2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: [Bug 2004463] Re: iocsh on vxWorks broken
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 01 Feb 2023 15:56:42 -0000
Core Group 2/1/2023: Thanks!
This change is still in unreleased Base branch.
We agree with Dirk's analysis, and would prefer to run the tests on an
architecture that has unsigned char, if necessary the use of -funsigned-
char should work.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2004463
Title:
Status in EPICS Base:
  New
Bug description:
  Since commit 60128ee9 "Com: separate iocsh argument splitting", iocsh
  is broken on VxWorks (tested with version 6.9.4.12)
  Any command prints the error "Unbalanced quote."
  > iocsh
  epics> echo
  Unbalanced quote.
  epics> "echo"
  Unbalanced quote.
  epics> "echo
  Unbalanced quote.
  epics> echo bla
  Unbalanced quote.
  epics> echo 1 2 3
  Unbalanced quote.
  epics> exit
  Unbalanced quote.
  I have started investigating....
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2004463/+subscriptions
[Bug 2004463] [NEW] iocsh on vxWorks broken Dirk Zimoch via Core-talk
Prev: [Bug 2004463] Re: iocsh on vxWorks broken Dirk Zimoch via Core-talk
Next: [Bug 2004463] Re: iocsh on vxWorks broken Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 01 Feb 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
