2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Create NTTable from JSON
From: "Veseli, Sinisa via Core-talk" <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>, Karl Vestin <karl.vestin at ess.eu>
Date: Wed, 5 Apr 2023 14:22:47 +0000
I am not sure if this helps, but if the object has correct structure as far as number/type columns, at the moment you could do something like this:
>>> nt = NtTable([STRING, INT, DOUBLE])
>>> nt.setColumn(0, ['xx', 'yy', 'zz'])
>>> nt.setColumn(1, [1, 2, 3])
>>> nt.setColumn(2, [11.1, 22.2, 33.3])
>>> nt.useNumPyArrays=False
>>> myString = json.dumps(dict(nt))
>>> print(myString)
{"labels": [], "value": {"column0": ["xx", "yy", "zz"], "column1": [1, 2, 3], "column2": [11.1, 22.2, 33.3]}, "descriptor": "", "timeStamp": {"secondsPastEpoch": 0, "nanoseconds": 0, "userTag": 0}, "alarm": {"severity": 0, "status": 0, "message": ""}}
>>> nt2 = NtTable([STRING, INT, DOUBLE])
>>> nt2.set(json.loads(myString))
>>> print(nt2)
epics:nt/NTTable:1.0
    string[] labels []
    structure value
        string[] column0 [xx, yy, zz]
        int[] column1 [1,2,3]
        double[] column2 [11.1,22.2,33.3]
    string descriptor
    time_t timeStamp
        long secondsPastEpoch 0
        int nanoseconds 0
        int userTag 0
    alarm_t alarm
        int severity 0
        int status 0
        string message
Sinisa
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
sveseli at anl.gov
(630)252-9182
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Karl Vestin via Core-talk <core-talk at aps.anl.gov>
Sent: Wednesday, April 5, 2023 8:25 AM
To: core-talk at aps.anl.gov <core-talk at aps.anl.gov>
Subject: Create NTTable from JSON
Dear all,
Are there any functions available to generate a NTTable from a JSON object or JSON schema? I have found a function to generate JSON from a PVObject, but not the other way around.
Anyone have insights to share?
Karl Vestin
Group Leader Hardware and Integration
Integrated Control Systems Division
European Spallation Source ERIC
+46721792066
P.O Box 176, SE 221 00 Lund, Sweden
Visiting address: Odarslövsvägen 113, Lund
Create NTTable from JSON Karl Vestin via Core-talk
Prev: Create NTTable from JSON Karl Vestin via Core-talk
Next: [Bug 2015234] Re: newline problem with genVersionHeader.pl Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re: Create NTTable from JSON Michael Davidsaver via Core-talk
ANJ, 05 Apr 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
