2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: OPI updates when enum strings/values change
From: Mark Rivers via Core-talk <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>, "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Tue, 2 May 2023 16:48:53 +0000
Hi Michael,
At the EPICS Core workshop last week I made a comment that one limitation of Channel Access was that OPI clients are not informed when enum strings or values change, and so OPI displays don’t update to reflect these changes.  I said that one needs to close the display and re-open it in order to see the changes.
You said this was because I was using a very old OPI client, i.e. medm.  You said that modern clients handle this correctly, by having 2 subscriptions to the PV, one for the value and one for the metadata.  You said that Phoebus is one of the clients that handles this correctly.
I just tested this with Phoebus.  I used the asyn/testAsynPortClient application.  In that application when the VerticalGain record is changed the enum choices for the VoltsPerDivSelect and VoltsPerDivSelect_RBV fields are changed.
VerticalGainRecord: https://github.com/epics-modules/asyn/blob/f9d492ed58f4bd730cf49ac7feccc201cd2b17b0/testAsynPortDriverApp/Db/testAsynPortDriver.db#L105
Code where enum values for VoltsPerDivSelect are changed: https://github.com/epics-modules/asyn/blob/f9d492ed58f4bd730cf49ac7feccc201cd2b17b0/testAsynPortDriverApp/src/testAsynPortDriver.cpp#L369
It does callbacks to device support where the record values are changed: https://github.com/epics-modules/asyn/blob/f9d492ed58f4bd730cf49ac7feccc201cd2b17b0/asyn/devEpics/devAsynInt32.c#L726
I have converted the medm .adl file for testAsynPortDriver to a Phoebus .bob file: https://github.com/epics-modules/asyn/blob/master/testAsynPortDriverApp/op/bob/autoconvert/testAsynPortDriver.bob
When I change the vertical Gain in Phoebus I observe exactly the same thing as in medm.  The enum menu choices for VoltsPerDivSelect mbbo and the enum string for the selected VoltsPerDivSelect_RBV do not update automatically.  They only update when I close the Phoebus window and re-open it.
I presume the behavior I observe with Phoebus must be due to one of the following 3 reasons:
  1. The asyn code for updating enum values is incorrect.
  2. The fact that the .bob file is autoconverted from medm rather than created natively in Phoebus is causing the undesired behavior.
  3. Phoebus cannot in fact update the screen when enum values change.
Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
Re: OPI updates when enum strings/values change Andrew Johnson via Core-talk
Prev: Build completed: EPICS Base 7 base-7.0-917 AppVeyor via Core-talk
Next: Re: OPI updates when enum strings/values change Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 02 May 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
