2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: [Bug 1995728] Re: registerRecordDeviceDriver.pl bug
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 04 Nov 2022 16:17:00 -0000
I agree with your assessment and solution. Fixed on the 7.0 branch,
including test changes, in commit
cbd86ada20cedbff5f45fe8decb3b7b7da71ef0f
Thanks!
** Changed in: epics-base
     Assignee: (unassigned) => Andrew Johnson (anj)
** Also affects: epics-base/7.0
   Importance: Undecided
     Assignee: Andrew Johnson (anj)
       Status: New
** Changed in: epics-base/7.0
       Status: New => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1995728
Title:
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  In EPICS 7, when processing a dbd file with a long function name (> 24
  chars), registerRecordDeviceDriver.pl generates buggy output.
  With the following file test.dbd:
  function(abcdefghijklmnopqrstuvwxyz0123456789)
  The command perl registerRecordDeviceDriver.pl test.dbd generates code with a line break in the middle of a variable name:
  epicsShareExtern reg_func pvar_func_register_func_abcdefghijklmnopqrstuvwx
      yz0123456789;
  I suspect the error is in line 191 caused by the usage of wrap().
  I have tested this with perl v5.16.3 and v5.26.3.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1995728/+subscriptions
[Bug 1995728] [NEW] registerRecordDeviceDriver.pl bug Dirk Zimoch via Core-talk
Prev: [Bug 1995728] Re: registerRecordDeviceDriver.pl bug Dirk Zimoch via Core-talk
Next: epics-7.0 » linux32 - Build # 435 - Fixed! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Build failed: epics-base base-7.0-60 AppVeyor via Core-talk
ANJ, 04 Nov 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
