2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: STATIC_BUILD=NO howto ?
From: Torsten Bögershausen via Core-talk <core-talk at aps.anl.gov>
To: Ralph Lange <ralph.lange at gmx.de>, EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 13 Jun 2023 09:26:22 +0000
Hej Ralph,
started with this:
ethercatmcSupport_LIBS_freebsd += VendorDLL
(Which seems to be the wrong thing)
With some local help from here: Adding this line seems to do what I want:
USR_LDFLAGS += -L/usr/local/lib -lMyVendorXXX
(Or is there a better way ?)
BR
/Torsten
From: Core-talk <core-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Core-talk <core-talk at aps.anl.gov>
Reply to: Ralph Lange <ralph.lange at gmx.de>
Date: Tuesday, 13 June 2023 at 10:42
To: EPICS Core Talk <core-talk at aps.anl.gov>
Hej Torsten,
Your error looks like you didn't declare the location of the vendor library.
Did you set Vendor_DIR?
If the build system doesn't find the library in a specified place, it assumes it is to be generated locally. That's why it tries to build a local libVendor.a, as it would need that to create a local libVendor.so.
Cheers,
~Ralph
Re: STATIC_BUILD=NO howto ? Ralph Lange via Core-talk
STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Prev: Re: STATIC_BUILD=NO howto ? Ralph Lange via Core-talk
Next: Re: STATIC_BUILD=NO howto ? Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 13 Jun 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
