long function name (> 24
chars), registerRecordDeviceDriver.pl generates buggy output.
With the following file test.dbd:
function(abcdefghijklmnopqrstuvwxyz0123456789)
The command perl registerRecordDeviceDriver.pl test.dbd generates code with a line break in the middle of a variable name:
epicsShareExtern reg_func pvar_func_register_func_abcdefghijklmnopqrstuvwx
    yz0123456789;
I suspect the error is in line 191 caused by the usage of wrap().
I have tested this with perl v5.16.3 and v5.26.3.
** Affects: epics-base
     Importance: Undecided
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1995728
Title:
Status in EPICS Base:
  New
Bug description:
      yz0123456789;
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1995728/+subscriptions
[Bug 1995728] Re: registerRecordDeviceDriver.pl bug Dirk Zimoch via Core-talk
[Bug 1995728] Re: registerRecordDeviceDriver.pl bug Andrew Johnson via Core-talk
Prev: Build completed: pva2pva 1.0.60 AppVeyor via Core-talk
Next: [Bug 1995728] Re: registerRecordDeviceDriver.pl bug Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
ANJ, 04 Nov 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
