2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: STATIC_BUILD=NO howto ?
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: Torsten Bögershausen <Torsten.Bogershausen at ess.eu>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 13 Jun 2023 14:25:56 +0200
Well,
In that Makefile, the PROD is "ethercatmc", not "ethercatmcsupport".
ethercatmc_LIBS += Vendor
Vendor_DIR = /usr/local/lib
should construct the linker line as you expect.
Btw. I should have mentioned before: You only need to add the *_DIR line if the library is not in one of the system paths. Libraries in system paths are always found - adding them to *_LIBS is enough.
Cheers,
~Ralph
Re: STATIC_BUILD=NO howto ? Mark Rivers via Core-talk
STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Re: STATIC_BUILD=NO howto ? Ralph Lange via Core-talk
Re: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Prev: Re: STATIC_BUILD=NO howto ? Torsten Bögershausen via Core-talk
Next: Re: STATIC_BUILD=NO howto ? Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 13 Jun 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
