2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: nil record field question
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Andrew Johnson <anj at anl.gov>, "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Wed, 22 Mar 2023 22:23:34 +0000
Thanks Andrew.  It was really STAT that concerned me most.
From: Core-talk <core-talk-bounces at aps.anl.gov> On Behalf Of Andrew Johnson via Core-talk
Sent: Wednesday, March 22, 2023 5:16 PM
To: core-talk at aps.anl.gov
Subject: Re: nil record field question
Hi Mark,
The ELL values that dbpr displays for MLIS are the count and next and prev pointers of the linked list of channel monitors (clients) connected to that record. In your case there are 4 entries in the list, whereas in Jueri's case he didn't have any CA clients monitoring the record so that list is empty.
SPVT is a private field for the record scanning mechanism, your record belongs to the 1 second scan list whereas his is passive so <nil> is expected there.
I don't know what STAT being shown as <nil> means, that does seem strange as it's an ENUM so it should display one of the strings valid for that ENUM. That might be an indication of a driver writing where it shouldn't.
HTH,
- Andrew
On 3/22/23 3:18 PM, Mark Rivers via Core-talk wrote:
Folks,
Jueri Tagger from BNL says the asynPortDriver::readInt16Array method in asyn R4-44-1 is not working for him.  He says the readInt16Array method is not being called when the associated waveform record processes.
It works fine for me in the asyn testErrorsApp test program.
This is dbpr on my waveform record:
epics> dbpr testErrors:WfInt16In 4
ACKS: NO_ALARM      ACKT: YES           AMSG:               APST: Always
ASG :               ASP : PTR (nil)     BKLNK: ELL 0 [(nil) .. (nil)]
BKPT: 00            BPTR: PTR 0x9e9d40  BUSY: 0             DESC:
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DPVT: PTR 0xa0f080  DSET: PTR 0x7f699647ece0
DTYP: asynInt16ArrayIn                  EGU :               EVNT:
FLNK: CONSTANT      FTVL: SHORT         HASH: 0             HOPR: 0
INP : INST_IO @asyn(PORT1,0,1)INT16_ARRAY_VALUE             LCNT: 0
LOPR: 0             LSET: PTR 0x9d8b40
MLIS: ELL 4 [0x7f694802f580 .. 0x7f694802f478]
MLOK: 10 9d 9e 00 00 00 00 00           MPST: Always
NAME: testErrors:WfInt16In              NAMSG:              NELM: 100
NORD: 100           NSEV: NO_ALARM      NSTA: NO_ALARM      OLDSIMM: NO
PACT: 0             PHAS: 0             PINI: NO            PPN : PTR (nil)
PPNR: PTR (nil)     PREC: 0             PRIO: LOW           PROC: 0
PUTF: 0             RARM: 0             RDES: PTR 0x994010  RPRO: 0
RSET: PTR 0x7f69961c09e0                SCAN: 1 second      SDIS: CONSTANT
SDLY: -1            SEVR: NO_ALARM      SIML: CONSTANT      SIMM: NO
SIMPVT: PTR (nil)   SIMS: NO_ALARM      SIOL: CONSTANT      SPVT: PTR 0xa29f60
SSCN: <nil>         STAT: NO_ALARM      TIME: 2023-03-21 17:31:36.000000000
TPRO: 0             TSE : -2            TSEL: CONSTANT      UDF : 0
UDFS: INVALID       UTAG: 0             VAL : PTR (nil)
This is what he sees for his record:
epics> dbpr("SR-RF{CFC:E-NA}Val:R-Wf", 4)
ACKS: INVALID       ACKT: YES           AMSG:               APST: Always
ASG :               ASP : PTR 0x1a4fda0 BKLNK: ELL 1 [0x16482a0 .. 0x16482a0]
BKPT: 00            BPTR: PTR 0x19267e0 BUSY: 0             DESC:
DPVT: PTR 0x1a15e30 DSET: PTR 0x7ff1f6d21f00
FLNK: DB_LINK SR-RF{CFC:E-NA}Val:Wf-Calc                    FTVL: SHORT
HASH: 0             HOPR: 0             INP : INST_IO @asyn(rfport,0)NA I
LCNT: 0             LOPR: 0             LSET: PTR 0x16f49e0
MLIS: ELL 0 [(nil) .. (nil)]            MLOK: b0 67 92 01 00 00 00 00
MPST: Always        NAME: SR-RF{CFC:E-NA}Val:R-Wf           NAMSG:
NELM: 128           NORD: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
OLDSIMM: NO         PACT: 0             PHAS: 0             PINI: NO
PPN : PTR (nil)     PPNR: PTR (nil)     PREC: 0             PRIO: LOW
PROC: 1             PUTF: 0             RARM: 0             RDES: PTR 0x1206680
RPRO: 0             RSET: PTR 0x7ff1f5783960                SCAN: Passive
SDIS: CONSTANT      SDLY: -1            SEVR: INVALID       SIML: CONSTANT
SIMM: NO            SIMPVT: PTR (nil)   SIMS: NO_ALARM      SIOL: CONSTANT
SPVT: PTR (nil)     SSCN: <nil>         STAT: <nil>
TIME: 2023-03-22 11:45:16.791763817     TPRO: 1             TSE : 0
TSEL: CONSTANT      UDF : 0             UDFS: INVALID       UTAG: 0
VAL : PTR (nil)
epics>
I notice that on his record the MLIS,SPVT, and STAT fields are <nil> whereas that is not the case for my record.
Is this an indication of a problem like perhaps memory corruption in his driver, or can that be normal?
Complexity comes for free, Simplicity you have to work for.
nil record field question Mark Rivers via Core-talk
Re: nil record field question Andrew Johnson via Core-talk
Prev: Re: nil record field question Andrew Johnson via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-893 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 28 Mar 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
