See <https://jenkins.aps.anl.gov/job/epics-base-3.15/561/display/redirect>
Changes:
Started by timer
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on the built-in node in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/>
The recommended git tool is: NONE
No credentials specified
> git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/.git> # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> git --version # timeout=10
> git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15 # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1006)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1248)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1312)
at hudson.scm.SCM.checkout(SCM.java:540)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1217)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:647)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:519)
at hudson.model.Run.execute(Run.java:1897)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
at hudson.model.ResourceController.execute(ResourceController.java:101)
at hudson.model.Executor.run(Executor.java:442)
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15" returned status code 128:
stdout:
stderr: fatal: unable to access 'https://git.launchpad.net/epics-base/': Failed connect to webproxy1.anl.gov:9091; Connection timed out
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2736)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2111)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:87)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:623)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1004)
... 11 more
Archiving artifacts
- Jenkins build is back to normal : epics-base-3.15 #562 APS Jenkins via Core-talk
Build failed: EPICS Base 7 base-7.0-716 AppVeyor via Core-talk
Build failed in Jenkins: epics-base-3.15-win32 #531 APS Jenkins via Core-talk
<2022>
2025
2026
<2022>
2025
2026
