2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Compression record returns double value for field "N" over channel access
From: Georg Weiss via Core-talk <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 25 Nov 2022 09:30:09 +0000
The field N (and NSAM) of a compression record should according to specification (https://epics.anl.gov/base/R7-0/6-docs/compressRecord.html) use ULONG. However, reading the field N over channel access apparently may return a double value:
>cainfo RFQ-010:RFS-EPR-110:Cur-ROI-Avg.N
    State:            connected
    Host:             idmz-ro-epics-gw-tn.esss.lu.se:5064
    Access:           read, no write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
The assumption is that since input data is an array of doubles, the field N uses same type.
While the above suggests query was handled by a ca gateway, I get the same result when not using a gateway.
Seems pvaccess returns a unsigned long type for field N.
Is this behavior expected?
BR,
Georg Weiss
European Spallation Source
Re: Compression record returns double value for field "N" over channel access Ralph Lange via Core-talk
Prev: Re: Question PVA environment variable Kasemir, Kay via Core-talk
Next: Re: Compression record returns double value for field "N" over channel access Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Build failed: EPICS Base 7 base-7.0-709 AppVeyor via Core-talk
ANJ, 25 Nov 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
