The reason is in iocsh.cpp line 363:
if (quote != EOF) {
Here, quote is 0xff but EOF is -1.
quote is initialized in line 265:
char quote = EOF;
The problem is the usage of EOF in function split().
On any architecture, where char is unsigned (e.g. VxWorks on PPC), the initialization
char quote = EOF;
sets quote to (char)-1 = 255.
Later, the comparison (quote != EOF) compares an unsigned char with the
signed int literal -1. Thus the unsigned char gets promoted to a signed
int with the same value 255 which is then then compared to -1. That is
of course not equal.
The possible fixes are:
1. use signed char quote
2. use int quote
3. use 0 instead of EOF
I prefer solution 3. The attached patch has been created with commit
60128ee but can be applied to the current HEAD (bc54524) as well.
** Patch added: "iocsh_fix_for_unsigned_char.patch"
https://bugs.launchpad.net/epics-base/+bug/2004463/+attachment/5644257/+files/iocsh_fix_for_unsigned_char.patch
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2004463
Title:
iocsh on vxWorks broken
Status in EPICS Base:
New
Bug description:
Since commit 60128ee9 "Com: separate iocsh argument splitting", iocsh
is broken on VxWorks (tested with version 6.9.4.12)
Any command prints the error "Unbalanced quote."
> iocsh
epics> echo
Unbalanced quote.
epics> "echo"
Unbalanced quote.
epics> "echo
Unbalanced quote.
epics> echo bla
Unbalanced quote.
epics> echo 1 2 3
Unbalanced quote.
epics> exit
Unbalanced quote.
I have started investigating....
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2004463/+subscriptions
- [Bug 2004463] [NEW] iocsh on vxWorks broken Dirk Zimoch via Core-talk
[Bug 2004463] Re: iocsh on vxWorks broken Dirk Zimoch via Core-talk
<2023>
2025
2026
<2023>
2025
2026
