2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Alarm behaviour
From: Timo Korhonen via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 16 Jun 2023 15:26:41 +0000
Yesterday I was presented with a case that puzzles me. I thought I understand the behavior of alarms but it seems that I do not.
One (ai, “Soft Channel”) record in our system seems to be stuck in alarm state. See below for what CA and PVA report.
The record reports a MINOR alarm severity, even if the HIGH is set at 30 and the value is below (at 27.96).
The record gets its input from another record, so I thought that maybe the alarm is propagated from there, but the input link is set to NMS.
And, the origin record is not in an alarm state so that would be odd anyway.
What am I missing here?
(One interesting observation is that pvget -v lists severities as null, although they are set (for sure.) HSV is set to MINOR (1).
EPICS version in this case is 7.0.6.1, but I see this with 7.0.7 as well. I do not think that this is related to the alarm behavior though.)
The records do not latch alarm states, do they? Or have I been wrong all these years? (I tried some other records in a soft IOC and they behaved as I would expect.)
What is the purpose of the ACKS and ACKT fields (if the explanation would be too long to write here, I can try to figure out from the source code…)
I have read what the record documentation says, but it does not help me to understand how these are intended to be used.
(Just for curiosity, ACKS=INVALID and ACKT=YES for that record.)
Is there an explanation for this, or any ideas where to look at?
Timo
(epics) timokorhonen@nxnode-06:~$ caget -a DTL-010:EMR-TT-028:Temp
DTL-010:EMR-TT-028:Temp        2023-06-16 09:09:44.009138 27.96 HIGH MINOR
(epics) timokorhonen@nxnode-06:~$ pvget DTL-010:EMR-TT-028:Temp
DTL-010:EMR-TT-028:Temp 2023-06-16 09:12:21.929  27.94 MINOR DEVICE HIGH
(epics) timokorhonen@nxnode-06:~$ pvget -v DTL-010:EMR-TT-028:Temp
DTL-010:EMR-TT-028:Temp epics:nt/NTScalar:1.0
    double value 27.96
    alarm_t alarm MINOR DEVICE HIGH
        int severity 1
        int status 1
        string message HIGH
    structure timeStamp
        long secondsPastEpoch 1686899551
        int nanoseconds 309940000
        int userTag 0
    structure display
        double limitLow 10
        double limitHigh 150
        string description "Temperature DTL-010 Tank, Location 028"
        string units degC
        int precision 0
        enum_t form (0) Default
            int index 0
            string[] choices [Default, String, Binary, Decimal, Hex, Exponential, Engineering]
    control_t control
        double limitLow 10
        double minStep 0
    valueAlarm_t valueAlarm
        boolean active false
        double lowAlarmLimit nan
        double lowWarningLimit nan
        double highWarningLimit 30
        double highAlarmLimit 50
        int lowAlarmSeverity 0
        int lowWarningSeverity 0
        int highWarningSeverity 0
        int highAlarmSeverity 0
        byte hysteresis 0
Dr. Timo Korhonen
Chief Engineer, Integrated Control System
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 721 79 22 31
E-mail: timo.korhonen at ess.eu
ess.eu
signature_2971982692
Re: Alarm behaviour Andrew Johnson via Core-talk
Prev: Build completed: epics-base base-7.0-965 AppVeyor via Core-talk
Next: Re: Alarm behaviour Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 16 Jun 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
