On Fri, 25 Nov 2022 at 11:14, Georg Weiss via Core-talk <core-talk at aps.anl.gov> wrote:
Well, kind of. Channel Access can't transport ULONG data. Instead, it will use DOUBLE. Thus, when doing the cainfo against the original compress record (on the IOC), I would expect that you see the Native type as DBF_ULONG and the Request Type as DBR_DOUBLE. The CA Gateway, however, has already a CA connection on the IOC side, so the data item for an original ULONG is of type DOUBLE inside the Gateway. This means when you're doing a cainfo against the Gateway, it would report both the Native and the Request type as DOUBLE. Please re-check your statement that you see the same result against the original IOC. I would expect the Native type to be ULONG in that case. Cheers, ~Ralph
| ANJ, 25 Nov 2022 |
Home
News
About
Talk
Base
Modules
Extensions
